OpenFOAM-2.2.x failed to compile on OpenSUSE 12.3
Dear OpenFOAMers,
I am wondering if anyone has compiled OpenFOAM-2.2.x successfully on OpenSUSE 12.3 64 bit? I got the following errors. It will be appreciated if someone can shed some light on this. Thanks! Pei-Ying -------------------------------- make[1]: Leaving directory `/home/phsieh/OpenFOAM/ThirdParty-2.2.x/scotch_6.0.0/src/check' rm -f ../bin/* ../include/* ../lib/* ======================================== Build Tecio optional component was not found ======================================== Done ThirdParty Allwmake ======================================== + wmakePrintBuild -check same version as previous build + wmakeLnInclude OpenFOAM wmakeLnInclude: linking include files to OpenFOAM/lnInclude + wmakeLnInclude OSspecific/POSIX wmakeLnInclude: linking include files to OSspecific/POSIX/lnInclude + Pstream/Allwmake + wmake libso dummy wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file UPstream.C Making dependency list for source file UIPread.C Making dependency list for source file UOPwrite.C SOURCE=UPstream.C ; wmakeScheduler g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.2.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc46DPOpt/UPstream.o SOURCE=UIPread.C ; wmakeScheduler g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.2.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc46DPOpt/UIPread.o SOURCE=UOPwrite.C ; wmakeScheduler g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.2.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc46DPOpt/UOPwrite.o ssh: connect to host jali port 22: No route to host make: *** [Make/linux64Gcc46DPOpt/UIPread.o] Error 255 make: *** Waiting for unfinished jobs.... ^C ---------------------------- |
Greetings Pei-Ying,
The only error I can see is: Quote:
ssh jali & As for: Quote:
Best regards, Bruno |
Hi, Bruno,
Thanks for the reply! You have been very kind to offer help, as always. I have been fooling around the ssh stuffs in opensuse 12.3, but, no luck. Both openFoam-2.1.x and 2.2.x compiled successfully on opensuse 12.2. But, both failed on opensuse 12.3 with the same issue. There is something different between opensuse 12.2 and 12.3. Pei-Ying |
Hi Pei-Ying,
I think I now understand what's going on! You're using "wmakeScheduler"! I suggest that instead of using something like this: Code:
export WM_SCHEDULER=wmakeScheduler Code:
export WM_NCOMPPROCS=4 ______ In the mean time, try to diagnose if ssh works locally: Code:
ssh localhost Code:
ping jali Best regards, Bruno |
Thanks a lot Bruno!
You are an angel. You were correct. WM_SCHEDULER is the cause of the issue. Pei-Ying |
