-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   Problem running tutorial (http://www.cfd-online.com/Forums/openfoam-installation/109810-problem-running-tutorial.html)
vrolin November 27, 2012 07:23
I've seen this posted elsewhere, but the solutions don't seem to apply to my case.
I'm running OpenFOAM on Ubuntu in VirtualBox. I followed the instructions to install the Ubuntu Deb pack from the OpenFOAM website: http://www.openfoam.org/download/ubuntu.php
When I run icoFoam -help, I get the usage message as expected.
However I run the tutorial using the sequence
blockMesh
icoFoam
paraFoam
blockMesh and icoFoam run without error,
but paraFoam generates the error message:
OpenGL Warning: No pincher, please call crStateSetCurrentPointers() in your SPU
paraview opens and displays a grey 3D block.
Thanks so much for your help
treima November 27, 2012 07:42
have you changed the settings in Paraview, that it displays the solution? From SolidColor to one of your variables?
regards
treima
vrolin November 27, 2012 07:49
Hi Treima
I haven't changed any of the settings in Paraview,
I'm new to all of the software I'm using here and wouldn't have the first clue how.
treima November 27, 2012 08:36
Play a little bit around with the parameters in Paraview or do some online research, I think that will help you a lot.
For your special case, have a look at the description of the tutorial: http://www.openfoam.org/docs/user/cavity.php#x5-40002.1
regards
treima
vrolin November 27, 2012 11:21
Thanks again,
This helped me understand how to view results in Paraview, but when I try to look at a variable like pressure, I still only see a blank surface.
I noticed while looking at the output of icoFoam, I see a time step continuity error at several iterations.
wyldckat November 27, 2012 18:19
Greetings to all!
I'm too tired right now to go through my blog post Related issues to ParaView with OpenFOAM - Fixes and solutions
Check the links provided there and do let us know if one of them is of any help!
Good luck!
Bruno
Jaggy_Snake November 30, 2012 09:12
Is 3D acceleration turned on in your VB? I think I was getting a similar error until I disabled it... Could be wrong though
