April 17, 2013, 00:20 |
source bashrc error
Yijiu Jiang
I'm trying to install the new version 2.2.0 on Ubuntu 12.04. The computer is x86_64 and has 4 cpu cores. I just followed the instruction here http://www.openfoam.org/download/source.php
I just created the directory OpenFOAM in home and after I edited .bashrc It gave me this: bash: /home/username/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc: No such file or directory The "username" above is my account name. Dose anyone have this problem when you install OpenFOAM? Dose anyone have suggestion? Thank you~ Last edited by y_jiang; April 17, 2013 at 10:52. |
April 17, 2013, 10:48 |
Yijiu Jiang
It solved.
April 17, 2013, 17:09 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings y_jiang and welcome to the forum!
Unfortunately I was not able to answer sooner. And I'm glad you've managed to fix the problem. Could you share the solution and/or your diagnosis on the problem you had? Best regards, Bruno
April 17, 2013, 18:48 |
Yijiu Jiang
Hi Bruno,
Thanks for you reply. The first time I didn't make it just due to a wrong path. Actually, if you just follow the instruction here http://www.openfoam.org/download/source.php and put the source packs in OpenFOAM in your home directory, it should be no problem. YJ |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
