OpenFOAM does not work any more!
Like Tree1Likes
  • 1 Post By wyldckat
Old   June 19, 2013, 04:10
Default OpenFOAM does not work any more!
Ye Zhang
kiddmax is on a distinguished road
Dear guys,
I have been using OpenFOAM2.1.0 for a while. But suddenly it does not work after I am trying to compile the utility foamToTecplot360. I think this is the reason which caused OpenFOAM can not work properly....
It gives the error: icoFoam: error while loading shared libraries: libmpi.so.1: cannot open shared object file: No such file or directory
I use "foamInstallationTest " to test, and get:
Checking basic setup...
Shell: bash
Host: tud204501
OS: Linux version 3.0.51-0.7.9-default
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /opt/apps/openfoam-2.1.0 yes yes
$WM_PROJECT_USER_DIR /home/yzhang13/OpenFOAM/yzhang13-2.1.0 yes no
$WM_THIRD_PARTY_DIR /home/yzhang13/OpenFOAM/ThirdParty-2.1.0 yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0 yes yes yes
$FOAM_APPBIN ...-2.1.0/platforms/linux64GccDPOpt/bin yes yes yes
$FOAM_SITE_APPBIN .../2.1.0/platforms/linux64GccDPOpt/bin no no
$FOAM_USER_APPBIN ...-2.1.0/platforms/linux64GccDPOpt/bin yes yes no
$WM_DIR .../openfoam-2.1.0/OpenFOAM-2.1.0/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...-2.1.0/platforms/linux64GccDPOpt/lib yes yes yes
$FOAM_SITE_LIBBIN .../2.1.0/platforms/linux64GccDPOpt/lib no no
$FOAM_USER_LIBBIN ...-2.1.0/platforms/linux64GccDPOpt/lib yes yes no
$MPI_ARCH_PATH ...0/platforms/linux64Gcc/openmpi-1.5.3 no yes
Third party software
Software Version Location
flex 2.5.35 /usr/bin/flex
gcc 4.3.4 /usr/bin/gcc
gzip 1.3.12 /usr/bin/gzip
tar 1.26 /bin/tar
icoFoam ...0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/icoFoam
Summary
Base configuration ok.
Critical systems ok.
Done
Can someone guide me to fix the problem?
Thank you in advance!
Best regards,
Ye
kiddmax is offline   Reply With Quote
Old   June 19, 2013, 04:17
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Your mpi libraries are not in your ld_library_path.
Did you install openmpi in third party or are you using your system package?
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   June 19, 2013, 05:20
Ye Zhang
Dear Laurence,
Thank you for your reply.
OpenFOAM works perfectly before I am trying to add utility foamToTecplot360. I added this utility maybe also added ThirdParty package (I can not remember.....). Because I remembered that there is no ThirdParty folder in my user folder before..... but now, there it is.
Hope this gave you some information. Thanks!
Best regards,
Ye
Old   June 19, 2013, 08:17
Give the outputs of:
echo $MPI_ARCH_PATH
echo $WM_MPLIB
echo $LD_LIBRARY_PATH | tr -s ' ' '\n'
locate libmpi.so
Old   June 19, 2013, 08:29
Ye Zhang
Dear Laurence,
First of all, thank you so much!
The output looks like:
echo $MPI_ARCH_PATH
/home/yzhang13/OpenFOAM/ThirdParty-2.1.0/platforms/linux64Gcc/openmpi-1.5.3
echo $WM_MPLIB
OPENMPI
/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/openmpi-1.5.3:/home/yzhang13/OpenFOAM/ThirdParty-2.1.0/platforms/linux64GccDPOpt/lib/openmpi-1.5.3:/home/yzhang13/OpenFOAM/ThirdParty-2.1.0/platforms/linux64Gcc/openmpi-1.5.3/lib:/home/yzhang13/OpenFOAM/yzhang13-2.1.0/platforms/linux64GccDPOpt/lib:/opt/apps/openfoam-2.1.0/site/2.1.0/platforms/linux64GccDPOpt/lib:/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib:/home/yzhang13/OpenFOAM/ThirdParty-2.1.0/platforms/linux64GccDPOpt/lib:/opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/dummy:/usr/lib64/mpi/gcc/openmpi/lib64:/usr/lib64/mpi/gcc/openmpi/lib64/
locate libmpi.so
/usr/lib64/mpi/gcc/openmpi/lib64/libmpi.so.0
/usr/lib64/mpi/gcc/openmpi/lib64/libmpi.so.0.0.3
Best regards,
Ye
Old   June 19, 2013, 14:38
It should be picked up then.
Does you $MPI_ARCH_PATH have anything in it? Your WM_MPLIB is OPENMPI so you should have openmpi installed in the ThirdParty folder. If you want to use the system openmpi libraries then change WM_MPLIB to SYSTEMOPENMPI.
Can you then also do:
ldd $(which icoFoam)
Old   June 20, 2013, 16:33
Retired Super Moderator
Bruno Santos
Greetings to all!
Just passing by to say that building foamToTecplot360 shouldn't have lead to such a big confusion
It would have been as simple as following the instructions provided here: https://github.com/wyldckat/localFoamToTecplot360
Best regards,
Bruno
Old   June 20, 2013, 18:48
Ye Zhang
Dear Laurence,
Sorry for the delay. Thanks! Today I tried to change WM_MPLIB to SYSTEMOPENMPI. But I can not edit /etc/bashrc file due to no permission(I can not change this situation in our faculty). Probably this means the original option is WM_MPLIB, am I right? So maybe this is no the reason result in this problem??
To be mentioned, I have also installed OpenFOAM-1.6-ext version, and it works good. I check /etc/bashrc file, and the option is SYSTEMOPENMPI..... So I am confused.....
By the way, I also check ldd $(which icoFoam) as you said, and it gives:
linux-vdso.so.1 => (0x00007fff75bff000)
libfiniteVolume.so => /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so (0x00007f2d8a209000)
libOpenFOAM.so => /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so (0x00007f2d89ae7000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007f2d8989e000)
libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00007f2d89593000)
libm.so.6 => /lib64/libm.so.6 (0x00007f2d8931a000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f2d89104000)
libc.so.6 => /lib64/libc.so.6 (0x00007f2d88d8c000)
libPstream.so => /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/openmpi-1.5.3/libPstream.so (0x00007f2d88b81000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f2d88964000)
libtriSurface.so => /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libtriSurface.so (0x00007f2d886ef000)
libmeshTools.so => /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libmeshTools.so (0x00007f2d8824d000)
libz.so.1 => /lib64/libz.so.1 (0x00007f2d88037000)
/lib64/ld-linux-x86-64.so.2 (0x00007f2d8b277000)
libmpi.so.1 => not found
libfileFormats.so => /opt/apps/openfoam-2.1.0/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfileFormats.so (0x00007f2d87e2e000)
Best regards,
Ye
Old   June 20, 2013, 18:53
Ye Zhang
Dear Bruno,
Thanks for your reply.
I am quite sure that OpenFOAM does not work after I tried to compile this utility as the guideline in this forum. Because of no permission as ordinary user in my office computer, I failed to compile it. After that, OpenFOAM stoped working....
Hope you can help me! Thanks!
Best regards,
Ye
Old   June 23, 2013, 11:55
Bruno Santos
Hi Ye,
If the "WM_THIRD_PARTY_DIR" variable is pointing to the "ThirdParty-2.1.0" folder in your home path, then you clearly modified something critical.
What changes have you made to the file "$HOME/.bashrc"? You can see the path to the file I'm talking about by running:
echo $HOME/.bashrc
Or did you add any files to the folder "$HOME/.OpenFOAM"?
Notice that this is a folder named ".OpenFOAM", not "OpenFOAM"!
Best regards,
Bruno
kiddmax likes this.
Old   June 24, 2013, 04:32
Ye Zhang
Dear Bruno,
Thanks for your help!
Indeed, there is folder under $HOME/.OpenFOAM which named 2.1.0, and there is a file 'prefs.sh' in it.
The phase in the file is:
export WM_THIRD_PARTY_DIR=/home/yzhang13/OpenFOAM/ThirdParty-2.1.0
Is it the reason which caused OpenFOAM does not work?
Thank you again, Bruno.
Best regards,
Ye
Old   June 24, 2013, 16:31
Bruno Santos
Hi Ye,
Yes, once you remove that file 'prefs.sh' and start a new terminal, OpenFOAM 2.1.0 should work properly once again.
As for foamToTecplot360, when you followed the instructions from here: https://github.com/wyldckat/localFoamToTecplot360 - at which step were you not able to follow?
Did you try the instructions from section "Using Zip or Tar"?
Best regards,
Bruno
Old   June 25, 2013, 02:56
Ye Zhang
Dear Bruno,
Thank you! OpenFOAM worked again after I removed the file!
I am not sure at which step I failed to install foamToTecplot360. I think that I don't have write permission on my office computer, because I have compiled it successfully on my own laptop.
Best regards,
Ye
how does the I/O work in OpenFOAM? goodkid OpenFOAM 8 October 27, 2011 11:39
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
OpenFOAM Training in Europe and USA hjasak OpenFOAM 0 August 8, 2008 05:33
OpenFOAM Training and Workshop Zagreb 2628Jan2006 hjasak OpenFOAM 1 February 2, 2006 21:07
