September 25, 2013, 07:33 |
fireFoam installation
Roman
Rep Power: 12 |
Hello all. I am new at the OpenFoam and fireFoam. OpenFoam is installed and works OK. There is a question about fireFoam. I downloaded the newest version, then cd fireFoam and run the command
~/fireFoam.1.7.x_0.4/solvers/fireFoam$ ./Allwmake Code:
~/fireFoam.1.7.x_0.4$ ./Allwmake Here are the results of starting compilation. Thanks Code:
vniipo@FF:~/fireFoam.1.7.x_0.4/solvers/fireFoam$ ./Allwmake + wmake libso thermophysicalModels/combustionModels SOURCE=eddyDissipationModel/eddyDissipationModel.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I./../../../../libs/thermophysicalModels/combustionModelsSpecies/lnInclude -I./../../../../libs/thermophysicalModels/reactionThermoNew/lnInclude -I/opt/openfoam221/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam221/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam221/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam221/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam221/src/OpenFOAM/lnInclude -I/opt/openfoam221/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/eddyDissipationModel.o In file included from ./../../../../libs/thermophysicalModels/combustionModelsSpecies/lnInclude/combustionModel.H:41:0, from eddyDissipationModel/eddyDissipationModel.H:41, from eddyDissipationModel/eddyDissipationModel.C:27: ./../../../../libs/thermophysicalModels/reactionThermoNew/lnInclude/hsCombustionThermo.H:39:28: fatal error: basicPsiThermo.H: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/eddyDissipationModel.o] Error 1 + wmake libso thermophysicalModels/radiation/submodels/absorptionEmissionModel/greyMeanAbsorptionEmissionSoot SOURCE=greyMeanAbsorptionEmissionSoot.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam221/src/finiteVolume/lnInclude -I/opt/openfoam221/src/thermophysicalModels/radiation/lnInclude -I/opt/openfoam221/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam221/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam221/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam221/src/OpenFOAM/lnInclude -I/opt/openfoam221/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/greyMeanAbsorptionEmissionSoot.o In file included from greyMeanAbsorptionEmissionSoot.C:26:0: greyMeanAbsorptionEmissionSoot.H:89:37: fatal error: absorptionEmissionModel.H: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/greyMeanAbsorptionEmissionSoot.o] Error 1 + wmake libso thermophysicalModels/radiation/derivedFvPatchFields/greyDiffusiveRadiation SOURCE=greyDiffusiveRadiationMixedFvPatchScalarField.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam221/src/finiteVolume/lnInclude -I/opt/openfoam221/src/thermophysicalModels/radiation/lnInclude -I/opt/openfoam221/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam221/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam221/src/meshTools/lnInclude -I../../../../../../libs/thermophysicalModels/basicSolidThermo/basicSolid/lnInclude -IlnInclude -I. -I/opt/openfoam221/src/OpenFOAM/lnInclude -I/opt/openfoam221/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/greyDiffusiveRadiationMixedFvPatchScalarField.o greyDiffusiveRadiationMixedFvPatchScalarField.C:31:35: fatal error: directMappedPatchBase.H: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/greyDiffusiveRadiationMixedFvPatchScalarField.o] Error 1 + wmake libso fvPatchFields SOURCE=alphaSgsBuoyantWallFunction/alphaSgsBuoyantWallFunctionFvPatchScalarField.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam221/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam221/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam221/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam221/src/triSurface/lnInclude -I/opt/openfoam221/src/meshTools/lnInclude -I/opt/openfoam221/src/finiteVolume/lnInclude -I/opt/openfoam221/src/turbulenceModels -I/opt/openfoam221/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/openfoam221/src/turbulenceModels/LES/LESfilters/lnInclude -I/opt/openfoam221/src/turbulenceModels/compressible/LES/lnInclude -IlnInclude -I. -I/opt/openfoam221/src/OpenFOAM/lnInclude -I/opt/openfoam221/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/alphaSgsBuoyantWallFunctionFvPatchScalarField.o alphaSgsBuoyantWallFunction/alphaSgsBuoyantWallFunctionFvPatchScalarField.C: In member function ‘virtual void Foam::compressible::LESModels::alphaSgsBuoyantWallFunctionFvPatchScalarField::evaluate(Foam::UPstream::commsTypes)’: alphaSgsBuoyantWallFunction/alphaSgsBuoyantWallFunctionFvPatchScalarField.C:189:49: error: no matching function for call to ‘Foam::basicThermo::Cp(const fvPatchScalarField&, const label&) const’ alphaSgsBuoyantWallFunction/alphaSgsBuoyantWallFunctionFvPatchScalarField.C:189:49: note: candidates are: /opt/openfoam221/src/thermophysicalModels/basic/lnInclude/basicThermo.H:333:41: note: virtual Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::basicThermo::Cp() const /opt/openfoam221/src/thermophysicalModels/basic/lnInclude/basicThermo.H:333:41: note: candidate expects 0 arguments, 2 provided /opt/openfoam221/src/thermophysicalModels/basic/lnInclude/basicThermo.H:336:38: note: virtual Foam::tmp<Foam::Field<double> > Foam::basicThermo::Cp(const scalarField&, const scalarField&, Foam::label) const /opt/openfoam221/src/thermophysicalModels/basic/lnInclude/basicThermo.H:336:38: note: candidate expects 3 arguments, 2 provided make: *** [Make/linux64GccDPOpt/alphaSgsBuoyantWallFunctionFvPatchScalarField.o] Error 1 + wmake libso fvPatchFieldsPyrolysis SOURCE=fixedIncidentRadiationCoupledMixed/fixedIncidentRadiationCoupledMixedFvPatchScalarField.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam221/src/finiteVolume/lnInclude -I/opt/openfoam221/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam221/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam221/src/meshTools/lnInclude -I/opt/openfoam221/src/turbulenceModels/compressible/RAS/lnInclude -I/opt/openfoam221/src/turbulenceModels/compressible/LES/lnInclude -I/opt/openfoam221/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/openfoam221/src/turbulenceModels//LES/LESfilters/lnInclude -I/opt/openfoam221/src/turbulenceModels -I/opt/openfoam221/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam221/src/thermophysicalModels/chemistryModel/lnInclude -I../thermophysicalModels/reactionThermo/lnInclude -I./../../../libs/thermophysicalModels/reactionThermoNew/lnInclude -I/opt/openfoam221/src/thermophysicalModels/radiation/lnInclude -IlnInclude -I. -I/opt/openfoam221/src/OpenFOAM/lnInclude -I/opt/openfoam221/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/fixedIncidentRadiationCoupledMixedFvPatchScalarField.o fixedIncidentRadiationCoupledMixed/fixedIncidentRadiationCoupledMixedFvPatchScalarField.C:31:35: fatal error: directMappedPatchBase.H: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/fixedIncidentRadiationCoupledMixedFvPatchScalarField.o] Error 1 + wmake libso functionObjects SOURCE=faceZonesIntegration/faceZonesIntegrationFunctionObject.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam221/src/finiteVolume/lnInclude -I/opt/openfoam221/src/meshTools/lnInclude -I/opt/openfoam221/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam221/src/OpenFOAM/lnInclude -I/opt/openfoam221/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/faceZonesIntegrationFunctionObject.o In file included from /opt/openfoam221/src/OpenFOAM/lnInclude/OutputFilterFunctionObject.H:225:0, from faceZonesIntegration/faceZonesIntegrationFunctionObject.H:41, from faceZonesIntegration/faceZonesIntegrationFunctionObject.C:27: /opt/openfoam221/src/OpenFOAM/lnInclude/OutputFilterFunctionObject.C: In member function ‘bool Foam::OutputFilterFunctionObject<OutputFilter>::timeSet() [with OutputFilter = Foam::faceZonesIntegration]’: faceZonesIntegration/faceZonesIntegrationFunctionObject.C:41:1: instantiated from here /opt/openfoam221/src/OpenFOAM/lnInclude/OutputFilterFunctionObject.C:215:9: error: ‘class Foam::faceZonesIntegration’ has no member named ‘timeSet’ /opt/openfoam221/src/OpenFOAM/lnInclude/OutputFilterFunctionObject.C: In member function ‘void Foam::OutputFilterFunctionObject<OutputFilter>::movePoints(const Foam::polyMesh&) [with OutputFilter = Foam::faceZonesIntegration]’: faceZonesIntegration/faceZonesIntegrationFunctionObject.C:41:1: instantiated from here /opt/openfoam221/src/OpenFOAM/lnInclude/OutputFilterFunctionObject.C:268:9: error: no matching function for call to ‘Foam::faceZonesIntegration::movePoints(const Foam::polyMesh&)’ /opt/openfoam221/src/OpenFOAM/lnInclude/OutputFilterFunctionObject.C:268:9: note: candidate is: faceZonesIntegration/faceZonesIntegration.H:167:22: note: virtual void Foam::faceZonesIntegration::movePoints(const pointField&) faceZonesIntegration/faceZonesIntegration.H:167:22: note: no known conversion for argument 1 from ‘const Foam::polyMesh’ to ‘const pointField& {aka const Foam::Field<Foam::Vector<double> >&}’ In file included from /opt/openfoam221/src/OpenFOAM/lnInclude/OutputFilterFunctionObject.C:27:0, from /opt/openfoam221/src/OpenFOAM/lnInclude/OutputFilterFunctionObject.H:225, from faceZonesIntegration/faceZonesIntegrationFunctionObject.H:41, from faceZonesIntegration/faceZonesIntegrationFunctionObject.C:27: /opt/openfoam221/src/OpenFOAM/lnInclude/IOOutputFilter.H: In member function ‘void Foam::IOOutputFilter<OutputFilter>::movePoints(const Foam::polyMesh&) [with OutputFilter = Foam::faceZonesIntegration]’: faceZonesIntegration/faceZonesIntegrationFunctionObject.C:41:1: instantiated from here /opt/openfoam221/src/OpenFOAM/lnInclude/IOOutputFilter.H:139:13: error: no matching function for call to ‘Foam::IOOutputFilter<Foam::faceZonesIntegration>::movePoints(const Foam::polyMesh&)’ /opt/openfoam221/src/OpenFOAM/lnInclude/IOOutputFilter.H:139:13: note: candidate is: faceZonesIntegration/faceZonesIntegration.H:167:22: note: virtual void Foam::faceZonesIntegration::movePoints(const pointField&) faceZonesIntegration/faceZonesIntegration.H:167:22: note: no known conversion for argument 1 from ‘const Foam::polyMesh’ to ‘const pointField& {aka const Foam::Field<Foam::Vector<double> >&}’ make: *** [Make/linux64GccDPOpt/faceZonesIntegrationFunctionObject.o] Error 1 + wmake SOURCE=fireFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I./include -I./../../libs/thermophysicalModels/combustionModelsSpecies/lnInclude -I./../../libs/regionModels/regionModel/lnInclude -I./../../libs/regionModels/surfaceFilmModels/lnInclude -I./../../libs/regionModels/pyrolysisModels/lnInclude -I./../../libs/lagrangian/intermediateNew/lnInclude -I./../../libs/thermophysicalModels/reactionThermoNew/lnInclude -I./../../libs/thermophysicalModels/SLGThermo/lnInclude -I./../../libs/thermophysicalModels/chemistryModelNew/lnInclude -I./../../libs/thermophysicalModels/basicSolidThermo/basicSolid/lnInclude -I./../../libs/thermophysicalModels/basicSolidThermo/chemistryModel/lnInclude -I/opt/openfoam221/src/lagrangian/basic/lnInclude -I/opt/openfoam221/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam221/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam221/src/finiteVolume/lnInclude -I/opt/openfoam221/src/meshTools/lnInclude -I/opt/openfoam221/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam221/src/thermophysicalModels/liquids/lnInclude -I/opt/openfoam221/src/thermophysicalModels/liquidMixture/lnInclude -I/opt/openfoam221/src/thermophysicalModels/solids/lnInclude -I/opt/openfoam221/src/thermophysicalModels/solidMixture/lnInclude -I/opt/openfoam221/src/thermophysicalModels/radiation/lnInclude -I/opt/openfoam221/src/thermophysicalModels/thermophysicalFunctions/lnInclude -I/opt/openfoam221/src/ODE/lnInclude -IlnInclude -I. -I/opt/openfoam221/src/OpenFOAM/lnInclude -I/opt/openfoam221/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/fireFoam.o In file included from fireFoam.C:34:0: ./../../libs/thermophysicalModels/reactionThermoNew/lnInclude/hsCombustionThermo.H:39:28: fatal error: basicPsiThermo.H: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/fireFoam.o] Error 1 Last edited by wyldckat; September 27, 2013 at 21:04. Reason: Added [CODE][/CODE] |
September 25, 2013, 09:37 |
Roman
Rep Power: 12 |
The first problem arises because of using openFoam 2.2.1. All needed files are in openFoam-2.1.1. But I have now one more problem. Help to resolve if possible please.
vniipo@FF:~/fireFoam.1.7.x_0.4/solvers/fireFoam$ ./Allwmake + wmake libso thermophysicalModels/combustionModels make: *** No rule to make target `/opt/openfoam211/src/OpenFOAM/lnInclude/debugName.H', needed by `infinitelyFastChemistryExplicit/infinitelyFastChemistryExplicit.dep'. Stop. + wmake libso thermophysicalModels/radiation/submodels/absorptionEmissionModel/greyMeanAbsorptionEmissionSoot make: *** No rule to make target `/opt/openfoam211/src/OpenFOAM/lnInclude/debugName.H', needed by `greyMeanAbsorptionEmissionSoot.dep'. Stop. + wmake libso thermophysicalModels/radiation/derivedFvPatchFields/greyDiffusiveRadiation make: *** No rule to make target `/opt/openfoam211/src/OpenFOAM/lnInclude/debugName.H', needed by `greyDiffusiveRadiationMixedFvPatchScalarField.dep'. Stop. + wmake libso fvPatchFields make: *** No rule to make target `/opt/openfoam211/src/OpenFOAM/lnInclude/debugName.H', needed by `uniformDensityHydrostaticTotalPressureFvPatchScalarField/uniformDensityHydrostaticTotalPressureFvPatchScalarField.dep'. Stop. + wmake libso fvPatchFieldsPyrolysis make: *** No rule to make target `/opt/openfoam211/src/OpenFOAM/lnInclude/debugName.H', needed by `flowRateInletVelocityFuelConvertCoupled/flowRateInletVelocityFuelConvertCoupledFvPatchVectorField.dep'. Stop. + wmake libso functionObjects make: *** No rule to make target `/opt/openfoam211/src/OpenFOAM/lnInclude/debugName.H', needed by `faceZonesIntegration/faceZonesIntegrationFunctionObject.dep'. Stop. + wmake make: *** No rule to make target `/opt/openfoam211/src/OpenFOAM/lnInclude/debugName.H', needed by `fireFoam.dep'. Stop. Last edited by wyldckat; September 27, 2013 at 21:05. Reason: Added [CODE][/CODE] |
September 27, 2013, 03:05 |
Roman
Rep Power: 12 |
Sorry, I must use only openFoam-1.7.x.....
Health and good luck to all. Good bay |
firefoam;installation |
How to setup a proper "heatFlux" boundary for fireFoam? | Jumping | OpenFOAM Pre-Processing | 0 | March 27, 2013 09:27 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Installation problems | indy | OpenFOAM Installation | 7 | April 3, 2009 09:40 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Installation problems | shellbell1999 | OpenFOAM Installation | 9 | April 6, 2006 13:29 |
