OF 2.2.1 installation error on dependencies in Ubuntu 12.04
Like Tree3Likes
  • 1 Post By skyinventorbt
  • 1 Post By wyldckat
Old   October 8, 2013, 19:13
Default OF 2.2.1 installation error on dependencies in Ubuntu 12.04
immortality's Avatar
Ehsan
immortality is on a distinguished road
this error is shown when I want to install 2.2.1 version of OF.
ehsan@Ehsan:~$ sudo apt-get install openfoam221
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 openfoam221 : Depends: g++ but it is not installable
               Depends: libreadline-dev but it is not installable
               Depends: libopenmpi1.3 but it is not going to be installed
               Depends: libptscotch-5.1 but it is not going to be installed
               Depends: flex
               Depends: libscotch-dev but it is not going to be installed
               Depends: libopenmpi-dev but it is not going to be installed
               Depends: libxt-dev but it is not going to be installed
               Depends: openmpi-bin but it is not going to be installed
               Recommends: libptscotch-dev but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
how can solve broken packages?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   October 9, 2013, 01:25
Default OpenFOAM 2.2.1 for Ubuntu 12.04
skyinventorbt's Avatar
Dr. B T KANNAN
skyinventorbt is on a distinguished road
I have installed and found this way is best for Ubuntu12.04
Simple solution for Ubuntu 12.04 !!
Based on architecture i.e. u must have 64bit so download these two
http://www.openfoam.org/download/ubu..._0-1_amd64.deb
Use this syntax to install(In terminal type and press enter)
  • dpkg -i openfoam221_0-1_amd64.deb
  • dpkg -i paraviewopenfoam3120_0-1_amd64.deb
KANNAN
immortality likes this.
skyinventorbt is offline   Reply With Quote
Old   October 9, 2013, 03:37
Ehsan
hi Kannan
Thanks for quick reply,
Can install paravaiew 14 instead of 13?
Old   October 9, 2013, 07:09
Ehsan
I followed what you said,but it has some troubles:
root@Ehsan:~/Desktop# dpkg -i openfoam221_0-1_amd64.deb
Selecting previously unselected package openfoam221.
(Reading database ... 183847 files and directories currently installed.)
Unpacking openfoam221 (from openfoam221_0-1_amd64.deb) ...
dpkg: dependency problems prevent configuration of openfoam221:
 openfoam221 depends on csh; however:
  Package csh is not installed.
 openfoam221 depends on g++; however:
  Package g++ is not installed.
 openfoam221 depends on libreadline-dev; however:
  Package libreadline-dev is not installed.
 openfoam221 depends on libopenmpi1.3; however:
  Package libopenmpi1.3 is not installed.
 openfoam221 depends on libptscotch-5.1; however:
  Package libptscotch-5.1 is not installed.
 openfoam221 depends on libscotch-5.1; however:
  Package libscotch-5.1 is not installed.
 openfoam221 depends on binutils-dev; however:
  Package binutils-dev is not installed.
 openfoam221 depends on flex; however:
  Package flex is not installed.
 openfoam221 depends on libscotch-dev; however:
  Package libscotch-dev is not installed.
 openfoam221 depends on libopenmpi-dev; however:
  Package libopenmpi-dev is not installed.
 openfoam221 depends on libxt-dev; however:
  Package libxt-dev is not installed.
 openfoam221 depends on openmpi-bin; however:
  Package openmpi-bin is not installed.
dpkg: error processing openfoam221 (--install):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
 openfoam221
Old   October 9, 2013, 08:36
Dr. B T KANNAN
Dear Eshan,
Yesterday one of my friend(Who does not know what OpenFOAM is and wants to learn it) also installed by the method I said. He did not find any error like this, as he said.
I never use paraview from the second package i.e. paraviewopenfoam221.
Instead I use paraview 4.0.1(Latest Version)
Please see this link
http://askubuntu.com/questions/14024...t-dependencies
KANNAN
Last edited by skyinventorbt; October 9, 2013 at 08:45. Reason: Addition of a link
Old   October 9, 2013, 11:46
Ehsan
thanks,OpenFOAM installed correctly but paraview shows some errors:
root@Ehsan:~/Desktop# dpkg -i paraviewopenfoam3120_0-1_amd64.deb
Selecting previously unselected package paraviewopenfoam3120.
(Reading database ... 246741 files and directories currently installed.)
Unpacking paraviewopenfoam3120 (from paraviewopenfoam3120_0-1_amd64.deb) ...
dpkg: dependency problems prevent configuration of paraviewopenfoam3120:
 paraviewopenfoam3120 depends on qt4-dev-tools; however:
  Package qt4-dev-tools is not installed.
dpkg: error processing paraviewopenfoam3120 (--install):
Old   October 9, 2013, 12:19
Ehsan
I used this command:
sudo apt-get -f install
now the error on paraview is this:
root@Ehsan:~# dpkg -i paraviewopenfoam3120_0-1_amd64.deb
dpkg: error processing paraviewopenfoam3120_0-1_amd64.deb (--install):
 cannot access archive: No such file or directory
is there any comment?
Old   October 10, 2013, 01:32
Default qt4 using apt-get
Dr. B T KANNAN
Dear Eshan,
You can install qt4-dev-tools using apt-get
and then try
KANNAN
Old   October 19, 2013, 16:17
Retired Super Moderator
Bruno Santos
Greetings to all!
Most of the installation problems reported on this thread should be fixed if you follow the instructions on this post: http://www.cfd-online.com/Forums/lou...tml#post457831 - post #6
Best regards,
Bruno
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 23:24
Openfoam Ubuntu 12.04 Unmet dependencies slls33 OpenFOAM Installation 10 April 9, 2013 05:16
Trouble shooting about OpenFOAM installation in Ubuntu 12.04 Nait OpenFOAM Installation 2 December 12, 2012 11:20
Installation on Ubuntu 12.04 LTS samiam1000 OpenFOAM Installation 11 May 26, 2012 06:54
Openfoam 2.1 installation in ubuntu 12.04 jsm OpenFOAM Installation 11 May 7, 2012 05:56
