June 1, 2011, 04:28 |
Install OpenFoam 1.6-ext
Yasser Amini
Rep Power: 15 |
Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/etc/settings.sh
Using openmpi-1.4.3 from the ThirdParty package: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3 Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/etc/openmpi-1.4.3.sh Using system installed OpenMPI: OPENMPI_BIN_DIR : /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/bin OPENMPI_LIB_DIR : /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib OPENMPI_INCLUDE_DIR : /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/include OPENMPI_COMPILE_FLAGS : -I/home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/include -pthread OPENMPI_LINK_FLAGS : -pthread -L/home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl MPI_HOME : /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt MPI_ARCH_PATH : /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt OPAL_PREFIX : /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt PINC : -I/home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/include -pthread PLIBS : -pthread -L/home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/mesquite-2.1.2/platforms/linux64GccDPOpt/etc/mesquite-2.1.2.sh MESQUITE_DIR is initialized to: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/mesquite-2.1.2/platforms/linux64GccDPOpt Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/metis-5.0pre2/platforms/linux64GccDPOpt/etc/metis-5.0pre2.sh METIS_DIR is initialized to: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/metis-5.0pre2/platforms/linux64GccDPOpt Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMetis-3.1.1/platforms/linux64GccDPOpt/etc/ParMetis-3.1.1.sh PARMETIS_DIR is initialized to: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMetis-3.1.1/platforms/linux64GccDPOpt PARMGRIDGEN_DIR is initialized to: Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/libccmio-2.6.1/platforms/linux64GccDPOpt/etc/libccmio-2.6.1.sh LIBCCMIO_DIR is initialized to: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/libccmio-2.6.1/platforms/linux64GccDPOpt Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/scotch-5.1.10b/platforms/linux64GccDPOpt/etc/scotch-5.1.10b.sh SCOTCH_DIR is initialized to: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/scotch-5.1.10b/platforms/linux64GccDPOpt Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/cmake-2.8.3/platforms/linux64GccDPOpt/etc/cmake-2.8.3.sh CMAKE_DIR is initialized to: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/cmake-2.8.3/platforms/linux64GccDPOpt PYTHON_DIR is initialized to: QT_DIR is initialized to: Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/etc/ParaView-3.8.1.sh PARAVIEW_DIR is initialized to: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt Sourcing: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/etc/aliases.sh aminiyasser@lap:~$ Last edited by aminiyasser; June 9, 2011 at 07:57. |
June 1, 2011, 04:53 |
Rep Power: 15 |
Have you compiled the ThirdParty files first? There is a folder "ThirdParty" - enter it an run AllMake
Hope it helps |
June 1, 2011, 05:14 |
Dear lindstroem
Yasser Amini
Rep Power: 15 |
June 1, 2011, 05:31 |
#4 | |
Rep Power: 15 |
chmod +x AllMake But actually it should already be executable... Sorry, dont know whats wrong. |
June 1, 2011, 09:01 |
#5 | |
Yasser Amini
Rep Power: 15 |
are you install openFoam 1.6-ext ? if yes please tell me step by step of your install procedure can you run the icoFsiFoam tutorial ? I want install 1.6-ext again what command should be used for clean openfoam 1.6-ext and its solvers |
June 1, 2011, 09:26 |
Rep Power: 15 |
I have 1.6-ext running but the icoFsiFoam is obviously not part of this package. It needs to be installed afterwards by hand:
http://www.cfd-online.com/Forums/ope...cofsifoam.html So you have to download the sources and build them. There are several guides how to install of1.6-ext online so i dont need to rewrite it again. If you have problems post the error messages then it is easier to help you. |
June 1, 2011, 10:10 |
#7 | |
Yasser Amini
Rep Power: 15 |
Dear lindstroem icoFsiFoam is a solver of 1.6-ext and exist in stressAnalysis the path of tutorial of icoFsiFoam is : OpenFOAM-1.6-ext/tutorials/stressAnalysis/icoFsiFoam/ |
June 1, 2011, 10:47 |
Jesse
Rep Power: 17 |
If u wanna uninstall it, Firstly you should delete one command line related to settings.sh in .bashrc. You can use "rm -rf" command to delete it completely after that.
June 1, 2011, 11:01 |
#9 | |
Yasser Amini
Rep Power: 15 |
I delete this line in .bashrc . $HOME/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc and then execute " rm -rf " but the openFoam 1.6-ext not removed !!!!!!!!! |
June 4, 2011, 01:44 |
dear nima
#11 |
Yasser Amini
Rep Power: 15 |
June 6, 2011, 02:10 |
Daer Nima
#13 |
Yasser Amini
Rep Power: 15 |
Dear nima
my errors is displayed at the top of this page Last edited by aminiyasser; June 9, 2011 at 08:08. |
June 6, 2011, 05:41 |
#14 |
Rep Power: 15 |
I found the tutorial, it runs fine on my machine. What system are you running on?
June 8, 2011, 01:50 |
#15 |
Yasser Amini
Rep Power: 15 |
June 8, 2011, 09:53 |
#16 | |
Rep Power: 15 |
the icoFsiFoam tutorial..
Maybe you can try this tutorial for an installation of 1.6-ext.. otherwise git clone the sources try to build them and if it fails post error messages.. Quote:
May 27, 2012, 10:34 |
openFOAM-1.6-ext
#17 |
Hello all
how can i install OpenFOAM-1.6-ext on Kubuntu while OF-1.5-dev installed automatically on this version of Linux? i read some documention about this problem, but i could not success to install it. would you mind to tell me step by step that how do it? tanx ______ Kind Regards |
May 29, 2012, 05:08 |
#18 |
you can have installed more than one installation coexisting side by side if you have the right .bashrc ;-) alias startOF15dev='unset FOAM_INST_DIR;unset WM_PROJECT_USER_DIR;unset WM_THIRD_PARTY_DIR;source /usr/lib/OpenFOAM-1.5dev/etc/bashrc' alias startOF16ext='unset FOAM_INST_DIR;unset WM_PROJECT_USER_DIR;unset WM_THIRD_PARTY_DIR;source /usr/lib/OpenFOAM-1.6-ext/etc/bashrc' alias startOFwhateveryouwant='...' please write the correct path after source => http://openfoamwiki.net/index.php/Installation on the console you type startOF16ext or startOF15dev or startOFwhateveryouwant to use the specific OFversion you want |
October 23, 2012, 12:56 |
#19 | |
fatemeh sadeghpour
Rep Power: 13 |
I have question? cd ~ rm rs OpenFOAM or OpenFOAM-1.6-ext??? i want to uninstall 1.6 and then to install again, because it has wrong directory, i should install in openfoam 2.1.1 directory not run directory. but i dont want to make mistake,for example not to remove openfoam 2.1.1 please help me thanks |
October 23, 2012, 13:36 |
#20 |
Nima Samkhaniani
Rep Power: 24 |
Hi
How did you install your OpenFOAM? from source, binary package or .deb package? if you install it from source or binary package you can go to that directory and remove it with rm -rf but if you install .deb package, you can easily uninstall it from synaptic package manager |
Display Modes | |
install OpenFoam 1.6 by building source: how? | niudie | OpenFOAM Installation | 13 | April 26, 2011 01:48 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 15:43 |
install openfoam 1.6 on opensuse 11.0 | andresbh | OpenFOAM Installation | 8 | September 30, 2009 01:48 |
Install openFOAM 1.6 on debian 32bit - blockMesh: command not found | fossy | OpenFOAM Installation | 1 | August 28, 2009 05:06 |
Install of OpenFOAM 1.6 Error 1 Error 2 & run tutorial | potac | OpenFOAM Installation | 3 | August 27, 2009 10:04 |
