November 19, 2012, 02:59 |
OpenFOAM-1.7.1 Installation on Fedora14
christal oceaney
Hi Everybody,
When I install the OpenFOAM-1.7.1 and go to the step of ./Allwmake, there are some errors. make : Target 'application' not remade because of errors. And I attach the detail informations. Any suggestion will be appreciated. Best regards! Oceaney |
November 19, 2012, 17:21 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Oceaney and welcome to the forum!
This has already been fixed in OpenFOAM 1.7.x: http://www.openfoam.org/mantisbt/view.php?id=15 If you still want to use OpenFOAM 1.7.1, you should apply this fix to it: https://github.com/OpenCFD/OpenFOAM-...f64468c3973429 Best regards, Bruno
November 20, 2012, 04:15 |
christal oceaney
Dear Bruno,
Thanks for your suggestion, it works when I use 1.7.x, but I meet some other troubles in the next step ./makeParaView of installation. Error: cannot find qmake either at $QMAKE_PATH or in current $PATH I thought the qt is not installed, but it says 'qt-4.7.4-7.fc14.x86_64 already installed and latest version' when I do '# yum install qt'. So, what's the problem and how to fix it. Kind regards~ Oceaney |
November 20, 2012, 06:57 |
Bruno Santos
Rep Power: 128 |
Hi Oceaney,
This should do the trick: Code:
./makeParaView -qmake $(which qmake-qt4) Bruno
November 21, 2012, 04:44 |
christal oceaney
Dear Bruno,
I typed this code, but it seems not work. This is part of error information, ~~~~~~~~~~~~~~~~~~~~~~~~~~ CMake Error: The following variables are used in this project, but they are set to NOTFOUND. Please set them or make sure they are set and tested correctly in the CMake files: QT_QTASSISTANTCLIENT_INCLUDE_DIR (ADVANCED) used as include directory in directory /root/OpenFOAM/ThirdParty-1.7.x/paraview-3.8.0/Qt/ApplicationComponents -- Configuring incomplete, errors occurred! Starting make make: *** No targets specified and no makefile found. Stop. real 0m0.007s user 0m0.001s sys 0m0.006s Done make Installing ParaView to /root/OpenFOAM/ThirdParty-1.7.x/platforms/linux64Gcc/paraview-3.8.0 make: *** No rule to make target `install'. Stop. --- Installation complete for paraview-3.8.0 Set environment variables: export ParaView_DIR=/root/OpenFOAM/ThirdParty-1.7.x/platforms/linux64Gcc/paraview-3.8.0 export PATH=$ParaView_DIR/bin:$PATH export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-3.8 --- Done ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ And then I find the old blog post and paste the code which mentioned in this post to my terminal window: http://www.cfd-online.com/Forums/blo...-qt-4-6-3.html But the problem still exist. Please help me. Best regards, Oceaney |
November 21, 2012, 07:58 |
Bruno Santos
Rep Power: 128 |
Hi Oceaney,
I haven't had time to confirm this, but you probably need the following packages: Code:
qt-devel qt-webkit-devel Code:
yum install qt-devel qt-webkit-devel Best regards, Bruno
November 22, 2012, 01:53 |
christal oceaney
Dear Bruno,
It is not the problem of this packages. I also tried the pre-built ParaView 3.8.0 version, and everything goes well, looks like, but at the end, I got: ____________ # paraFoam created temporary 'cavity.foam' paraview-real: cannot connect to X server ____________ So depressed! I dont know how to do and hope you will help me when you have time. Best regards! Ocenaney |
November 22, 2012, 03:59 |
Bruno Santos
Rep Power: 128 |
Hi Oceaney,
Did you try searching with Google? Try these two commands: Code:
export LIBGL_ALWAYS_INDIRECT=y paraFoam Bruno
fedora14, openfoam-1.7.1 |
OpenFoam 2.0.0 installation | Jan_Peters | OpenFOAM Installation | 86 | April 27, 2012 05:32 |
Problem? with Installation of OpenFOAM 2.1.0 on to Ubuntu 10.4.4 VirtualBox | Stubby | OpenFOAM Installation | 8 | March 5, 2012 15:12 |
OpenFOAM Installation | Meisam | OpenFOAM Installation | 6 | January 31, 2012 15:43 |
Compiling OpenFOAM 1.7.1 on Ubuntu 10.10 | samiam1000 | OpenFOAM Installation | 4 | November 24, 2010 08:00 |
Some Query on Installation of OpenFoam | lzgwhy | OpenFOAM Installation | 1 | July 15, 2009 03:20 |
