[Sponsors] | |||||
Rep Power: 2 ![]() |
Can you help me.
Affter I installed OpenFOAM and run paraView result follow: hon@hon-ubuntu:~/OpenFOAM/hon-2.1.0/run/tutorials/incompressible/icoFoam/cavity$ paraFoam created temporary 'cavity.OpenFOAM' void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Main Controls" under id 64 void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Selection Controls" under id 65 void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "VCR Controls" under id 66 void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Current Time Controls" under id 67 void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Active Variable Controls" under id 68 void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Representation Toolbar" under id 69 void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Camera Controls" under id 70 void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Center Axes Controls" under id 71 void DBusMenuExporterPrivate::addAction(QAction*, int): Already tracking action "Macros Toolbars" under id 72 When i closed terminal and return open terminal, run OpenFOAM result follow: hon@hon-ubuntu:~$ cd OpenFOAM/hon-2.1.0/run/tutorials/ basic/ DNS/ incompressible/ resources/ combustion/ electromagnetics/ lagrangian/ stressAnalysis/ compressible/ financial/ mesh/ discreteMethods/ heatTransfer/ multiphase/ hon@hon-ubuntu:~$ cd OpenFOAM/hon-2.1.0/run/tutorials/incompressible/icoFoam/cavity hon@hon-ubuntu:~/OpenFOAM/hon-2.1.0/run/tutorials/incompressible/icoFoam/cavity$ blockMesh blockMesh: command not found hon@hon-ubuntu:~/OpenFOAM/hon-2.1.0/run/tutorials/incompressible/icoFoam/cavity$ paraFoam paraFoam: command not found hon@hon-ubuntu:~/OpenFOAM/hon-2.1.0/run/tutorials/incompressible/icoFoam/cavity$ |
Bruno Santos
Rep Power: 45 ![]() ![]() |
Greetings honvu and welcome to the forum!
Two questions:
Bruno
#3 | |
I using Ubuntu 11.10 and installed OpenFOAM 2.1.0. When i remove OpenFOAM 2.1.0 and installed OpenFOAM 2.2.0 result the same.
Bruno Santos
Hi honvu,
I think that the messages that start with: Code:
void DBusMenuExporterPrivate::addAction As for the problem with OpenFOAM not working when you start a new terminal, that is because you probably did not add the following line to the file "~/.bashrc": Code:
source /opt/openfoam210/etc/bashrc If you have more than one line inside the file "~/.bashrc" that is related to OpenFOAM, then you should comment out the other versions, at least until you are more familiar with OpenFOAM and how it works. ![]() Best regards, Bruno
#5 | |
I installed successful OpenFOAM for your help. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Paraview Compiling Error (OpenFOAM 2.1.x + openSUSE 12.2) | sfigato | OpenFOAM Installation | 22 | January 31, 2013 10:16 |
| Case running in serial, but Parallel run gives error - Please help! urgent ! | atmcfd | OpenFOAM Running, Solving & CFD | 9 | November 21, 2012 03:39 |
| Questions about Paraview to show Parallel run of OpenFOAM | padian | OpenFOAM Post-Processing | 9 | November 19, 2012 06:02 |
| paraview doesn't run after upgrading to jaunty | lions85 | OpenFOAM | 8 | June 24, 2009 17:49 |
| Paraview run problem | ztdep | OpenFOAM | 1 | April 21, 2009 02:52 |
