OpenMPI fail with Bluecape port of OF2.1 (I am doing it wrong). |
October 13, 2012, 08:36 |
Rep Power: 15 |
So I have an operating setup of Bluecapes port of OF2.1 running just fine including running in parallel on Windows 7 64.
So I'm trying to setup another machine in exactly the same way, except clearly I am screwing something up as I get the error message below in the log files when trying to run a job in parallel. BTW the Windows firewall is totally disabled on this machine, so that should not be an issue, I believe I've followed the step in the user documentation, but clearly I am doing this wrong. Its frustrating as I've been through this once and solved it already and from memory its was an easy thing to do. AQny help is appreciated. C:\BLUECF~1.1\msys\home\ofuser>mpirun -n 4 -x HOME -x PATH -x USERNAME -x WM_PROJECT_DIR -x WM_PROJECT_INST_DIR -x WM_OPTIONS -x FOAM_LIBBIN -x FOAM_APPBIN -x FOAM_USER_APPBIN -x MPI_BUFFER_SIZE 5131088.bat [WIN-UEDH712LCQI:01756] [[2578,0],0] ORTE_ERROR_LOG: Error in file ..\..\..\openmpi-1.5.3\orte\mca\ess\hnp\ess_hnp_module.c at line 214 [WIN-UEDH712LCQI:01756] [[2578,0],0] ORTE_ERROR_LOG: Error in file ..\..\..\openmpi-1.5.3\orte\runtime\orte_init.c at line 128 -------------------------------------------------------------------------- It looks like orte_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during orte_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): orte_rml_base_select failed --> Returned value Error (-1) instead of ORTE_SUCCESS -------------------------------------------------------------------------- [WIN-UEDH712LCQI:01756] [[2578,0],0] ORTE_ERROR_LOG: Error in file ..\..\..\..\..\openmpi-1.5.3\orte\tools\orterun\orterun.c at line 572 -------------------------------------------------------------------------- It looks like orte_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during orte_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): orte_ess_set_name failed --> Returned value Error (-1) instead of ORTE_SUCCESS -------------------------------------------------------------------------- |
October 14, 2012, 05:07 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Doug68,
Mmm... not much information to work with, although from the first command line, it looks like I've seen some similar issue before. So, a few questions:
Best regards, Bruno
October 15, 2012, 09:08 |
Rep Power: 15 |
Sorry, all fixed now went back tot he beginning and followed the instructions properly
Display Modes | |
udf error | srihari | FLUENT | 1 | October 31, 2016 15:18 |
CCM+ Solution 11% higher than measured intake port flow - what are we doing wrong? | DBurns | Siemens | 16 | December 7, 2009 05:10 |
