Unsuccessful Installaton Of OpenFOAM-1.6 and Paraview in Ubuntu 10.04
Old   December 26, 2012, 12:22
Unhappy Unsuccessful Installaton Of OpenFOAM-1.6 and Paraview in Ubuntu 10.04
zandi's Avatar
Fatema Zandi Goharrizi
zandi is on a distinguished road
Hi friends
I'm new in OpenFOAM
i want to install OpenFOAM 1.6 on LINUX 10.04
but when i want test the installations' files with this command:
"$HOME/OpenFOAM/OpenFOAM-1.6/bin/foamInstallationTest"
it shows these warnings and errors in the terminal:
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.3
User version : 4.4.3
Minimum required: 4.3.1
gcc 4.4.3
WARNING: Conflicting installations:
OpenFOAM settings : /home/linux/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
gzip 1.3.12 /bin/gzip
tar 1.22 /bin/tar
icoFoam
OpenFOAM settings : /home/linux/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
Summary
Base configuration ok.
The foam installation contains 2 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
any helps would be appreciated.
please help me it is urgent.
thank you
zandi is offline   Reply With Quote
Old   December 26, 2012, 13:34
Nima Samkhaniani
nimasam is on a distinguished road
do you mean OpenFOAM.1.6-ext, because OpenFOAM.1.6 is some how an old version, i recommend you to install latest version from here (http://www.openfoam.org/download/)
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   December 26, 2012, 14:08
Question
zandi's Avatar
Thank you very much Mr Sam. you ment this old openfoal can't be installed on this version of linux at all?
Old   December 26, 2012, 15:57
Nima Samkhaniani
if you insist to install this version no matter why, then i feel you may want to try binary installation
Old   December 26, 2012, 17:30
Talking
zandi's Avatar
thank you i have installed 2.0.1 at last
Old   December 26, 2012, 17:57
Retired Super Moderator
Bruno Santos
Greetings to all!
@Zandi: Gcc 4.4.3 will only work if you can use OpenFOAM 1.6.x (not 1.6-ext): http://www.openfoam.org/archive/1.6/download/git.php
For installing OpenFOAM 1.6.x you can also try the Nucleation installation scripts: http://code.google.com/p/nucleation/
OpenFOAM 1.6 has to be built with Gcc 4.3.3 or greater, but only in the Gcc 4.3 series.
In Ubuntu 10.04 you can install this series with this command:
sudo apt-get install gcc-4.3 g++-4.3 cpp-4.3
Then....
... I've seen now that you have already installed OpenFOAM 2.0.1... oh well .
Best regards,
Bruno
Old   December 28, 2012, 04:41
zandi's Avatar
Thank you very much Bruno for useful reply. I would try it if is necessary in future
thank you all
linux 10.04, openfoam 1.6, openfoam error
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
OpenFOAM 1.6 and ThirdParty Software Paraview dunlopjp OpenFOAM Installation 0 February 24, 2010 11:35
Thumbs up Successful Installaton Of OpenFOAM-1.6 and Paraview in Ubuntu 9.04 AlanR OpenFOAM Installation 8 December 18, 2009 11:14
Successful Installaton Of OpenFOAM-1.6 and Paraview in Ubuntu 9.04 AlanR OpenFOAM Installation 21 September 17, 2009 11:27
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
