[Sponsors] | |||||
Rep Power: 2 ![]() |
I am new to Linux. I want to update my OpenFoam 2.1.1 to 2.2.0. Can you please help me which commands should I use? Thanks, |
Chris Sideroff
Rep Power: 6 ![]() |
No simple, one liner, to update. You need to install it like a new version (because it is a new version). Then to use one or the other, simply source the appropriate shell script to setup the environment.
There tends to be significant enough changes to the core framework between even dot releases (e.g. 2.1 to 2.2) to prevent simple updating. This also often requires modifications to custom written code (solver, BCs, etc). |
Thank you very much for your response. I tried to install the OpenFOAM 2.2.0. I follow exactly the same steps that is presented on the website but there is a problem. After the 3rd step "sudo apt-get install openfoam220", I got the error below:
E: Couldn't find package openfoam220 Do you have any idea to how to solve that problem? Thanks, |
I am trying to install the OpenFOAM 2.2.0. I follow exactly the same steps that is presented on the website but there is a problem. After the 3rd step "sudo apt-get install openfoam220", I got the error below:
E: Couldn't find package openfoam220 I am running Ubuntu 10.04. I checked the "sources.list" file and I can see that "deb http://www.openfoam.org/download/ubuntu lucid main" is there and also it gets updated fine at the end of the 2nd step too. Do you have any idea to how to solve that problem? Thanks, |
Jose Rey
Do you have your linux environment within a Virtual Machine (e.g. VirtualBox)? Sometimes just with resetting the virtual machine, or disconnecting the LAN bridge and connecting it again is enough.
The question for the Senior Foamers is: Is it worth it to change to the 2.2.0 version now? Or should we wait for a 2.2.1? Regardless of how elegant the code is and how well tested it is, there are always bugs when major changes are made. I am excited about the improvements to snappyHexMesh which seem significant. Last edited by JR22; April 2, 2013 at 15:00. Reason: Worth it upgrading to Openfoam-2.0.0 ? |
I am not using a Virtual Machine. I am using Ubuntu 10.04.
#7 | |
Bruno Santos
Rep Power: 45 ![]() ![]() |
Greetings to all!
@kilroy: I'm guessing you didn't read the available Ubuntu versions at the beginning of the page : http://www.openfoam.org/download/ubuntu.phpQuote:
Best regards, Bruno
#8 | |
![]() I will follow the instructions on the post that you provided, I think that will solve the problem. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| No Wall pressure from OpenFOAM 2.2.0 | musahossein | OpenFOAM Post-Processing | 4 | April 4, 2013 19:05 |
| Problem with RenumberMesh in parallel in OpenFOAM 2.1.1 | srini_esi | OpenFOAM Mesh Utilities | 0 | March 18, 2013 08:01 |
| Is OpenFOAM 2.1.1 Heat Transfer applications working? | fontania | OpenFOAM Running, Solving & CFD | 0 | September 20, 2012 23:15 |
| Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
| The OpenFOAM extensions project | mbeaudoin | OpenFOAM | 16 | October 9, 2007 09:33 |
