Installation on ubuntu 13.04
Hi all
I have recently installed ubuntu 13.04, on which I would like to install openfoam. I could not fine the procedure to install openfoam v2.2.0 Can anyone please tell me the procedure? Does openfoam v2.2.0 compatible with ubuntu 12.10? What changes are required to make it compatible with 13.04? Thanks Mvee |
Hi
I tried to install OF 2.2.0 on Ubuntu 13.04. When I gave command of sudo apt-get update, I did not able to install few packages that prevents me to install the OF. Is there any other way to install it? I have followed the way similar to the installation on ubuntu 12.10. Thanks in advance Mvee |
paraview error on ubuntu 13.04
plsi need your advice, am kinda new to ubuntu, so i will really appreciate a simplified solution (step by step if possible). i recently installed openfoam2.2.0 on my ubuntu 13.04 OS, 64bit system. i ran the motorbike case on openfoam, it ran alright the trying to view it on paraview i get the following error ;
ERROR: In /build/buildd/paraview-3.98.0/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 4468 vtkOpenFOAMReaderPrivate (0x23b6cc0): Error reading line 20 of /home/chijioke/OpenFOAM/chijioke-2.2.0/run/tutorials/incompressible/simpleFoam/motorBike/system/forceCoeffs: Found duplicated entries with keyword log ERROR: In /build/buildd/paraview-3.98.0/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 753 vtkPVCompositeDataPipeline (0x23afd40): Algorithm vtkPOpenFOAMReader(0x239f370) returned failure for request: vtkInformation (0x23b6c70) Debug: Off Modified Time: 111085 Reference Count: 1 Registered Events: (none) Request: REQUEST_INFORMATION ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 pls i will really appreciate a solution from the house. p, li { white-space: pre-wrap; } |
Hi pitpat231
How did you install OF? I could not. Can you please tell me the procedure? I have followed the procedure described on OF site but got error of "certain packages are not installed". Please tell me how to install. Thank you Mvee |
i actually saw the procedure on openfoam website. here is the link; http://www.openfoam.org/download/ubuntu.php.
pls dose anyone have Bruno, wlydkat's email, or the Engys Guys own, i really need them to help me out with my above problem. |
Greetings to all!
@Mvee: :confused: I'm sorry, but I gotta ask this... Did you try using Google or some other online search engine to look for the following sentence? Code:
OpenFOAM Ubuntu 13.04 @pitpat231: Uhm... did you at least try and click on my user name link? Because you should get indications about how to contact me in my user page! As for Helyx-OS, there is a dedicated discussion board they have got here: http://sourceforge.net/p/helyx-os/di...?source=navbar Either way, I see you've already gotten an answer for your question about Helyx-OS: http://www.cfd-online.com/Forums/ope...tml#post435057 Also, about the problem you're having with ParaView:
Bruno |
@Bruno, thanks alot, it worked, my paraview dosent give the error again. i managed to get the stl geometry showing in helyx, in trying to creat my mesh and running the solver i get the following error;
MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun has exited due to process rank 3 with PID 3555 on node chijioke-W240HU-W250HUQ exiting without calling "finalize". This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [chijioke-W240HU-W250HUQ:03550] 1 more process has sent help message help-mpi-api.txt / mpi-abort [chijioke-W240HU-W250HUQ:03550] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages pls how do you advice i handle this ??? thanks in advance edit: Hi Bruno, just to add that my laptop is a intel corei7, so am running the solver on 7 proccessors. thanks |
Hi Patrick,
I'll answer on the other dedicated thread you've got: http://www.cfd-online.com/Forums/ope...tml#post435298 edit: didn't manage to do it yesterday, but chegdan is on the case :) Best regards, Bruno |
