-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   ParaView reader module libraries do not exist (http://www.cfd-online.com/Forums/openfoam-installation/107779-paraview-reader-module-libraries-do-not-exist.html)
anishtain4 October 7, 2012 02:32
When I want to use the paraFoam it complains:
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers
./Allwclean
./Allwmake
So I go to there and do ./Allwclean, it clears some stuff but when I want to ./Allwmake it returns
+ [ -d /opt/OpenFOAM/ThirdParty-2.1.0/platforms/linuxGcc/paraview-3.12.0 -a -r /opt/OpenFOAM/ThirdParty-2.1.0/platforms/linuxGcc/paraview-3.12.0 ]
I went down there and saw there is no paraview-3.12.0 folder there, but instead it is in the ThirdParty-2.1.0 folder, so I copied that to the subfolder, but still I get the same result.
What should I do?
wyldckat October 7, 2012 02:51
Greetings Mahdi,
Which Linux Distribution are you using and what instructions did you follow for installing OpenFOAM?
Best regards,
Bruno
anishtain4 October 7, 2012 07:22
Hey wyldckat, the savior is here again.
I'm using ubuntu 10.04 and I installed the OF manually as we discussed in another topic. Back then paraFoam was working fine, I have no idea how this has happened and it stopped working?
wyldckat October 7, 2012 15:24
Hi Mahdi,
Nah, I'm just a typical Obsessive Compulsive Installer :D
It's possible that you might have installed something else that might have disturbed OpenFOAM's working environment. Perhaps you installed another version of OpenFOAM?
What do these commands output:
echo $PV_PLUGIN_PATH
ls -l $PV_PLUGIN_PATH//libPV3FoamReader_SM.so
which paraview
Best regards,
Bruno
anishtain4 October 9, 2012 02:15
which paraview
Best regards,
Bruno
Guess it got out of service after some updates, not sure how it happened?
The output is:
/opt/OpenFOAM-2.1.1/platforms/linuxGccDPOpt/lib/paraview-3.12
-rwxr-xr-x 1 mahdi mahdi 198152 2012-10-08 19:36 /opt/OpenFOAM-2.1.1/platforms/linuxGccDPOpt/lib/paraview-3.12//libPV3FoamReader_SM.so
/opt/ThirdParty-2.1.1/platforms/linuxGcc/paraview-3.12.0/bin/paraview
I tried to install all the openfoam and paraview from the scratch, now when I want to open paraview it says: Segmentation fault
I looked it up and found another thread where you have mentioned there maybe something wrong with the Open-GL. I checked my drivers and I have the proprietary driver, but I remember I ran some command regarding to xorg :D guess that hit the problem. anyway I'm running the update from 10.04 to 12 LTS now, hope this helps
anishtain4 October 9, 2012 08:25
I believe it was a VGA issue, after update to precise things are working good.
Thanks for your patience
