-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   source bashrc error (http://www.cfd-online.com/Forums/openfoam-installation/116315-source-bashrc-error.html)
y_jiang April 17, 2013 00:20
source bashrc error
I'm trying to install the new version 2.2.0 on Ubuntu 12.04. The computer is x86_64 and has 4 cpu cores. I just followed the instruction here http://www.openfoam.org/download/source.php
I just created the directory OpenFOAM in home and after I edited .bashrc It gave me this:
bash: /home/username/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc: No such file or directory
The "username" above is my account name.
Dose anyone have this problem when you install OpenFOAM? :confused:
Dose anyone have suggestion? Thank you~
y_jiang April 17, 2013 10:48
It solved.
wyldckat April 17, 2013 17:09
Greetings y_jiang and welcome to the forum!
Unfortunately I was not able to answer sooner.
And I'm glad you've managed to fix the problem. Could you share the solution and/or your diagnosis on the problem you had?
Best regards,
Bruno
y_jiang April 17, 2013 18:48
Hi Bruno,
Thanks for you reply. The first time I didn't make it just due to a wrong path. Actually, if you just follow the instruction here http://www.openfoam.org/download/source.php and put the source packs in OpenFOAM in your home directory, it should be no problem.
YJ
