Problem compiling Paraview (Thirdparty)
Hi all,
I try to compile paraview-3.12.0 which comes with the thirdparty. While compilation I get the following error message: Code:
-- Configuring development install... Code:
-- The C compiler identification is GNU Thanks in advance Tobi |
Hi Tobi,
I don't know if you've already fixed this problem or not, but if not, I'm able to give a better suggestion/solution/fix if I knew which Linux Distribution and version you are using in this case ;) In addition, are you certain that you've already installed the correct graphics card drivers? Best regards, Bruno |
Hi Bruno,
Could you please help me out? I've the same problem as Tobi. Error messages are appended to this mail. My linux version is Code:
:~$ lsb_release -a Code:
:~$ lshw -c video J Code:
CMake Error: The following variables are used in this project, but they are set to NOTFOUND. Quote:
Greetings Johny,
You're using the Nouveau drivers, which are open source. I don't know how good they are nowadays, but my suggestion is that you install the NVidia drivers (not open source :(), which officially support 3D performance with NVidia graphics cards. After you've managed to install the NVidia drivers, the makeParaView or makeParaView4 scripts should work as intended. Best regards, Bruno |
Hi Bruno,
Thanks for the reply. Its getting more confusing when it comes to find the right driver for my computer. Could you please let me know which one is the right NVIDIA driver for my processor and version of ubuntu. And if you direct me where to find it would also be great help. ~$ lspci | grep VGA 01:00.0 VGA compatible controller: NVIDIA Corporation G96 [GeForce 9500 GT] (rev a1) ~$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu Trusty Tahr (development branch) Release: 14.04 Codename: trusty Looking forward to your reply. Cheers, J Quote:
Hi Johny,
Ubuntu 14.04 is still in beta stage, so it's probably not yet very stable. But anyway, this page should explain how to install the official NVidia drivers for Ubuntu: http://askubuntu.com/a/307478 The actual driver model needed for your card should automatically be installed this way. Best regards, Bruno |
Hi Bruno,
Thanks again for the quick reply. It was pretty difficult to still get the drivers installed and as you said I thought it would be a better idea to start do do the whole process in a new installation. I installed the new stable version of ubuntu Code:
:~$ lsb-release -a Code:
~$ lshw -c video http://openfoamwiki.net/index.php/In...M-2.2.0/Ubuntu After completing the step 8 with the command wmSET $FOAM_SETTINGS I still get the error as below Code:
Warning in /home/user/OpenFOAM/OpenFOAM-2.2.0/etc/config/settings.sh: I moved the gcc-4.5.2 to /home/user/OpenFOAM/ThirdParty-2.2.0/platforms/linux64/ And then as expected there was no error and continued till building the openFOAM without any issues. The build log has errors(seeming due to the change I made above) as follows... Code:
ollect2: error: ld returned 1 exit status Cheers, J Quote:
Hi Johny,
I'm glad the NVidia drivers have been installed with success. But I think you got lost in the instructions for installing OpenFOAM, because: Quote:
Please be very careful in following the instructions, since any mistake, no matter how small, can result it not reaching a successful installation :( You might ask why this is so hard and detailed. The answer is simple: because OpenFOAM is at a similar level of detail, therefore you should learn to keep a very close attention to all details when installing and using OpenFOAM ;) Best regards, Bruno |
Hi Bruno,
The complete OF installation works now :-) Thanks a lot. Cheers, J Quote:
1 Attachment(s)
Hi Bruno,
I got yet another problem. Right after my installation I had opened an stl geometry and viewed it properly in paraview. I don't know what changes I made, but now I simply can't view the same stl file. The file opens and instead of a 3D geometry I see just a line. I'm sure its some settings issue. Could you please provide some insight? Please see the screenshot. Cheers, J Quote:
Hi Bruno,
I figured it out that the stl file was in the plain text format and after conversion to binary it worked. But still wondering how it worked couple of days ago after which the file was never altered. Anyway now it works. Cheers, J Quote:
