[swak4Foam] what this sentence in groovyBC compiling mean?
Old   February 17, 2013, 05:42
Default what this sentence in groovyBC compiling mean?
immortality's Avatar
Ehsan
immortality is on a distinguished road
is this message an error?
No 'swakConfiguration'. Python etc won't work
immortality is offline   Reply With Quote
Old   February 17, 2013, 05:49
Ehsan
and also these:
lex.fvexpr.c:60969:22: warning: use of old-style cast [-Wold-style-cast]
lex.parserSubset.c:10227:57: warning: use of old-style cast [-Wold-style-cast]
[CODElex.parserSubset.c:11798:16: warning: ‘int yy_top_state(yyscan_t)’ defined but not used [-Wunused-function]
][/CODE]
and also:
position.hh:136:69: warning: suggest parentheses around ‘&&’ within ‘||’ [-Wparentheses]
and many of these sentences:
Making dependency list for source file swakExplicitSources.C
could not open file FixedValuePointPatchField.H for source file swakExplicitSources.C
could not open file ZeroGradientPointPatchField.H for source file swakExplicitSources.C
could not open file CalculatedPointPatchField.H for source file swakExplicitSources.C
why it cant open these and many other headers?whats the problem?is compilation ok despite of these messages?
Old   February 17, 2013, 06:08
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
No.
(The message board needs to have at least 10 characters so I'll add an aside: I don't want to imagine the amount of questions you'll ask once you start with Python)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   February 17, 2013, 06:12
Assistant Moderator
Bernhard Gschaider
and also these:
][/CODE]
and also:
I said it elsewhere: the warnings are ONLY warnings (in computer generated code. So there is not much that can be done about it)
"Could not open file" is an artefact of the utility that determines the dependenies of the source files. It is completely irrelevant
Old   February 17, 2013, 06:58
Ehsan
allright.then these are not any problems and compilation is ok?
[swak4Foam] is this pattern and message of compiling groovyBC 0.2.1 ok? immortality OpenFOAM Community Contributions 3 May 13, 2013 10:15
[swak4Foam] some errors in compiling groovyBC in OF220 immortality OpenFOAM Community Contributions 10 April 1, 2013 03:46
[swak4Foam] is this expression as bolean sentence wrong in groovyBC? immortality OpenFOAM Community Contributions 6 March 8, 2013 05:24
[swak4Foam] problem in compiling groovyBC in OpenFoam 1.71 javad814 OpenFOAM Community Contributions 4 July 31, 2011 04:33
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
