Home > Forums > OpenFOAM Installation
Error installing swak4Foam
Like Tree19Likes
Old   December 3, 2013, 09:14
Question error building swak4foam
  #61
macelee is on a distinguished road
I am building swak4foam on a cluster with OpenFOAM 2.2.0. Here is my steps:
- I load my OpenFOAM environement first, then go to $WM_PROJECT_USER_DIR directory
- I donwload https://github.com/wyldckat/swak4foa...ive/master.zip and unpack it
- I loaded Flex and Bison modules
- cd swak4foam-master/; ./Allwmake 2>&1 > make.log
My 'make.log' is attached. It contains errors like:
could not open file polyMesh.H for source file repositories/SurfacesRepository.C
then
SOURCE=repositories/SurfacesRepository.C ;  icpc -std=c++0x -Dlinux64 -DWM_DP -w
d327,654,819,1125,1476,1505,1572 -xSSE3 -O2 -no-prec-div  -DNoRepository -IMake/
linux64IccDPOpt       -I/app/materials/openfoam/2.2.0/intel-11.1/intel-4.0/Op
enFOAM-2.2.0/src/finiteVolume/lnInclude -I/app/materials/openfoam/2.2.0/intel-11
.1/intel-4.0/OpenFOAM-2.2.0/src/sampling/lnInclude -I/app/materials/openfoam/2.2
.0/intel-11.1/intel-4.0/OpenFOAM-2.2.0/src/fileFormats/lnInclude -I/app/material
s/openfoam/2.2.0/intel-11.1/intel-4.0/OpenFOAM-2.2.0/src/triSurface/lnInclude -I
/app/materials/openfoam/2.2.0/intel-11.1/intel-4.0/OpenFOAM-2.2.0/src/surfMesh/l
nInclude -I/app/materials/openfoam/2.2.0/intel-11.1/intel-4.0/OpenFOAM-2.2.0/src
/lagrangian/basic/lnInclude -I/app/materials/openfoam/2.2.0/intel-11.1/intel-4.0
/OpenFOAM-2.2.0/src/meshTools/lnInclude -IlnInclude -I. -I/app/materials/openfoa
m/2.2.0/intel-11.1/intel-4.0/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/app/materi
als/openfoam/2.2.0/intel-11.1/intel-4.0/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnIn
clude   -fPIC -c $SOURCE -o Make/linux64IccDPOpt/SurfacesRepository.o
/app/materials/openfoam/2.2.0/intel-11.1/intel-4.0/OpenFOAM-2.2.0/src/finiteVolu
me/lnInclude/fvMesh.H(50): catastrophic error: could not open source file "polyM
esh.H"
  #include "polyMesh.H"
compilation aborted for repositories/SurfacesRepository.C (code 4)
make: *** [Make/linux64IccDPOpt/SurfacesRepository.o] Error 4
Parser library did not compile OK. No sense continuing as everything else depend
s on it
Requirements for Library not satisfied. I see no sense in going on
I can verify that the missing files are actually on my system under $FOAM_SRC/OpenFOAM/lnInclude/
Can anyone help please?
macelee is offline   Reply With Quote
Old   December 3, 2013, 10:25
Assistant Moderator
Bernhard Gschaider
Originally Posted by fg118 View Post
Dear Bernhard,
Thank you very much for you reply.
I will try to download the development version and compile it later.
For the second question, once I remove the whitespaces in the expression-string, the different error appeared (see below).
That is interesting. Space shouldn't matter. My guess is that the string held a character that looks like a space but is not a real space. Or some control character. Can you post the file that reproduces this here (zip it for uploading. That way no well-meaning program can remove the offender) or even better at the OpenFOAM-extend-Mantis
Create mesh for time = 0
Time = 0
Using funkySetFieldsDict
Part: setLower
Modifying field alpha1 of type volScalarField
Putting "average(fpos().y<surf(0.)?surf(1.0):surf(0.)) " into field alpha1 at t = "0" if condition "true" is true
Keeping patches unaltered
--> FOAM FATAL ERROR:
inconsistent types: alpha1 is volScalarField while the expression evaluates to a surfaceScalarField
From function doAnExpression()
in file funkySetFields.C at line 359.
FOAM exiting
You create a surfaceScalarField. Then you take the average of it (the average of ALL the faces) which yields a homogenous field that is also a surface-field. Have a look at the reference-guide that comes with swak: you probably wanted the faceAverage-function
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   December 3, 2013, 10:29
Assistant Moderator
Bernhard Gschaider
then
esh.H"
s on it
And $FOAM_SRC/OpenFOAM/lnInclude is the same directory your compiler-call is using (-I/app/materials/openfoa
m/2.2.0/intel-11.1/intel-4.0/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude)?
No idea (and I don't have an Intel-compiler to test it)
Old   December 3, 2013, 11:17
Yes I think they are the same.
echo $FOAM_SRC
Really confused.
Old   December 3, 2013, 15:40
Assistant Moderator
Bernhard Gschaider
echo $FOAM_SRC
Really confused.
"I think" is not good enough. Copy path from the compiler output/command-line and do stuff like
ls blalaPath/polyMesh.H
to check whether the file is REALLY where it is expected
Some people have compiled swak with the Intel-compiler. So it should be feasible. Maybe one of them can assist you
Old   December 3, 2013, 16:14
Dear gschaider,
Thanks for your advice. I checked those files again. While the path is indeed correct, I found that the files in $FOAM_SRC/src/OpenFOAM/lnInclude/ are actually symbolic links pointing to files elsewhere. I then found that some of those files have incorrect permissions so that they cannot be read by a normal user on the system. So basically my OpenFOAM installation is somewhat broken. I will ask the system people to correct those file permissions first. I will report back the outcome later.
Old   December 4, 2013, 11:10
After fixing the file permission problem, my compiling can go a bit longer, until it stopped with another error, related to the Intel compiler, as discussed in this thread (swak4Foam installation on 2.0). I am not exactly clear after reading that thread: is the problem completely fixed by using a new version of Intel compiler? I am using an old cluster with OpenFOAM built with intel compiler version 11.x. But new versions 12.x and 13.x are also available.
Old   December 4, 2013, 11:50
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hello dear Bernhard,
sorry for propound this here,
but could you introduce me for some line about historty of groovyBC and the creator( I mean you!) I need these information for my thesis.I sent an email to you too
before.thanks.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   December 4, 2013, 12:27
Assistant Moderator
Bernhard Gschaider
Don't know
a) I don't have an Intel-compiler
b) didn't want to read through all 50 Postings in the thread to find out which one you meant. Hint: for linking to a specific posting use the #23 link that every posting has
Old   December 4, 2013, 16:26
Don't know
Sorry about that, I did not notice the permlinks associated with individual posts. I was referring to this post (swak4Foam installation on 2.0) which was posted several months after the initial post in that thread. It seems to imply that a newer version of Intel compiler does not suffer from the problem.
Old   December 4, 2013, 17:38
Default Error in installation
  #71
weezer579 is on a distinguished road
Hi Bernhard,
Thank you very much for your help in this post. I am trying to compile swak4foam but running into a little problem of one of the files in Gcc46 folder not found. I did check the source and the file was there, so I am really not sure what went wrong. Attached below is the log of my compilation. Could you please take a look? Thank you very much for your help.
No 'swakConfiguration'. Python etc won't work
Checking swak4Foam-version and generating file
Bison is version 2.7.12-4996
Flex is version 2.5.37 (Minor version: 37)
OpenFOAM-version: Major 2 Minor 2 Patch 0 (-1 == x)
No change to swak4FoamParsers/foamVersion4swak.H
SOURCE=helpers/printSwakVersion.C ; g++ -m64 -fsignaling-nans -ftrapping-math -DdarwinIntel64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O2 -DNoRepository -ftemplate-depth-100 -IMake/darwinIntel64GccDPOpt -I/Users/Ninja/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/Users/Ninja/OpenFOAM/OpenFOAM-2.2.0/src/sampling/lnInclude -I/Users/Ninja/OpenFOAM/OpenFOAM-2.2.0/src/fileFormats/lnInclude -I/Users/Ninja/OpenFOAM/OpenFOAM-2.2.0/src/triSurface/lnInclude -I/Users/Ninja/OpenFOAM/OpenFOAM-2.2.0/src/surfMesh/lnInclude -I/Users/Ninja/OpenFOAM/OpenFOAM-2.2.0/src/lagrangian/basic/lnInclude -I/Users/Ninja/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -IlnInclude -I. -I/Users/Unimax/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/Users/Unimax/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64GccDPOpt/printSwakVersion.o
In file included from /opt/local/lib/gcc46/gcc/x86_64-apple-darwin12/4.6.4/include-fixed/syslimits.h:7:0,
from /opt/local/lib/gcc46/gcc/x86_64-apple-darwin12/4.6.4/include-fixed/limits.h:34,
from /opt/local/include/gcc46/c++/climits:43,
from /Users/Unimax/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/label.H:38,
from /Users/Unimax/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/labelList.H:47,
from /Users/Unimax/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/UPstream.H:43,
from /Users/Unimax/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude/Pstream.H:42,
from helpers/printSwakVersion.H:43,
from helpers/printSwakVersion.C:43:
/opt/local/lib/gcc46/gcc/x86_64-apple-darwin12/4.6.4/include-fixed/limits.h:169:61: fatal error: limits.h: No such file or directory
compilation terminated.
make: *** [Make/darwinIntel64GccDPOpt/printSwakVersion.o] Error 1
Parser library did not compile OK. No sense continuing as everything else depends on it
weezer579 is offline   Reply With Quote
Old   December 4, 2013, 18:56
Assistant Moderator
Bernhard Gschaider
I can't exactly say. It seems at THAT time THAT version of swak compiled with THAT Intel-compiler. Of course new stuff was added to swak and it is possible that the new sources reintroduced the problem (would be helpful to know which sources cause problems for you)
Old   December 4, 2013, 19:17
Assistant Moderator
Bernhard Gschaider
before.thanks.
I've always got to look myself for "when did groovyBC start" etc. Best guess is to look at the History-tab of http://openfoamwiki.net/index.php/Contrib/groovyBC
There are no proper papers on it (I'm not in academia so I don't have to write a paper on EVERYTHING I do). People in the past when referencing it either referred to the Wiki-page (this is the 21st century. URLs can be used as references. They might change, I'm aware of that) or one of the presentations listed on the swak-page.
Reason why I wrote groovyBC was that before that I had written a utility to set a parabolic inlet condition. People were asking questions on that ("How do I use it for a different orientation") and I figured "with that thing people don't have to write C++ so they'll ask less questions". Turned out that I was wrong (that is the interesting part on the history of groovyBC as far as I'm concerned)
immortality likes this.
Old   December 4, 2013, 19:24
Assistant Moderator
Bernhard Gschaider
Originally Posted by weezer579 View Post
Hi Bernhard,
Don't know. For me it is there and works.
Are you one of these people who already updated to Mavericks (which I believe is darwin13). MacPorts recommends reinstalling the whole MacPorts-tree after a OS-Upgrade like this (my theory: you installed gcc46 on 10.8, upgraded to 10.9 now gcc46 doesn't know where to find stuff). Even if I'm wrong: try uninstalling gcc46 and reinstalling it
Old   December 5, 2013, 05:17
Feng
fg118 is on a distinguished road
Thank you very much for your help! I do need faceAverage function. Once I change to it, the program run smoothly.
By the way, after I installed the development version of swak4Foam, the space problem disappeared.
fg118 is offline   Reply With Quote
Old   December 5, 2013, 06:24
Assistant Moderator
Bernhard Gschaider
Sorry for the naming conflict. But
a) there is documentation
b) more people need the "other" average. So I decided to name this function differently than the OF-convention
About the space: strange. Don't remember fixing that
Old   December 5, 2013, 11:16
Ehsan
thank you a lot.I added the interesting start to my thesis. you certainly have helped many people to get their degrees so far like me thank you a lot
Old   December 6, 2013, 22:16
Hi Bernhard,
The problem was exactly what you pointed out. I've reinstalled everything and it can compile smoothly now. Thank you very much for your help.
Old   December 7, 2013, 07:30
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
OK. That is valuable information for me: wait with the Mavericks-update until I have a couple of days where it doesn't matter that MacPorts rebuilds itself
Old   December 8, 2013, 10:05
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings to all!
I guess I'm too late for the party.
But I'd like to point out an important detail - @macelee: you should have downloaded from the OF22X branch, not the master branch, as explained here: Swak4FOAM 0.2.3 / OF2.2.x installation error post #8
Best regards,
Bruno
compile error, swak4foam
Thread Tools
Trackbacks are On
swak4Foam for calculating velocity transformations santoshgoku OpenFOAM 5 April 19, 2016 12:57
swak4foam newbie29 OpenFOAM Installation 82 July 18, 2015 17:16
groovyBC and funkySetFields married and got a kid named swak4Foam gschaider OpenFOAM 164 January 13, 2015 03:52
Installing swak4Foam to OpenFOAM in mac Kaquesang OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 22 January 21, 2013 12:51
About installation of swak4Foam mmkr825 OpenFOAM Programming & Development 10 December 14, 2012 02:24
