Operating Systems
Old   September 8, 2013, 13:05
Default Operating Systems
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
I want to set up a cluster for my CFD work.
Using Ubuntu the last 4 years but are there performance advantages if I use redhat or suse linux?
Thanks in advance
Tobi
Tobi is offline   Reply With Quote
Old   September 11, 2013, 16:48
Retired Super Moderator
Bruno Santos
Hi Tobi,
From what I know, there isn't much difference in performance between Linux Distributions. Usually what weighs more on the choice for cluster operating systems is the maintenance, stability and security, as well as compatibility with the hardware.
Usually the main Linux Distributions for clusters are (not in order):
Anything beyond these distributions theoretically means that you should upgrade the Linux Distribution on your cluster every 6 to 24 months.
While with the distributions on the list above, you can maintain the same installation for 5 or more years. And in the case of Debian, you can easily upgrade from one stable version to the next one.
Best regards,
Bruno
Mixture Model and operating density RodriguezFatz FLUENT 5 February 20, 2019 02:16
Optimizing the solution of tridiagonal linear systems CCKM Main CFD Forum 14 March 14, 2012 07:40
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Operating Systems and CFX-5 cfd guy CFX 2 March 5, 2003 17:47
Operating Systems for PC Erich CFX 1 January 9, 2002 20:30
