To install OF-1.7.x on Scientific Linux
Old   March 1, 2013, 07:41
Default To install OF-1.7.x on Scientific Linux
Gitesh
Gitesh P is on a distinguished road
Can anyone suggest me how to install OF-1.7.x on Scientific Linux 6.3 (It's based on Red Hat Enterprise Linux) ?
Thank you in advanced!
With regards,
GP
Gitesh P is offline   Reply With Quote
Old   March 2, 2013, 10:13
Retired Super Moderator
Bruno Santos
Greetings Gitesh,
Does it have to be OpenFOAM 1.7.x?
Anyway, currently I'm not aware of any set of instructions that explain how to install 1.7.x on SL 6.3, but I'm guessing that you can do the following:
  1. Do step #1 from here: http://openfoamwiki.net/index.php/In...HEL#CentOS_6.3
  2. Then follow these instructions: http://www.openfoam.org/archive/1.7.1/download/git.php
  3. When it comes to building ParaView, don't. Instead, add the EPEL repositories and install the ParaView version that is supplied in that repository.
  4. Then edit the file "$WM_PROJECT_DIR/bin/paraFoam" and replace the file extensions ".OpenFOAM" to ".foam" and save.
Best regards,
Bruno
Old   March 4, 2013, 03:37
Gitesh
Hello Bruno,
Thank you for your help.
I am not getting exactly what are the last two steps (3rd and 4th one) suggest by you ?
With regards,
GP
Old   March 4, 2013, 17:21
Bruno Santos
Hi Gitesh,
On #3, instead of building the ParaView version that comes with OpenFOAM's "ThirdParty-1.7.1" package, I advise you to install the latest ParaView version that is provided in the EPEL repositories: http://fedoraproject.org/wiki/EPEL
On #4, the idea is that for using the ParaView version that is installed from the EPEL repository, you'll need to do some small changes to the file "bin/paraFoam" that should be located in the folder "OpenFOAM-1.7.x". The full path should be revealed if after you build OpenFOAM 1.7.x, you run:
echo $WM_PROJECT_DIR/bin/paraFoam
Best regards,
Bruno
Installation Problem with ParaView 3.12.0 on Scientific Linux 5.7 Wley OpenFOAM Installation 2 September 28, 2012 06:06
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 16:49
My experience Installing Elmer (Open Source Multi physics programme) on Linux Ahmed Main CFD Forum 3 August 10, 2010 13:42
How to install linux? gholamghar Main CFD Forum 3 July 22, 2010 10:40
Install Fluent in Linux L3munoz FLUENT 0 July 21, 2009 14:55
