[OpenFOAM.org] How to clean the build environment...?
Like Tree6Likes
  • 3 Post By wyldckat
Old   September 20, 2012, 12:41
Default How to clean the build environment...?
Rui Alexandre Trigo Ribeiro Pereira
ed_teller is on a distinguished road
Hi
Is there any command to clean the build environment from object files, while still preserving the libraries and executables created...?
All i can find in foam directory is Allwmake... there is no Allwclean...
BRGDS
Alex
ed_teller is offline   Reply With Quote
Old   September 22, 2012, 16:32
Retired Super Moderator
Bruno Santos
Hi Alex,
Here's an example of why OpenFOAM is so great: we have full liberty to look at the source code of everything in it!
In this case, two folders are suspects:
  • The "bin" folder in "OpenFOAM-2.*.*".
  • The "wmake" folder, also in "OpenFOAM-2.*.*".
Almost all of the scripts placed in them have a nice big header that describes what each respective script does. It not, the source code inside it will tell it's own tale of how it does it's own job.
So, to answer your question, here are the following scripts that might come in handy to you:
  • rmoall - deletes all *.o files, starting from the folder where you are. More specifically, if you ask it for help:
    $ rmoall -help
    Usage: rmoall [dir1] .. [dirN]
        remove all .o files
  • rmdepall - ditto for *.dep
  • wcleanLnIncludeAll - ditto for "lnInclude" folders, but this you probably do not want, otherwise you won't be able to build your own custom utilities and solvers, nor use codeStream.
Best regards,
Bruno
Old   November 6, 2018, 13:36
Przemek
gaza is on a distinguished road
Originally Posted by wyldckat View Post
Hi Alex,
    $ rmoall -help
        remove all .o files
Best regards,
Bruno
How can I clean environment on OpenFOAM v1612+?
There are no rm* scripts
best regards
pblasiak
gaza is offline   Reply With Quote
Old   December 28, 2018, 08:37
Bruno Santos
Quick answer: I've finally written a wiki page with information on how to clean up the build environments for all major versions/forks/variants here: https://openfoamwiki.net/index.php/I...rmediate_files
You will find the indication on how to do the clean up in section OpenFOAM v3.0+, v1606+ and v1612+
louisgag, gaza and Daniel_Khazaei like this.
64-bit machine, 32-bit build environment daniel_pramudita FLUENT 2 January 18, 2018 13:06
Building from Source on Windows using Cygwin64 ericthefatguy SU2 2 May 12, 2015 18:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Documentation on build environment make clean edric OpenFOAM Installation 2 March 14, 2005 11:10
