OF 1.6 ext on Ubuntu 12.10 (64 bit) compilation errors
Old   April 20, 2013, 09:20
Default OF 1.6 ext on Ubuntu 12.10 (64 bit) compilation errors
ILAM
dreamilam is on a distinguished road
Hi guys,
I am trying to install OF 1.6 ext on ubuntu 12.1 (64 bit).. I got some errors while compiling paraview. So I set it to system installed paraview.
But, I am still getting errors while compiling the src folder.
can anybody help?
I have attached the log files
kaipulla@kaipulla-Dell-System-XPS-L502X:~/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty$ ./AllMake
This system rpm command: rpm --force-debian
Starting ThirdParty Allwmake
Starting ThirdParty AllMake: Stage1
Package name : cmake-2.8.8
Package URL : https://www.cmake.org/files/v2.8/cmake-2.8.8.tar.gz
RPM spec file name: cmake-2.8.8.spec
Additional flags :
Updating the ThirdParty environment variables before building package cmake-2.8.8
Package cmake-2.8.8 is already installed
Done installing package
Done ThirdParty AllMake: Stage1
Starting ThirdParty AllMake: Stage2
Package name : openmpi-1.4.3
Package URL : http://www.open-mpi.org/software/omp...i-1.4.3.tar.gz
RPM spec file name: openmpi-1.4.3.spec
Additional flags :
Updating the ThirdParty environment variables before building package openmpi-1.4.3
Package openmpi-1.4.3 is already installed
Done ThirdParty AllMake: Stage2
Starting ThirdParty AllMake: Stage3
Package name : metis-5.0pre2
Package URL : http://glaros.dtc.umn.edu/gkhome/fet...5.0pre2.tar.gz
RPM spec file name: metis-5.0pre2.spec
Additional flags :
Updating the ThirdParty environment variables before building package metis-5.0pre2
Package metis-5.0pre2 is already installed
Package name : ParMGridGen-1.0
Package URL : http://www.mgnet.org/mgnet/Codes/par...Gen-1.0.tar.gz
RPM spec file name: ParMGridGen-1.0.spec
Additional flags :
Updating the ThirdParty environment variables before building package ParMGridGen-1.0
Package ParMGridGen-1.0 is already installed
Package name : libccmio-2.6.1
Package URL : https://wci.llnl.gov/codes/visit/3rd...o-2.6.1.tar.gz
RPM spec file name: libccmio-2.6.1.spec
Additional flags :
Updating the ThirdParty environment variables before building package libccmio-2.6.1
Package libccmio-2.6.1 is already installed
Package name : mesquite-2.1.2
Package URL : http://software.sandia.gov/~jakraft/...e-2.1.2.tar.gz
RPM spec file name: mesquite-2.1.2.spec
Additional flags :
Updating the ThirdParty environment variables before building package mesquite-2.1.2
Package mesquite-2.1.2 is already installed
Package name : scotch-5.1.10b
Package URL : https://gforge.inria.fr/frs/download...5.1.10b.tar.gz
RPM spec file name: scotch-5.1.10b.spec
Additional flags :
Updating the ThirdParty environment variables before building package scotch-5.1.10b
Package scotch-5.1.10b is already installed
Package name : ParMetis-3.1.1
Package URL : http://glaros.dtc.umn.edu/gkhome/fet...s-3.1.1.tar.gz
RPM spec file name: ParMetis-3.1.1.spec
Additional flags :
Updating the ThirdParty environment variables before building package ParMetis-3.1.1
Package ParMetis-3.1.1 is already installed
Done ThirdParty AllMake: Stage3
Starting ThirdParty AllMake: Stage4
Package name : qt-everywhere-opensource-src-4.7.4
Package URL : http://get.qt.nokia.com/qt/source/qt...c-4.7.4.tar.gz
RPM spec file name: qt-everywhere-opensource-src-4.7.4.spec
Additional flags :
Updating the ThirdParty environment variables before building package qt-everywhere-opensource-src-4.7.4
Package qt-everywhere-opensource-src-4.7.4 is already installed
Using system installed ParaView
Done ThirdParty AllMake: Stage4
Done ThirdParty Allwmake
kaipulla@kaipulla-Dell-System-XPS-L502X:~/OpenFOAM/OpenFOAM-1.6-ext/src$ ./Allwmake
+ wmakePrintBuild -check
no git description found
+ /bin/rm -f OpenFOAM/Make/linux64GccDPOpt/global.C OpenFOAM/Make/linux64GccDPOpt/global.o
+ wmakeLnInclude OpenFOAM
+ wmakeLnInclude meshTools
+ wmakeLnInclude OSspecific/POSIX
+ Pstream/Allwmake
+ wmake libso dummy
'/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/dummy/libPstream.so' is up to date.
+ set +x
Note: ignore spurious warnings about missing mpicxx.h headers
+ WM_OPTIONS=linux64GccDPOptOPENMPI
+ wmake libso mpi
'/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/openmpi-1.4.3/libPstream.so' is up to date.
+ wmake libo OSspecific/POSIX
'/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt/libOSspecific.o' is up to date.
+ wmake libso OpenFOAM
SOURCE=global/global.Cver ; sed -e 's/VERSION_STRING/1.6-ext/' -e 's/BUILD_STRING/1.6-ext/' $SOURCE > Make/linux64GccDPOpt/global.C; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linux64GccDPOpt/global.C -o Make/linux64GccDPOpt/global.o
SOURCE=db/dictionary/dictionary.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/dictionary.o
SOURCE=db/IOobject/IOobjectWriteHeader.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/IOobjectWriteHeader.o
SOURCE=db/regIOobject/regIOobject.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/regIOobject.o
SOURCE=db/regIOobject/regIOobjectRead.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/regIOobjectRead.o
In file included from lnInclude/ILList.H:170:0,
from lnInclude/IDLList.H:36,
from lnInclude/entry.H:46,
from db/dictionary/dictionary.H:55,
from db/dictionary/dictionary.C:27:
lnInclude/ILList.C: In instantiation of ‘Foam::ILList<LListBase, T>::ILList(const Foam::ILList<LListBase, T>&, const CloneArg&) [with CloneArg = Foam::dictionary; LListBase = Foam:LListBase; T = Foam::entry]’:
lnInclude/IDLList.H:85:49: required from ‘Foam::IDLList<T>::IDLList(const Foam::IDLList<T>&, const CloneArg&) [with CloneArg = Foam::dictionary; T = Foam::entry]’
db/dictionary/dictionary.C:127:23: required from here
lnInclude/ILList.C:66:9: error: ‘append’ was not declared in this scope, and no declarations were found by argument-dependent lookup at the point of instantiation [-fpermissive]
lnInclude/ILList.C:66:9: note: declarations in dependent base ‘Foam:LListBase’ are not found by unqualified lookup
lnInclude/ILList.C:66:9: note: use ‘this->append’ instead
make: *** [Make/linux64GccDPOpt/dictionary.o] Error 1
make: *** Waiting for unfinished jobs....
P.S : I have tried most of the fixes discussed on the forum.
dreamilam is offline   Reply With Quote
Old   April 20, 2013, 14:21
Retired Super Moderator
Bruno Santos
Hi dreamilam,
I got your message and I saw your post even before that
I won't be able to test this anytime soon, but the following code seems to be the missing step:
Originally Posted by wenterodt View Post
# We are going to use the system installed version of gcc-4.7.1
# Modify the etc/prefs.sh file to switch to gcc 4.7.1
sed -i s/"compilerInstall=System"/"compilerInstall=System\nWM_COMPILER=Gcc47"/g ~/OpenFOAM/OpenFOAM-1.6-ext/etc/prefs.sh
It changes from the default option "Gcc" to "Gcc47", which applies some of the much needed rules for compiling with Gcc 4.7, which Ubuntu 12.10 provides.
After you've executed the last line of code, do the following steps as well:
  1. Since I don't want you to need to rebuild every single package once again, let's try and use symbolic links for linking to the previous builds:
    foam3rdParty
    find . -name linux64GccDPOpt | sed -e 's=linux64GccDPOpt=linux64Gcc47DPOpt=' | xargs -I {} ln -s linux64GccDPOpt {}
  2. Then start a new terminal and run "Allwmake" once again!
Best regards,
Bruno
Old   April 20, 2013, 20:19
ILAM
Thanks for the quick reply bruno.
I did as you told and got this error.
Makefile:55: /home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc47/general: No such file or directory
Makefile:56: /home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc47/c++: No such file or directory
make: *** No rule to make target `/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc47/c++'. Stop.
+ /bin/rm -f OpenFOAM/Make/linux64Gcc47DPOpt/global.?
+ Pstream/Allwmake
+ wmake libso dummy
/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/wmake/MakefileOptions:37: /home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc47/general: No such file or directory
make: *** No rule to make target `/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc47/general'. Stop.
/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/wmake/MakefileFiles:39: /home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc47/general: No such file or directory
/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/wmake/MakefileFiles:40: linux64Gcc47DPOpt/options: No such file or directory
make: *** No rule to make target `linux64Gcc47DPOpt/options'. Stop.
wmake error: file 'Make/linux64Gcc47DPOpt/objectFiles' could not be created
+ set +x
+ WM_OPTIONS=linux64Gcc47DPOptOPENMPI
+ wmake libso mpi
/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/wmake/MakefileFiles:40: linux64Gcc47DPOptOPENMPI/options: No such file or directory
make: *** No rule to make target `linux64Gcc47DPOptOPENMPI/options'. Stop.
wmake error: file 'Make/linux64Gcc47DPOptOPENMPI/objectFiles' could not be created
Then i copy-pasted the wmake/rules/linux64Gcc47 directory from my OF2.2 installation.
But Its still not getting compiled.
kaipulla@kaipulla-Dell-System-XPS-L502X:~/OpenFOAM/OpenFOAM-1.6-ext$ ./Allwmake
make: Nothing to be done for `all'.
+ /bin/rm -f OpenFOAM/Make/linux64Gcc47DPOpt/global.C OpenFOAM/Make/linux64Gcc47DPOpt/global.o
+ Pstream/Allwmake
+ wmake libso dummy
'/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc47DPOpt/dummy/libPstream.so' is up to date.
+ set +x
+ wmake libso mpi
linux64Gcc47DPOptOPENMPI/options:4: /home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc47/mplibOPENMPI: No such file or directory
make: *** No rule to make target `/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc47/mplibOPENMPI'. Stop.
'/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc47DPOpt/libOSspecific.o' is up to date.
SOURCE=global/global.Cver ; sed -e 's/VERSION_STRING/1.6-ext/' -e 's/BUILD_STRING/1.6-ext/' $SOURCE > Make/linux64Gcc47DPOpt/global.C; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linux64Gcc47DPOpt/global.C -o Make/linux64Gcc47DPOpt/global.o
SOURCE=db/dictionary/dictionary.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/dictionary.o
SOURCE=db/dictionary/primitiveEntry/primitiveEntry.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/primitiveEntry.o
SOURCE=db/dictionary/primitiveEntry/primitiveEntryIO.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/primitiveEntryIO.o
make: *** [Make/linux64Gcc47DPOpt/dictionary.o] Error 1
Old   April 21, 2013, 04:16
Bruno Santos
OK, I know what the problem is... I think... Run the following commands:
foam
git stash
git merge hotfix/gcc47
git stash pop
Note: Do the last step, even if the "git merge" step gives an error!
If the "git merge" step does give you an error, then you possibly got the incomplete git repository... if so, try this:
foam
git remote add repo git://repo.or.cz/OpenFOAM-1.6-ext.git
git pull repo hotfix/gcc47
Then run Allwmake once again.
Best regards,
Bruno
Last edited by wyldckat; April 21, 2013 at 05:19. Reason: "git stash pop", not "git pop"...
Old   April 21, 2013, 05:12
ILAM
Hi Bruno,
I Followed your instructions, but I am getting a different kind of error.
kaipulla@kaipulla-Dell-System-XPS-L502X:~/OpenFOAM/OpenFOAM-1.6-ext$ git stash
Saved working directory and index state WIP on master: 9716e5a Merge branch 'master' into hotfix/gcc47
HEAD is now at 9716e5a Merge branch 'master' into hotfix/gcc47
kaipulla@kaipulla-Dell-System-XPS-L502X:~/OpenFOAM/OpenFOAM-1.6-ext$ git merge hotfix/gcc47
fatal: hotfix/gcc47 - not something we can merge
kaipulla@kaipulla-Dell-System-XPS-L502X:~/OpenFOAM/OpenFOAM-1.6-ext$ git pop
git: 'pop' is not a git command. See 'git --help'.
Did you mean this?
log
kaipulla@kaipulla-Dell-System-XPS-L502X:~/OpenFOAM/OpenFOAM-1.6-ext$ git pull repo hotfix/gcc47
From git://repo.or.cz/OpenFOAM-1.6-ext
* branch hotfix/gcc47 -> FETCH_HEAD
Already up-to-date.
After running Allwmake, this is the first error i get
+ wmake libso parMetisDecomp
linux64Gcc47DPOpt/options:4: /home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc47/mplibOPENMPI: No such file or directory
+ wmake libso decompositionMethods
Making dependency list for source file patchConstrainedDecomp/patchConstrainedDecomp.C
Making dependency list for source file hierarchGeomDecomp/hierarchGeomDecomp.C
Making dependency list for source file simpleGeomDecomp/simpleGeomDecomp.C
Making dependency list for source file geomDecomp/geomDecomp.C
Making dependency list for source file manualDecomp/manualDecomp.C
Making dependency list for source file decompositionMethod/decompositionMethod.C
SOURCE=decompositionMethod/decompositionMethod.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/decompositionMethod.o
SOURCE=manualDecomp/manualDecomp.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/manualDecomp.o
SOURCE=geomDecomp/geomDecomp.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/geomDecomp.o
SOURCE=simpleGeomDecomp/simpleGeomDecomp.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/simpleGeomDecomp.o
SOURCE=hierarchGeomDecomp/hierarchGeomDecomp.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/hierarchGeomDecomp.o
SOURCE=patchConstrainedDecomp/patchConstrainedDecomp.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -IlnInclude -I. -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/kaipulla/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc47DPOpt/patchConstrainedDecomp.o
/usr/bin/ld: cannot find -lparMetisDecomp
collect2: error: ld returned 1 exit status
Old   April 21, 2013, 05:25
Bruno Santos
Sorry, I forgot to write down the word "stash" before "pop" I've fixed the previous post. The correct command is:
git stash pop
But this is getting very strange... because the "git pull" command indicates that the merge was already done sometime in the past.
And apparently I was too sleepy when I read your previous post...
Since you've copied the "wmake/rules/linux64Gcc47" folder from OF 2.2, then there's only one file missing. Copy the file "wmake/rules/General/mplibOPENMPI" from OpenFOAM 2.2 into the folder "wmake/rules/linux64Gcc47" on 1.6-ext. Then try Allwmake once again.
Old   April 21, 2013, 05:31
ILAM
Hi Bruno,
yeah, I copied the file. Its compiling nice and good. There is no error till now.
Thanks a lot. You are a life saver.
Old   April 21, 2013, 05:43
Bruno Santos
Hi dreamilam,
You're welcome! I just hope it will build everything without any further problems...
Best regards,
Bruno
OF 1.6 installation on Ubuntu 7.04 mstfl OpenFOAM Installation 12 March 29, 2010 00:18
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
Problem in running fluent 6.3 (64 bit) on ubuntu 8.1 (64 bit) Mir5 FLUENT 3 April 29, 2009 10:32
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
