Problem installing pythonFlu
Hi Foamers!
First, thank you for developing a tool that merges Python and OpenFOAM. So now i want to use pythonFlu with OpenFoam-2.1.x. So i have downloaded all the sources and startet installing them as described here. The problem is mainly, that when i try to run the configure-script of managedFlu there is an error regarding C++ compiler. It states as follows: Quote:
So i don't figure it out how the skript tests, if the compiler works. Can i test it manually otherwise? My modified env.sh just make a path to some local directory for confFlu, where it is installed. My OpenFoam-2.1.x-bashrc should also work. Can someone help me with that? I am using a Debian Wheezy system (hopefully i'll need just some extra packages ;-) ) Best regards, Christoph |
Can you compile OpenFOAM itself (or your own solvers/tools)? Do have different compilers installed?
I tried to compile pythonFlu for OpenFOAM 2.2.1 and this didn't work very well (I had to exclude a lot of files). Probably the latest supported version 2.0.x. |
Because i'm not familiar with pure C++-Programming i hope the follwing outputs answers your question: Code:
g++ --version Quote:
ls -l gcc* Quote:
Is this some useful information :)? I think the latest supported OpenFOAM-version is 2.1.x as stated here. Best regards |
I think these posts might help with the selection of gcc versions in Debian:
http://lektiondestages.blogspot.de/2...-versions.html http://lukas.ahrenberg.se/archives/154 |
