Home > Forums > OpenFOAM Installation
Install Optional Packages from Ubuntu 12.10 Repositories
Like Tree1Likes
  • 1 Post By atg
Old   March 9, 2013, 17:48
Default Install Optional Packages from Ubuntu 12.10 Repositories
Matthew Denno
mgdenno is on a distinguished road
Hi All,
I am wondering if installing the optional gmp, mpfr, mpc, cgal and boost from the repositories instead of from source works for OpenFOAM? The current versions are:
libgmp-dev (2:5.0.2+dfsg-2ubuntu1 Ubuntu:12.04/precise [amd64])
libmpfr-dev (3.1.0-3ubuntu2 Ubuntu:12.04/precise [amd64])
libboost1.46-dev (1.46.1-7ubuntu3 Ubuntu:12.04/precise [amd64])
libcgal8 (3.9-1build1 Ubuntu:12.04/precise [amd64])
Looks like maybe some values in settings.sh might need to be adjusted? But I have never ventured this far beyond the standard install procedure.
Edit: It is easy enough to just try to install this packages and compile, but how can I tell it it worked when it compiles without them to begin with?
MD
mgdenno is offline   Reply With Quote
Old   March 9, 2013, 19:31
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings Matthew,
According to Bernhard:
Originally Posted by gschaider View Post
- boost and cgal (these are optional. If found they will be used for surfaceExtractFeatures).
As for GMP, MPFR and MPC, these are usually only necessary for building GCC.
Best regards,
Bruno
Old   March 10, 2013, 13:51
Matthew Denno
Bruno,
Thanks for your input. That post by Bernhard was what got me thinking about CGAL and OpenFOAM. I have worked with the CGAL libraries for a different project and was interested about using them with OF.
I installed CGAL from the repositories, but it says that it is compiling without CGAL curvature support, but does include a line "-ICGALPolyhedron"
From my make.log:
+ [ -n  ]
+ echo
+ echo Compiling surfaceFeatureExtract without CGAL curvature support
+ echo
+ wmake
make[2]: Entering directory `/home/matt/OpenFOAM/OpenFOAM-2.2.0/applications/utilities/surface/surfaceFeatureExtract'
Making dependency list for source file surfaceFeatureExtract.C
make[2]: Leaving directory `/home/matt/OpenFOAM/OpenFOAM-2.2.0/applications/utilities/surface/surfaceFeatureExtract'
SOURCE=surfaceFeatureExtract.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100    -Wno-old-style-cast -I/include -I/include -I/include -I/include -ICGALPolyhedron -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/edgeMesh/lnInclude -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/triSurface/lnInclude -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/surfMesh/lnInclude -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/sampling/lnInclude -IlnInclude -I. -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/surfaceFeatureExtract.o
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100    -Wno-old-style-cast -I/include -I/include -I/include -I/include -ICGALPolyhedron -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/meshTools/lnInclude -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/edgeMesh/lnInclude -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/triSurface/lnInclude -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/surfMesh/lnInclude -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/sampling/lnInclude -IlnInclude -I. -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/matt/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/surfaceFeatureExtract.o -L/home/matt/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \
             -L/lib -L/lib -L/lib       -lmeshTools -ledgeMesh -ltriSurface -lsampling -lOpenFOAM -ldl   -lm -o /home/matt/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/bin/surfaceFeatureExtract
I am wondering if I need to change my etc/config/settings.sh file to reflect the correct versions of boost and CGAL. Looks like I have CGAL 3.9 and Boost 1.46.1 from the repos. I found this with grep but don't fully understand how it all works.
# boost and CGAL
boost_version=boost_1_45_0
cgal_version=CGAL-4.0
export BOOST_ARCH_PATH=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER/$boost_version
export CGAL_ARCH_PATH=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER/$cgal_version
# enabled if CGAL is available
if [ "$FOAM_VERBOSE" -a "$PS1" ]
then
    echo "Checking for"
    echo "    $cgal_version at $CGAL_ARCH_PATH"
    echo "    $boost_version at $BOOST_ARCH_PATH"
fi
if [ -d "$CGAL_ARCH_PATH" ]
then
    if [ -d "$BOOST_ARCH_PATH" ]
    then
        _foamAddLib $BOOST_ARCH_PATH/lib
    else
        unset BOOST_ARCH_PATH
    fi
    _foamAddLib $CGAL_ARCH_PATH/lib
else
    unset BOOST_ARCH_PATH CGAL_ARCH_PATH MPFR_ARCH_PATH GMP_ARCH_PATH
fi
unset boost_version cgal_version
Old   March 10, 2013, 14:31
Bruno Santos
Hi Matthew,
I haven't tried this yet, but the following massive hack will probably be necessary (or similar):
export BOOST_ARCH_PATH=/usr/include/boost
export CGAL_ARCH_PATH=/usr/include/CGAL
#this one probably won't be needed
_foamAddLib /usr/lib
You can either replace the other bunch of code, or simply place these lines after the last "unset" line.
Wait... this is only the tip of the iceberg
You also need to hack the following files:
And you should confirm that "lapack" and "blas" are also installed!
Best regards,
Bruno
Old   March 11, 2013, 13:59
Matthew Denno
Thanks Bruno,
I made the changes that you suggested and it seems to have compiled without errors but I haven't tried to use it yet. I will try this evening and report back.
MD
Old   April 22, 2014, 22:19
atg
Karl
atg is on a distinguished road
--edit--
Well, I have to temper my enthusiasm. It attempted to compile, and reported that it found all the libraries, but when the time came to build surfaceFeatureExtract, it appears to have failed with the following error (see below). Something about the wrong number of arguments and a missing "initializer". So it looks like the "Monge" related variables are missing (I have no idea what they are or if they are necessary to get SurfaceFeatureExtract to work, so I need to do some homework). Maybe I need a different version of CGAL?
make[2]: `/home/karl/OpenFOAM/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/bin/surfaceToPatch' is up to date.
surfaceFeatureExtract.C: In function ‘Foam::scalarField calcCurvature(const Foam::triSurface&)’:
surfaceFeatureExtract.C:85:47: error: wrong number of template arguments (1, should be 3)
/usr/local/include/CGAL/Monge_via_jet_fitting.h:56:9: error: provided for ‘template<class DataKernel, class LocalKernel, class SvdTraits> class CGAL::Monge_via_jet_fitting’
surfaceFeatureExtract.C:85:78: error: invalid type in declaration before ‘;’ token
surfaceFeatureExtract.C:86:57: error: expected initializer before ‘Monge_form’
make[2]: `/home/karl/OpenFOAM/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/bin/surfaceTransformPoints' is up to date.
surfaceFeatureExtract.C:148:9: error: ‘Monge_form’ was not declared in this scope
surfaceFeatureExtract.C:148:20: error: expected ‘;’ before ‘monge_form’
surfaceFeatureExtract.C:164:21: error: ‘monge_form’ was not declared in this scope
surfaceFeatureExtract.C:146:31: warning: unused variable ‘monge_fit’ [-Wunused-variable]
surfaceFeatureExtract.C:92:18: warning: unused variable ‘d_monge’ [-Wunused-variable]
make[2]: *** [Make/linux64GccDPOpt/surfaceFeatureExtract.o] Error 1
make[2]: Target `/home/karl/OpenFOAM/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/bin/surfaceFeatureExtract' not remade because of errors.
make[1]: *** [surfaceFeatureExtract] Error 2
make[1]: Target `application' not remade because of errors.
make: *** [surface] Error 2
make: Target `application' not remade because of errors.
This is the part where it finds the libraries, which seems to have worked:
make[3]: `/home/karl/OpenFOAM/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/bin/createPatch' is up to date.
+ [ -n /usr/include/CGAL ]
+ echo
+ echo Compiling surfaceFeatureExtract with CGAL curvature support
+ echo
+ wmake ENABLE_CURVATURE=-DENABLE_CURVATURE            EXE_FROUNDING_MATH=-frounding-math            USE_F2C=-DCGAL_USE_F2C            CGAL_LIBDIR=-L/usr/lib            LAPACK_LIB=-llapack            BLAS_LIB=-lblas            CGAL_LIB=-lCGAL            CGAL_BOOST_LIB=-lboost_thread            CGAL_MPFR_LIB=-lmpfr
Originally Posted by wyldckat View Post
Hi Matthew,
Best regards,
Bruno
atg is offline   Reply With Quote
Old   April 25, 2014, 14:51
Bruno Santos
Greetings Karl,
Any chance you can switch to OpenFOAM 2.3.0 or 2.3.x instead? Because OpenFOAM 2.3 is better connected to CGAL and Boost.
If not, I'll need more information, namely which CGAL version you're using and which Ubuntu version.
And those paths "/usr/local/include/" seem to indicate that you're using a custom build of CGAL?
Best regards,
Bruno
Old   April 25, 2014, 15:08
atg
Karl
Well the goal is to keep using helyxos which only works with 2.2 apparently.
I was able to downgrade cgal to 4.1 and build surfacefearureextract correctly with cgal support.
Yes installed cgal in ubuntu 12.04 and pointed openfoam build to the system cgal directories. You actually posted the method for that above.
Unfortunately I have another problem with open mpi at the moment that I will post about separately.
Thank you for your response.
Regards,
Karl
Greetings Karl,
Best regards,
Bruno
wyldckat likes this.
Thread Tools
Trackbacks are On
Openfoam Ubuntu 12.04 Unmet dependencies slls33 OpenFOAM Installation 10 April 9, 2013 04:16
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 wyldckat OpenFOAM Installation 14 February 12, 2013 05:43
errors when installing openfoam2.1 on ubuntu12.o4 hewei OpenFOAM Installation 5 May 29, 2012 07:43
Problem? with Installation of OpenFOAM 2.1.0 on to Ubuntu 10.4.4 VirtualBox Stubby OpenFOAM Installation 8 March 5, 2012 16:12
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 15:43
