OF 2.2.1 installation error on dependencies in Ubuntu 12.04 |
October 8, 2013, 19:13 |
Ehsan
Rep Power: 26 |
this error is shown when I want to install 2.2.1 version of OF.
ehsan@Ehsan:~$ sudo apt-get install openfoam221 Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: openfoam221 : Depends: g++ but it is not installable Depends: libreadline-dev but it is not installable Depends: libopenmpi1.3 but it is not going to be installed Depends: libptscotch-5.1 but it is not going to be installed Depends: flex Depends: libscotch-dev but it is not going to be installed Depends: libopenmpi-dev but it is not going to be installed Depends: libxt-dev but it is not going to be installed Depends: openmpi-bin but it is not going to be installed Recommends: libptscotch-dev but it is not going to be installed E: Unable to correct problems, you have held broken packages.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
October 9, 2013, 01:25 |
OpenFOAM 2.2.1 for Ubuntu 12.04
Dr. B T KANNAN
Rep Power: 14 |
I have installed and found this way is best for Ubuntu12.04
Simple solution for Ubuntu 12.04 !! Based on architecture i.e. u must have 64bit so download these two ------------------------------------------------------------------------------------------------------------- http://www.openfoam.org/download/ubu..._0-1_amd64.deb --------------------------------------------------------------------------------------------------------------- http://www.openfoam.org/download/ubu..._0-1_amd64.deb ---------------------------------------------------------------------------------------------------------------- Use this syntax to install(In terminal type and press enter)
KANNAN |
October 9, 2013, 03:37 |
Ehsan
Rep Power: 26 |
hi Kannan
Thanks for quick reply, Can install paravaiew 14 instead of 13?
October 9, 2013, 07:09 |
Ehsan
Rep Power: 26 |
I followed what you said,but it has some troubles:
root@Ehsan:~/Desktop# dpkg -i openfoam221_0-1_amd64.deb Selecting previously unselected package openfoam221. (Reading database ... 183847 files and directories currently installed.) Unpacking openfoam221 (from openfoam221_0-1_amd64.deb) ... dpkg: dependency problems prevent configuration of openfoam221: openfoam221 depends on csh; however: Package csh is not installed. openfoam221 depends on g++; however: Package g++ is not installed. openfoam221 depends on libreadline-dev; however: Package libreadline-dev is not installed. openfoam221 depends on libopenmpi1.3; however: Package libopenmpi1.3 is not installed. openfoam221 depends on libptscotch-5.1; however: Package libptscotch-5.1 is not installed. openfoam221 depends on libscotch-5.1; however: Package libscotch-5.1 is not installed. openfoam221 depends on binutils-dev; however: Package binutils-dev is not installed. openfoam221 depends on flex; however: Package flex is not installed. openfoam221 depends on libscotch-dev; however: Package libscotch-dev is not installed. openfoam221 depends on libopenmpi-dev; however: Package libopenmpi-dev is not installed. openfoam221 depends on libxt-dev; however: Package libxt-dev is not installed. openfoam221 depends on openmpi-bin; however: Package openmpi-bin is not installed. dpkg: error processing openfoam221 (--install): dependency problems - leaving unconfigured Errors were encountered while processing: openfoam221
October 9, 2013, 08:36 |
Dr. B T KANNAN
Rep Power: 14 |
Dear Eshan,
Yesterday one of my friend(Who does not know what OpenFOAM is and wants to learn it) also installed by the method I said. He did not find any error like this, as he said. I never use paraview from the second package i.e. paraviewopenfoam221. Instead I use paraview 4.0.1(Latest Version) Please see this link http://askubuntu.com/questions/14024...t-dependencies -- KANNAN Last edited by skyinventorbt; October 9, 2013 at 08:45. Reason: Addition of a link |
October 9, 2013, 11:46 |
Ehsan
Rep Power: 26 |
thanks,OpenFOAM installed correctly but paraview shows some errors:
root@Ehsan:~/Desktop# dpkg -i paraviewopenfoam3120_0-1_amd64.deb Selecting previously unselected package paraviewopenfoam3120. (Reading database ... 246741 files and directories currently installed.) Unpacking paraviewopenfoam3120 (from paraviewopenfoam3120_0-1_amd64.deb) ... dpkg: dependency problems prevent configuration of paraviewopenfoam3120: paraviewopenfoam3120 depends on qt4-dev-tools; however: Package qt4-dev-tools is not installed. dpkg: error processing paraviewopenfoam3120 (--install): dependency problems - leaving unconfigured Errors were encountered while processing: paraviewopenfoam3120
October 9, 2013, 12:19 |
Ehsan
Rep Power: 26 |
I used this command:
sudo apt-get -f install Code:
root@Ehsan:~# dpkg -i paraviewopenfoam3120_0-1_amd64.deb dpkg: error processing paraviewopenfoam3120_0-1_amd64.deb (--install): cannot access archive: No such file or directory Errors were encountered while processing: paraviewopenfoam3120_0-1_amd64.deb
October 10, 2013, 01:32 |
qt4 using apt-get
#8 | |
Dr. B T KANNAN
Rep Power: 14 |
You can install qt4-dev-tools using apt-get and then try dpkg -i paraviewopenfoam3120_0-1_amd64.deb -- KANNAN |
October 19, 2013, 16:17 |
#9 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Most of the installation problems reported on this thread should be fixed if you follow the instructions on this post: http://www.cfd-online.com/Forums/lou...tml#post457831 - post #6 Best regards, Bruno
Display Modes | |
FLUENT installation on UBUNTU 12.04 (LTS) | teymourj | FLUENT | 2 | March 1, 2017 23:24 |
Openfoam Ubuntu 12.04 Unmet dependencies | slls33 | OpenFOAM Installation | 10 | April 9, 2013 05:16 |
Trouble shooting about OpenFOAM installation in Ubuntu 12.04 | Nait | OpenFOAM Installation | 2 | December 12, 2012 11:20 |
Installation on Ubuntu 12.04 LTS | samiam1000 | OpenFOAM Installation | 11 | May 26, 2012 06:54 |
Openfoam 2.1 installation in ubuntu 12.04 | jsm | OpenFOAM Installation | 11 | May 7, 2012 05:56 |
