Home > Forums > OpenFOAM Installation
openfoam environment viarable
Old   January 23, 2013, 21:05
Default openfoam environment viarable
Jie
jiejie is on a distinguished road
Dear foamers
I have compiled the openfoam on our cluster, however the environment variable size exceeds the limit of the cluster after source /etc/bashrc. I know a lot of the variables are for installation purpose. I just wonder whether there is anyway I can unload those unnecessary ones for running the solver?
Thanks
Jie
jiejie is offline   Reply With Quote
Old   January 24, 2013, 05:55
Assistant Moderator
Bernhard Gschaider
Originally Posted by jiejie View Post
Dear foamers
That is a strange limit to set. Anyway.
As far as I remember for an OF-program to run there are only two things necessary:
- correctly set PATH and LD_LIBRARY_PATH so that the binaries are found
- two environment variables from the WM_* FOAM_* variety (I think one of them is WM_PROJECT_DIR but I'm not sure)
To find out which these variables are I'd recommend the following: open two terminals. The "clean" one in which no OF-script was called and the "tainted" one in which you source the etc/bashrc. Now in the clean one set PATH and LD_LIBRARY_PATH to the values you find in the tainted terminal with "echo $PATH". Then in the clean terminal go to a case and run an OpenFOAM-command (blockMesh for instance). The command will complain about an unset environment variable. Echo that in the clean terminal and export it in the tainted terminal. As I said: I think you have to do that twice and then OF-programs should run without problems. The four export-commands (PATH, LD_LIBRARY_PATH and the two others) should be all you need to set up a terminal for THAT OF-version and you can set them at the start of your cluster-script.
Now comes the important part: this recipe might stop working mysteriously if you don't do the following: go to the Wiki and write a short article "Howto: Set up a minimal environment for OF commands to run" (or so) so that others will profit from your insight
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Thread Tools
Trackbacks are On
OpenFOAM Foundation Releases OpenFOAMŪ Version 2.1.1 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 May 31, 2012 09:07
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 9 June 22, 2011 18:59
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
Getting OpenFOAM to coexist with an existing JAVA VM nik777 OpenFOAM Installation 5 February 22, 2007 08:21
OpenFOAM Training and Workshop Zagreb 2628Jan2006 hjasak OpenFOAM 1 February 2, 2006 22:07
