OpenFOAM 2.2.0 installation on scientific-linux
I got this error while installing OF 2.2.0 on scintific Linux (cluster)
Kindly help readSolidDisplacementFoamControls.H: In function ‘int main(int, char**)’: readSolidDisplacementFoamControls.H:3: warning: unused variable ‘nCorr’ readSolidDisplacementFoamControls.H:5: warning: unused variable ‘convergenceTolerance’ g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -ItractionDisplacement/lnInclude -IlnInclude -I. -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/tractionDisplacementFvPatchVectorField.o Make/linux64GccDPOpt/solidDisplacementFoam.o -L/home/deepak/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \ -lfiniteVolume -lOpenFOAM -ldl -lm -o /home/deepak/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/bin/solidDisplacementFoam /usr/bin/ld: cannot find -lfiniteVolume collect2: ld returned 1 exit status make[2]: *** [/home/deepak/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/bin/solidDisplacementFoam] Error 1 make[2]: Leaving directory `/home/deepak/OpenFOAM/OpenFOAM-2.2.0/applications/solvers/stressAnalysis/solidDisplacementFoam' make[1]: *** [solidDisplacementFoam] Error 2 make[2]: Entering directory `/home/deepak/OpenFOAM/OpenFOAM-2.2.0/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam' Making dependency list for source file tractionDisplacementCorrection/tractionDisplacementCorrectionFvPatchVectorField.C Making dependency list for source file solidEquilibriumDisplacementFoam.C make[2]: Leaving directory `/home/deepak/OpenFOAM/OpenFOAM-2.2.0/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam' make[2]: Entering directory `/home/deepak/OpenFOAM/OpenFOAM-2.2.0/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam' SOURCE=tractionDisplacementCorrection/tractionDisplacementCorrectionFvPatchVectorField.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -ItractionDisplacementCorrectionStress -I../solidDisplacementFoam -IlnInclude -I. -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/tractionDisplacementCorrectionFvPatchVectorField.o SOURCE=solidEquilibriumDisplacementFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -ItractionDisplacementCorrectionStress -I../solidDisplacementFoam -IlnInclude -I. -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/solidEquilibriumDisplacementFoam.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -ItractionDisplacementCorrectionStress -I../solidDisplacementFoam -IlnInclude -I. -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/deepak/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/tractionDisplacementCorrectionFvPatchVectorField.o Make/linux64GccDPOpt/solidEquilibriumDisplacementFoam.o -L/home/deepak/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib \ -lfiniteVolume -lOpenFOAM -ldl -lm -o /home/deepak/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/bin/solidEquilibriumDisplacementFoam /usr/bin/ld: cannot find -lfiniteVolume collect2: ld returned 1 exit status make[2]: *** [/home/deepak/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/bin/solidEquilibriumDisplacementFoam] Error 1 make[2]: Leaving directory `/home/deepak/OpenFOAM/OpenFOAM-2.2.0/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam' make[1]: *** [solidEquilibriumDisplacementFoam] Error 2 make[1]: Target `application' not remade because of errors. make[1]: Leaving directory `/home/deepak/OpenFOAM/OpenFOAM-2.2.0/applications/solvers/stressAnalysis' make: *** [stressAnalysis] Error 2 make: Target `application' not remade because of errors. |
Hi
You need to break the compilation just after the first error or output to a log file so its possible to scroll back to the first error. Code:
./Allwmake > make.log 2>&1 http://sourceforge.net/projects/centfoam/ |
