[stressAnalysis] Failed to create symbolic link: flappingConsoleSmall and unable to use ParaView in it |
December 5, 2013, 06:22 |
ok
Rep Power: 13 |
Dear Bruno,
thanks a lot, paraview is working now for some tested cases in both OF-2.2.2 and OF-1.6-ext. But, I faced another problem when I tried running flappingConsoleSmall in OpenFOAM/maimouna-1.6-ext/run/tutorials/stressAnalysis/icoFsiFoam/flappingConsoleSmall I apply ./Allclean ./Allrun for running, it takes around 16 hours for running. It run very well for fluid case , but unfortunately, it gives me this command for solid ln: failed to create symbolic link `0/solid': File exists and after paraFoam, it gives me these commands ERROR: In /build/buildd/paraview-3.14.1/VTK/IO/vtkOpenFOAMReader.cxx, line 8464 vtkPOpenFOAMReader (0x3540160): /home/maimouna/OpenFOAM/maimouna-1.6-ext/run/tutorials/stressAnalysis/icoFsiFoam/flappingConsoleSmall/flappingConsoleSmall.foam contains no timestep data. ERROR: In /build/buildd/paraview-3.14.1/VTK/Filtering/vtkExecutive.cxx, line 756 vtkPVCompositeDataPipeline (0x35411f0): Algorithm vtkPOpenFOAMReader(0x3540160) returned failure for request: vtkInformation (0x35427d0) Debug: Off Modified Time: 70860 Reference Count: 1 Registered Events: (none) Request: REQUEST_INFORMATION ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 how can solve that? What's wrong with solid at flappingConsoleSmall. Warm regards Maimouna |
December 6, 2013, 06:05 |
ok
Rep Power: 13 |
Dear OpenFOAM users,
I'm working in OpenFOAM-1.6-ext in Ubuntu 12.04 (x86.64). I tried flappingConsoleSmall which is FSI case in icoFsiFoam solver (tutorials/ stressAnalysis/ icoFsiFoam/ flappingConsoleSmall), after running, ./Allclean ./Allrun I got ln: failed to create symbolic link `solid/constant': File exists ln: failed to create symbolic link `solid/0': File exists How can I solve this? Any idea? Regards |
December 7, 2013, 10:44 |
ok
Rep Power: 13 |
Dear Bruno,
how can I solve ln: failed to create symbolic link `0/solid': File exists. after running flappingConsoleSmall case? Regards |
December 8, 2013, 13:58 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Maimouna,
I've moved the first and third post from the other thread you had to here, namely from this one: http://www.cfd-online.com/Forums/ope...1-6-ext-2.html OK, these two: Code:
ln: failed to create symbolic link `solid/constant': File exists ln: failed to create symbolic link `solid/0': File exists If you don't want to see this error, then add these two lines to the end of the Allclean script: Code:
unlink fluid/0/solid unlink fluid/constant/solid Best regards, Bruno
December 9, 2013, 06:08 |
ok
Rep Power: 13 |
Dear Bruno,
when apply paraFoam, ParaView window gives me this error: ERROR: In /build/buildd/paraview-3.14.1/VTK/IO/vtkOpenFOAMReader.cxx, line 6875 vtkOpenFOAMReaderPrivate (0x2d670f0): boundaryField defaultFaces not found in object U at time = 0. What's the problem? Regards |
December 9, 2013, 18:07 |
Bruno Santos
Rep Power: 128 |
Hi Maimouna,
Best regards, Bruno
December 10, 2013, 06:12 |
ok
Rep Power: 13 |
Dear Bruno,
many thanks for your help. Warm regards Maimouna |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
[OpenFOAM] Unable to run paraview | vaibhavkhare | ParaView | 1 | July 23, 2018 14:44 |
[General] Unable to display image in Paraview | adey | ParaView | 2 | May 23, 2017 11:14 |
unable to run paraview | yoddha24 | OpenFOAM Installation | 4 | May 6, 2013 00:10 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
