Ubuntu 12.10 64bit: To compile or not?
Old   January 13, 2013, 20:45
Question Ubuntu 12.10 64bit: To compile or not?
The solar system
CrazyFatDude is on a distinguished road
Hi everyone,
I have put together a new computer with intel core i7 3930K, 32GB Ram, 1TB hdd, nvidia GTX 570. I'll install Ubuntu 12.10 and I would like to install OpenFoam for everything CFD, my questions are:
1. Are there any gains in compiling OpenFoam from source vs. installing from the binary file?
2. If compiling from source is the way to go, which compiler should I go for, will ICC be the obvious choice? Or does the latest version of GCC have the edge?
3. Do I need code vectorization, or use of pragmas to achieve better performance? I'm no expert on these terms but I have seen them mentioned in threads discussing GCC vs ICC.
Thanks.
CrazyFatDude is offline   Reply With Quote
Old   January 14, 2013, 04:10
Retired Super Moderator
Bruno Santos
Greetings CrazyFatDude,
In quick reply:
  1. Yes. One reported here on the forum indicated an increase of performance of 50%, at least a couple of years ago.
  2. You'll have to try it for yourself. It may depend from case to case. Some reports say that ICC is best and others say that GCC 4.5 and above can be around 5% faster.
    Some hints on this can be found here: http://www.cfd-online.com/Forums/blo...-amd-cpus.html - don't mind the crazy ranting post, but there is good information there, mainly in the comments.
  3. Yes, AFAIK, it's good to use everything your CPU has to offer.
  4. Not asked, but even if your CPU has Hyper-Threading, it's useless to use the threads with OpenFOAM: http://code.google.com/p/bluecfd-sin...SE_12.1_x86_64
Best regards,
Bruno
Old   January 14, 2013, 04:18
The solar system
Thanks a lot Bruno, sorry if I posted in the wrong forum. I'll keep coming to this thread and report my findings & further questions.
Thanks again.
compile, core i7, gcc, icc, linux
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 wyldckat OpenFOAM Installation 14 February 12, 2013 04:43
Gettings started after installing OpenFOAM 2.1.1 in Ubuntu 12.10 yoddha24 OpenFOAM 7 November 22, 2012 11:46
ThirdParty2.1.1 on Ubuntu 12.10 64bit davide_c OpenFOAM Installation 5 October 25, 2012 02:45
ubuntu 9.10 64bit - wmake missing headers soeren87 OpenFOAM Installation 5 November 11, 2009 10:01
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
