[Sponsors] | |||||
Sudhakar Dayal
Rep Power: 2 ![]() |
Has anyone installed OpenFOAM on Fedora 18. I am getting ERROR message: libmpi.so.1: cannot open object file: No such file or directory. :-(
Bruno Santos
Rep Power: 45 ![]() ![]() |
Greetings Suhdakar and welcome to the forum!
You didn't mention which installation instructions you've followed. Have you tried these? http://openfoamwiki.net/index.php/In...M-2.1.1/Fedora Best regards, Bruno
Sudhakar Dayal
Thanks a lot. I had a jolly good OpenFOAM working in Fedora 17. The I decided to switch over on Fedora 18. During re-load it did not work ! :-( Now instead of x86_64 versions of RPM files I have i-686 versions of every thing. OpenFOAM is OK with x86_64 but to my guess not with Fedora - 18, i-686 kinf of stuff.
Sudhakar Dayal
I am facing the same issue, with Fedora 18. It says unable to open modulefile for openmpi-i686. ... and mpicc command not found. :-(
#6 | |
Bruno Santos
module load mpi/openmpi-i386
Tomas
Rep Power: 3 ![]() |
Hi guys I have a little problem with final installation of OpenFoam on my Fedora 18. I'm doing all fallow the instruction on http://www.openfoam.org/download/fedora.php
Could anyone show me how to "bashrc" file should looks like after final configuration?. It's main: # Source global definitions if [ -f /etc/bashrc ]; then . /etc/bashrc fi # User specific aliases and functions module load openmpi-x86_64 source /opt/OpenFOAM-2.2.0/etc/bashrc correct? and error in my terminal: [jed@localhost ~]$ icoFoam -help icoFoam: error while loading shared libraries: libmpi.so.1: cannot open shared object file: No such file or directory Thanks so much for any help |
#9 |
Bruno Santos
Greetings to all!
I believe the correct command for Fedora 18 is: Code:
module load mpi/openmpi-x86_64 ![]() @Laurence: Sorry, I haven't managed to report this on bug tracker yet... I've been meaning to do go through the list of Linux Distributions that are at openfoamwiki.net (namely here) and test installing OpenFOAM 2.2 with them all, but I haven't found the time to do it. Hence not having confirmed it and reported it yet. Best regards, Bruno
#10 |
Laurence R. McGlashan
Rep Power: 12 ![]() |
Ok fair enough. I'll double check on my 18 installation at the weekend.
The 'module load' command should fail if the modulefile doesn't exist though, and that's why I asked.
Laurence R. McGlashan :: Website |
#11 |
Tomas
hi l_r_mcglashan
My ansfer: [jed@localhost ~]$ module available ------------------------ /usr/share/Modules/modulefiles ------------------------ dot module-git module-info modules null use.own ------------------------------- /etc/modulefiles ------------------------------- mpi/openmpi-x86_64 [jed@localhost ~]$ module list No Modulefiles Currently Loaded. |
#12 |
What does this give:
module load openmpi-x86_64 You need to do: module load mpi/openmpi-x86_64 Can I also ask if your fedora 18 installation is new, or an upgrade from 17?
#13 |
Tomas
It's fresh instalation of Fedora 18.
When i try to load the module, no reaction: [jed@localhost ~]$ module load mpi/openmpi-x86_64 [jed@localhost ~]$ So, could you paste the correct bashrc file in my case?. And I'm sorry, I'm completly new in Linux. Thx |
#15 |
Tomas
Thank you so much. Everything's working
#17 |
Tomas
sure, now my bashrc file looks like this:
# Source global definitions if [ -f /etc/bashrc ]; then . /etc/bashrc fi # User specific aliases and functions module load mpi/openmpi-x86_64 source /opt/OpenFOAM-2.2.0/etc/bashrc |
#18 | |
Bruno Santos
Greetings to all,
@Tomas: That looks perfect! By the way, it's natural that "module load" doesn't show anything when things work as intended It's when it says something that we have to worry ![]() @Laurence: I've done some tests with the virtual machines that I already had from my past installations of OpenFOAM 2.1.1 with Fedora 17 and 18 (both were clean installations). Here are my findings:
I've made a quick search and the following page popped up when looking for "Fedora mpi/openmpi": http://fedoraproject.org/wiki/Packaging:MPI Quote:
A bit more searching and I found the associated ticket for this: https://fedorahosted.org/fpc/ticket/229 Best regards, Bruno
| Tags |
| fedora 18, installing openfoam |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| OpenFOAM 1.7 installation on Redhat linux | maxims | OpenFOAM Installation | 2 | November 30, 2012 04:29 |
| OpenFoam 2.0.0 installation | Jan_Peters | OpenFOAM Installation | 86 | April 27, 2012 05:32 |
| OpenFoam 2.0.1 installation | shailesh.nitk | OpenFOAM Installation | 4 | October 4, 2011 08:50 |
| OpenFOAM 2.0.1-foamInstallationTest Failed on Fedora 15 x64 | Winston Wu | OpenFOAM | 5 | August 16, 2011 07:24 |
| OpenFOAM Installation | rclprice | OpenFOAM Installation | 1 | July 21, 2011 16:31 |
