Cannot configure OpenFOAM environment variable in CAE Linux 2011 |
October 12, 2013, 14:21 |
#1 | |
Tommi P. Laiho
Rep Power: 12 |
I try to set environment variable for OpenFOAM 2.0.1 in CAE Linux 2011 which is Ubuntu 10.04 LTS. I try to accurately follow the instructions according to OpenFOAM pages but I am not able to create functional environment variable for OpenFOAM. I have used instructions as follows: Quote:
October 12, 2013, 14:58 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Tommi and welcome to the forum!
A quick question: did you install OpenFOAM 2.0.1 from OpenFOAM's website, or are you using the installation already provided with CAELinux? Best regards, Bruno
October 12, 2013, 15:12 |
Tommi P. Laiho
Rep Power: 12 |
The OpenFOAM 2.0.1. is a default installation what came within the CAE Linux. The installation is fresh except I removed open java and installed Sun Java 8 to my Ubuntu.
October 12, 2013, 15:23 |
Bruno Santos
Rep Power: 128 |
Unfortunately I don't a CAELinux installation at hand, but according to this post of mine: http://www.cfd-online.com/Forums/ope...tml#post376326 post #26 - it looks like that CAELinux provides OpenFOAM 2.1.0?
Try these two commands: Code:
ls -l /opt/openfoam201 ls -l /opt/openfoam210
October 12, 2013, 23:26 |
#5 | ||
Tommi P. Laiho
Rep Power: 12 |
The OpenFOAM 2.0.1 is present but 2.1.0 is not. I have tried to install 2.1.0 but the problem was same...no environments set. Here is the result of the command ls -l /opt/openfoam201: Quote:
October 13, 2013, 00:51 |
#6 | ||
Tommi P. Laiho
Rep Power: 12 |
I tested the installation DVD with a md5 testers just for fun. There were no errors in the installation disk.
I also run: Quote:
October 13, 2013, 04:29 |
Bruno Santos
Rep Power: 128 |
Hi Tommi,
CAE Linux was designed to make it easier for people to use the software provided with it. Therefore, at the very least, they provide the following capabilities for using OpenFOAM:
Best regards, Bruno
October 13, 2013, 04:55 |
#8 | |
Tommi P. Laiho
Rep Power: 12 |
I just wonder why it says that environment variable is not set when I test it. Is it somehow unusable command in Ubuntu? I tested this OpenFoam terminal with Code:
icoFoam -help Quote:
October 13, 2013, 04:58 |
#9 |
Bruno Santos
Rep Power: 128 |
The OpenFOAM 2.0.1 installation provided in CAE Linux was done from the Deb packages that are provided at openfoam.org, which is why foamInstallationTest doesn't work.
This is because the foamInstallationTest script was created for testing the environment where OpenFOAM is built by the user and therefore doesn't work on pre-built installations.
October 15, 2013, 08:44 |
#10 |
Franco Marra
Rep Power: 17 |
Dear Tommy,
CAELinux is configured with a special terminal for OpenFOAM. You will find it under Applications -> CAELinux . You have to open this terminal to have the environment correctly configured. Regards, Franco |
Display Modes | |
OpenFOAM 1.7 installation on Redhat linux | maxims | OpenFOAM Installation | 2 | November 30, 2012 04:29 |
OpenFoam Installation in Redhat Enterprise linux 5 | sahm | OpenFOAM Installation | 78 | November 1, 2011 15:22 |
Problems with installation of OpenFoam | sheyer | OpenFOAM Installation | 8 | July 28, 2008 03:45 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
Installing OpenFOAM on SuSE Linux 91 | Lars Edvardsen (Edvardsen) | OpenFOAM Installation | 2 | January 10, 2005 02:26 |
