[swak4Foam] About GroovyBC
Like Tree1Likes
  • 1 Post By gschaider
Old   March 19, 2013, 01:42
Default About GroovyBC
M Mallikarjuna Reddy
mmkr825 is on a distinguished road
Hi Foamers,
I am using OpenFOAM2.1.1 version. My solver is steady state and i prepared it by modifying "simpleFoam" solver. I am facing problem with boundary condition for the scalar field (lets say T).
The governing equation for the field T as follows:
solve ( fvm::div(phi, T) + fvc::div(J) );
At the fixed Walls i need to apply zero flux boundary condition. In the above equation "J" is the flux. So i need to apply J.n=0 at fixed walls. I have little experienced in handling "groovyBC".
Can anyone help me how to write this expression. Thanks in advance.
Regards
mmkr825 is offline   Reply With Quote
Old   March 19, 2013, 05:04
Assistant Moderator
Bernhard Gschaider
Originally Posted by mmkr825 View Post
Hi Foamers,
Regards
And J is related to T how?
Assuming that J is a surface field then fvc::div(J) only uses the values on the boundary patches (the situation is not better if J is a volume-field).
Anyway: if you're not doing completely different physics to somebody else then J is somehow related to grad(T) which makes the second term boil down to something like laplacian(lambda,T) for which you can use the fvm-form which makes everything much more stable.
If J is completely unrelated to T then only the actual value of div(J) in the cells matters for the solution of the T-equation and if J is a vector and J=(0,0,0) is not good enough for you then a slip-boundary condition is sufficient
mmkr825 likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 19, 2013, 06:57
Dear gschaider,
Thanks for the quick response. In my case i defined J as volume field:
volVectorField J
        IOobject
            "J",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        -f1*fvc::div(Epnn1)+fvc::laplacian(f2, U)
Where Epnn1 is defined as:
volTensorField Epnn1
IOobject
"Epnn1",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
f3*Q
Where f1,f2 and f3 are functions of T and Q is a tensor. I defined Q as:
dimensionedTensor Q
"Q",
dimensionSet(0, 0, 0, 0, 0, 0, 0),
tensor(1,0,0,0,0.58,0,0,0,0.38)
As you noticed if J is function of grad(T), then my problem could be easy. But in my case i don't have any explicit expression for J in-terms of grad(T). Could you please elaborate the method in which I can use a slip boundary condition for my case by using groovyBC?
Moreover i am struggling with divergence problem. From your valuable suggestion I understood that there is divergence in my case since J is defined as a volume field. Should I define J at the surface field to achieve convergence?
Thanks
Reddy
Old   March 19, 2013, 08:00
Assistant Moderator
Bernhard Gschaider
Dear gschaider,
volVectorField J
        IOobject
            "J",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
Thanks
Reddy
slip has nothing to do with groovyBC. It is a standard-BC in OpenFOAM. Anyway: to set special boundary conditions for a field it is better to read that field from disc. Everything else is horrible to program.
For convergence: i can only be general here: you mentioned that the functions fX depend on T: the best strategy would be to identify the parts that depend on T, linearize them, put these parts implicitly into the T-equation using fvm-operations and only put the rest of the terms into the explicit source. Also sit down with pen and paper and see if the BC for J can be expressed in terms of T on the boundary. Then implement that BC for T. If you insist on having an all-explicit source term the way you do now you may need veeeery small time-steps (probably)
Yeah: if you know what you're doing a surfaceScalar-field for the flux is better than a volVector-field (see creation and usage of phi in the regular solvers)
Old   March 20, 2013, 05:55
Dear gschaider
Thanks for your reply. I'll go through your suggestion and let you know if i succeed.
Thanks
Regards
Mallikarjuna Reddy
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 07:16
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 08:49
