OF 1.6 ext on Ubuntu 12.10 (64 bit) compilation errors
Hi guys,
I am trying to install OF 1.6 ext on ubuntu 12.1 (64 bit).. I got some errors while compiling paraview. So I set it to system installed paraview. But, I am still getting errors while compiling the src folder. can anybody help? I have attached the log files Quote:
Hi dreamilam,
I got your message and I saw your post even before that :) I won't be able to test this anytime soon, but the following code seems to be the missing step: Quote:
After you've executed the last line of code, do the following steps as well:
Bruno |
Thanks for the quick reply bruno.
I did as you told and got this error. Quote:
But Its still not getting compiled. Quote:
:confused: OK, I know what the problem is... I think... Run the following commands:
foam If the "git merge" step does give you an error, then you possibly got the incomplete git repository... if so, try this: Code:
foam Best regards, Bruno |
Hi Bruno,
I Followed your instructions, but I am getting a different kind of error. Quote:
Sorry, I forgot to write down the word "stash" before "pop" :( I've fixed the previous post. The correct command is:
git stash pop And apparently I was too sleepy when I read your previous post... Since you've copied the "wmake/rules/linux64Gcc47" folder from OF 2.2, then there's only one file missing. Copy the file "wmake/rules/General/mplibOPENMPI" from OpenFOAM 2.2 into the folder "wmake/rules/linux64Gcc47" on 1.6-ext. Then try Allwmake once again. |
Hi Bruno,
yeah, I copied the file. Its compiling nice and good. There is no error till now. Thanks a lot. You are a life saver. |
Hi dreamilam,
You're welcome! I just hope it will build everything without any further problems... Best regards, Bruno |
