Paraview 3.14.1 + opensuse 12.2 (gcc 4.7.1 & qmake 4.8.1) SOLVED
1 Attachment(s)
Hello everybody!!!!
I updated my OS to openSUSE 12.2 last weekend. As the title says it comes with gcc 4.7.1 and qt 4.8.1. I use the reader developed by Takuya Oshima (http://openfoamwiki.net/index.php/Co...r_for_ParaView) The reader requieres that paraview is compiled with some flags (see the previous link for details) so, I use to build paraview by myself instead of use a precompiled version (openSUSE has a Paraview 3.14.0 package) I found that compile Paraview it is not as straight as it was before, this is because of the gcc version. I found the solution and I want to share it. In order to build Paraview we have to patch the original sources. The patch file is attached. The patch is a merge from https://build.opensuse.org/package/v...roject=science and http://anonscm.debian.org/gitweb/?p=...c1a34fc103d208 After we patched the sources the compilation follows as before. Hope it helps somebody!!!! Pablo |
Hi, Pablo,
It is very nice of you to post the patch. I have never built paraview (and the OpenFOAM reader). But, now I am using OpenSUSE 12.2 and am having a lot of issues with paraview. So, I would like to give it a try. After I patched the Paraview source and ran ccmake, I got the following warning: You are using Qt 4.8.1. Officially supported version is Qt 4.6 Do I need to install Qt4.6? How to install QT 4.6 on OpenSUSE 12.2? Thanks! Pei-Ying |
Hi, Pablo,
When I type make to build paraview, it looked like the compilation was successful. But, when I ran paraview, I got the following error: hsieh@jali:~/projects/ParaView-3.14.1-Source/ParaView-bin/bin> ./paraview ./paraview: symbol lookup error: ./paraview: undefined symbol: _ZN23pqTabbedMultiViewWidgetC1EP7QWidget hsieh@jali:~/projects/ParaView-3.14.1-Source/ParaView-bin/bin> ----------------------------------------------------------------------- Any suggestion? Pei-Ying ---------------------- [100%] Building CXX object Applications/ParaView/CMakeFiles/paraview-real.dir/moc_ParaViewMainWindow.cxx.o Linking CXX executable ../../bin/paraview [100%] Built target paraview-real Scanning dependencies of target paraview [100%] Building C object Applications/ParaView/CMakeFiles/paraview.dir/paraview-forward.c.o Linking C executable launcher/paraview [100%] Built target paraview hsieh@jali:~/projects/ParaView-3.14.1-Source/ParaView-bin> |
Hi Pei-Ying
First of all, it feels good to give something back to the community! :D As you realized, you can compile paraview using qt 4.8.1, the message shown in ccmake it is just a WARNING. The compile sequence is:
Best, Pablo |
Hi, Pablo,
Thanks a million! You were correct. I did not do "make install". I thought that I can run the paraview before installation just to check it out. I was wrong. I am wondering if you can answer a couple of basic questions because I am not quite sure about the exact steps to build paraview. 1. If I put the source of paraview-3.14 under /opt/paraview/3.14.1, but, the build and install document suggested that paraview should be built in /opt/paraview/3.14.1/paraview-bin (well, in a separate folder in stead of the source), then, what should PARAVIEW_DIR be? PARAVIEW_DIR=/opt/Paraview/3.14.1? or PARAVIEW_DIR=/opt/Paraview/3.14.1/paraview-bin? 2. It looks like paraview-3.14.1 is having issue with reading stl in ascii format. I would like to compile the latest source from svn. After I grab the svn version, I am wondering if I should patch it using your patch? I am hoping that the svn version fixed the issue. Pei-Ying |
Hi Pei-Ying!
Sorry, I don't know. Try to build the svn version, if it fails try patching the sources, if it still fails...well I don't know. Best Pablo |
Thanks a lot Pablo! This really helped.
Pei-Ying |
Hi, Pablo,
I grabbed the latest development version from svn and compilation/installation went through. But, when I ram paraview, I got the following error: hsieh@jali:~/OpenFOAM/hsieh-2.1.x/run/damBreak> paraview ERROR: In /home/hsieh/projects/ParaView/VTK/GUISupport/Qt/vtkEventQtSlotConnect.cxx, line 68 vtkEventQtSlotConnect (0x1d0e470): Cannot connect NULL objects. Segmentation fault hsieh@jali:~/OpenFOAM/hsieh-2.1.x/run/damBreak> --------------------------------- Will applying your patch fix this issue? Also, your path applies to ParaView-3.14.1-Source. But, my paraview development version is under $HOME/projects/ParaView. How can I apply your patch to the new folder? Thanks! Pei-Ying |
Hi, Pablo,
It looks like there are only 3 files that needed to be patched. So, I did it manually to svn version. Compilation and installation were successful. But, I still got the same error when I ran paraview. Thanks! Pei-Ying |
Hi Pei-Ying
I'm not an expert using patch utility, but googling I found this link http://www.cyberciti.biz/faq/appy-pa...patch-command/ I think you should look for the solution in vtk and/or paraview forums. Have a nice weekend! Pablo |
Hi, Pablo,
Thanks a lot for your help! Wish you a good weekend too! Pei-Ying |
