Installing OpenFOAM 1.6-ext on Ubuntu 11.10
Old   May 5, 2013, 08:52
Default Installing OpenFOAM 1.6-ext on Ubuntu 11.10
immortality's Avatar
Ehsan
immortality is on a distinguished road
Originally Posted by wyldckat View Post
Hi Oleg,
The differences are only:
  1. That git mirror version does not have all of the branches that the one at sf.net had. But the master branch is present as "sf/master", which is the default upon clone.
  2. You can also use the following instructions, depending on the Ubuntu version you've got: https://github.com/ogoe/OpenFOAM-1.6...uctions/Ubuntu
Best regards,
Bruno
where are instructions for ubuntu 11.10?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   May 5, 2013, 09:06
Retired Super Moderator
Bruno Santos
Try following these instructions: http://openfoamwiki.net/index.php/In...u#Ubuntu_11.04 - they should work on Ubuntu 11.10.
Old   May 5, 2013, 10:52
Ehsan
I downloaded 1.6ext folder and followed instructions but nothing occurred when used ./Allwmake:
bash: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc: No such file or directory
ehsan@Ehsan-com:~/Desktop/OpenFOAM-1.6-ext-sf-master$ ./AllMake > log.AllMake 2>&1
ehsan@Ehsan-com:~/Desktop/OpenFOAM-1.6-ext-sf-master$ gedit log.AllMake
ehsan@Ehsan-com:~/Desktop/OpenFOAM-1.6-ext-sf-master$ source etc/bashrc
bash: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/bin/foamEtcFile: No such file or directory
bash: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/bin/foamCleanPath: No such file or directory
bash: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/etc/settings.sh: No such file or directory
bash: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/etc/aliases.sh: No such file or directory
ehsan@Ehsan-com:~/Desktop/OpenFOAM-1.6-ext-sf-master$ ./Allwmake > make.log 2>&1ehsan@Ehsan-com:~/Desktop/OpenFOAM-1.6-ext-sf-master$ ./Allwmake > make.log 2>&1ehsan@Ehsan-com:~/Desktop/OpenFOAM-1.6-ext-sf-master$ icoFoam -help
icoFoam: command not found
Old   May 5, 2013, 11:17
Bruno Santos
Hi Ehsan,
You didn't properly follow the instructions. Looks like you skipped step #2. Follow these instructions:
cd ~
mkdir OpenFOAM
cd OpenFOAM
mv ~/Desktop/OpenFOAM-1.6-ext-sf-master OpenFOAM-1.6-ext
Then continue from step #4 from the section "2.2 - Ubuntu 11.04": http://openfoamwiki.net/index.php/In...u#Ubuntu_11.04
Best regards,
Bruno
Old   May 5, 2013, 11:29
Ehsan
thanks.I supposed stages before are related to downloading.
now I have extracted ext folder in the desktop and this error occurs:
ehsan@Ehsan-com:~/OpenFOAM$ cd OpenFOAM-1.6-ext
bash: cd: OpenFOAM-1.6-ext: No such file or directory
should I copy it to HOME/OpenFOAM?
Old   May 5, 2013, 11:34
Bruno Santos
Please follow the instructions from the previous post.
By the way, I've moved this line of conversation to a new thread, given that the emphasis is about installing on Ubuntu 11.10.
Old   May 5, 2013, 11:55
Ehsan
thanks.now is this on compiling?(nothing is shown)
ehsan@Ehsan-com:~/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty$ ./AllMake > log.AllMake 2>&1
Old   May 5, 2013, 12:02
Bruno Santos
Yes, it should be and it's going to take a while. And this is just for building the "ThirdParty" applications!
When it's finished, then you'll be able to build OpenFOAM 1.6-ext.
Old   May 5, 2013, 13:19
Ehsan
ahy does it takes this so much?its now 2hours!
even doesn't show anything that user be certain its running or when ends!
why is not like official version?
Old   May 5, 2013, 13:33
Ehsan
why this text displayed when i open a new terminal now?whats wrong?
Sourcing: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/etc/settings.sh
Using openmpi-1.4.3 from the ThirdParty package: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3
Sourcing: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/etc/openmpi-1.4.3.sh
  Environment variables defined for OpenMPI:
    OPENMPI_BIN_DIR       : /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/bin
    OPENMPI_LIB_DIR       : /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib
    OPENMPI_INCLUDE_DIR   : /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/include
    OPENMPI_COMPILE_FLAGS : -I/home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/include -pthread
    OPENMPI_LINK_FLAGS    : -pthread -L/home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
    MPI_HOME              : /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt
    MPI_ARCH_PATH         : /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt
    OPAL_PREFIX           : /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt
    PINC                  : -I/home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/include -pthread
    PLIBS                 : -pthread -L/home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
Sourcing: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/mesquite-2.1.2/platforms/linux64GccDPOpt/etc/mesquite-2.1.2.sh
    MESQUITE_DIR is initialized to: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/mesquite-2.1.2/platforms/linux64GccDPOpt
Sourcing: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/metis-5.0pre2/platforms/linux64GccDPOpt/etc/metis-5.0pre2.sh
    METIS_DIR is initialized to: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/metis-5.0pre2/platforms/linux64GccDPOpt
Sourcing: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMetis-3.1.1/platforms/linux64GccDPOpt/etc/ParMetis-3.1.1.sh
    PARMETIS_DIR is initialized to: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMetis-3.1.1/platforms/linux64GccDPOpt
Sourcing: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMGridGen-1.0/platforms/linux64GccDPOpt/etc/ParMGridGen-1.0.sh
    PARMGRIDGEN_DIR is initialized to: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMGridGen-1.0/platforms/linux64GccDPOpt
Sourcing: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/libccmio-2.6.1/platforms/linux64GccDPOpt/etc/libccmio-2.6.1.sh
    LIBCCMIO_DIR is initialized to: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/libccmio-2.6.1/platforms/linux64GccDPOpt
Sourcing: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/scotch-5.1.10b/platforms/linux64GccDPOpt/etc/scotch-5.1.10b.sh
    SCOTCH_DIR is initialized to: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/scotch-5.1.10b/platforms/linux64GccDPOpt
Sourcing: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/cmake-2.8.8/platforms/linux64GccDPOpt/etc/cmake-2.8.8.sh
    CMAKE_DIR is initialized to: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/cmake-2.8.8/platforms/linux64GccDPOpt
    M4_DIR is initialized to:
    BISON_DIR is initialized to:
    FLEX_DIR is initialized to:
    ZOLTAN_DIR is initialized to:
    PYTHON_DIR is initialized to:
Sourcing: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/qt-everywhere-opensource-src-4.7.4/platforms/linux64GccDPOpt/etc/qt-everywhere-opensource-src-4.7.4.sh
    QT_DIR is initialized to: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/qt-everywhere-opensource-src-4.7.4/platforms/linux64GccDPOpt
    PARAVIEW_DIR is initialized to:
Sourcing: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/etc/aliases.sh
Sourcing: /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/etc/prefs.sh
Old   May 5, 2013, 13:39
Bruno Santos
Start a new terminal, go to the same folder and run:
less log.AllMake
Press the "End" key and it should go show the end of the log. Press a couple more times and you'll see that it's updating the log file. Press the "Q" key to exit the application less.
It's taking so long because it has to build Qt and ParaView. This is to avoid some occasional running issues that occur with ParaView, when it's built with an untested or Ubuntu Qt version.
And since Ubuntu 11.10 only provides ParaView 3.10, I didn't suggest using this particular version of ParaView.
And it's not like the official version, because it does not have the same level of support and development At least as far as I know.
Old   May 5, 2013, 13:41
Bruno Santos
I forgot to mention this before: those instructions currently only assume the user is installing a single OpenFOAM version. You'll have to edit the file "~/.bashrc" once again and adapt to your current settings.
The long description is a feature that 1.6-ext has got, since it provides tons of features. This way it's easier to verify if, what and where is installed and being used.
Old   May 5, 2013, 14:27
Ehsan
its the bashrc now.what changes have to be done?
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
if [ -f /etc/bash_completion ] && ! shopt -oq posix; then
    . /etc/bash_completion
fi
#. /opt/openfoam220/etc/bashrc
#. /opt/openfoam211/etc/bashrc
#. /opt/openfoam210/etc/bashrc
alias of220='. /opt/openfoam220/etc/bashrc'
alias of210='. /opt/openfoam210/etc/bashrc'
export PATH="$PATH:/home/ehsan/Desktop/codes"
source /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc
Old   May 5, 2013, 14:31
Bruno Santos
Replace:
With:
alias of16ext='source /home/ehsan/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc'
Old   May 5, 2013, 14:49
Ehsan
now it has ended and 1.6.ext is compiling.but I can't see its progress by before commandyou said in 1.6ext folder.
and what do you mean by:
Old   May 5, 2013, 16:46
Bruno Santos
Ubuntu 11.10 has got ParaView 3.10 in the apt-get package system. If you were to run:
sudo apt-get install paraview
You would get ParaView 3.10.
I didn't suggest to you to install this version, because it's a very outdated version.
Old   May 6, 2013, 06:27
Ehsan
then how It can be possible to install a recent version pof paraview?or not possible?!
Old   May 6, 2013, 17:43
Bruno Santos
The current instructions take so very long to perform because it builds ParaView 3.12.0, which is better than Ubuntu 11.10.
I didn't suggest installing a more recent version of ParaView, because it can be a two-edge sword: it works great for many people, but leads to crashes for others. And one wrong step can lead to bigger problems. Therefore my suggestion is usually to take the safer route of building the custom version, even if it takes longer.
Either way, instructions on how to install a pre-built version of ParaView can be found here: Using the official pre-built ParaView 3.10.1 version with OpenFOAM - It's possible to adapt to the latest ParaView 3.98.1, instead of "3.10.1".
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 wyldckat OpenFOAM Installation 14 February 12, 2013 04:43
OpenFOAM 2.1 on Ubuntu SERVER 11.10 samiam1000 OpenFOAM Installation 2 March 7, 2012 02:40
openFOAM installation in ubuntu 11.10 kirubhakaran OpenFOAM Installation 5 February 17, 2012 02:16
OpenFOAM vs Ubuntu 10.10 64 bit vkrastev OpenFOAM Installation 12 April 23, 2011 10:14
Trouble with installing OpenFOAM on Ubuntu Milos OpenFOAM Installation 16 November 16, 2009 02:44
