October 23, 2013, 04:01 |
How to setup a simple OpenFOAM cluster?
Tommi P. Laiho
Rep Power: 12 |
I have been trying to find a tutorial how to setup a simple OpenFOAM cluster. I have two 8 core computers and OpenMPI, OpenFOAM and Paraview are successfully installed to these two computers. I am using Ubuntu Studio 12.04 and Ubuntu CAELinux 10.04 as platforms. The computers are connected with a common router. I have not found a simple Linux novice tutorial how to connect these two computers and make a simple two computers cluster of these two machines. The tutorial should be really a novice guide, a step by step tutorial. Few questions: 1. Does the OpenFOAM installation need to be exactly same version in both machines? I have OpenFOAM 2.2.2 in Ubuntu Studio 12.04 and OpenFOAM 2.1.1 in Ubuntu 10.04 CAELinux. Will I face problems with this combination, I mean Ubuntu CAELinux is a master machine and Ubuntu Studio 12.04 is a slave machine. Maybe upper release can run lower release files? The OpenMPI is also lower version 1.4.1 in CAELinux which is a master and 1.5 in a slave machine. 2. The router what I use is not bridged. I have same ip in every machine. Is this a problem? Please help and thanks in advance. |
October 25, 2013, 08:41 |
#2 | |
Then you may setup MPI and check that it's working properly |
October 27, 2013, 07:53 |
Tommi P. Laiho
Rep Power: 12 |
I have been trying to setup Open MPI with OpenFOAM211. I have compiled the Open MPI by myself but it went very smoothly so I guess the compilation went correctly. However I am not a true expert of the field. I have a bridged modem having different IP's with different machines right now. I should at first connect two computers with Open MPI in order to run 14 cores with OpenFOAM 211. The OpenFOAM 211 is same version now in both computers which I will call as master and slave and also OpenMPI is same in both computers. This time master machine is CAELinux Ubuntu 10.04 LTS and slave is Ubuntu Studio 12.04 LTS. I have read many articles and also FAQ but now I cant progress any more by myself, I need some help. Thank you for understanding. So when I run this code: Code:
/opt/openmpi-1.6.5/bin/mpirun -hostfile /home/tommi2/Desktop/machinefile -np 14 /opt/openfoam211/platforms/linux*/bin/pisoFoam -parallel Code:
/opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam: error while loading shared libraries: libincompressibleTurbulenceModel.so: cannot open shared object file: No such file or directory /opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam: error while loading shared libraries: libincompressibleTurbulenceModel.so: cannot open shared object file: No such file or directory /opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam: error while loading shared libraries: libincompressibleTurbulenceModel.so: cannot open shared object file: No such file or directory /opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam: error while loading shared libraries: libincompressibleTurbulenceModel.so: cannot open shared object file: No such file or directory /opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam: error while loading shared libraries: libincompressibleTurbulenceModel.so: cannot open shared object file: No such file or directory /opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam: error while loading shared libraries: libincompressibleTurbulenceModel.so: cannot open shared object file: No such file or directory /opt/openfoam211/platforms/linux64GccDPOpt/bin/pisoFoam: error while loading shared libraries: libincompressibleTurbulenceModel.so: cannot open shared object file: No such file or directory [caelinux:05633] [[49395,1],1] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/util/nidmap.c at line 371 [caelinux:05633] [[49395,1],1] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../orte/mca/ess/base/ess_base_nidmap.c at line 62 [caelinux:05633] [[49395,1],1] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../../orte/mca/ess/env/ess_env_module.c at line 173 -------------------------------------------------------------------------- It looks like orte_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during orte_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): orte_ess_base_build_nidmap failed --> Returned value Data unpack would read past end of buffer (-26) instead of ORTE_SUCCESS -------------------------------------------------------------------------- -------------------------------------------------------------------------- It looks like orte_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during orte_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): orte_ess_set_name failed --> Returned value Data unpack would read past end of buffer (-26) instead of ORTE_SUCCESS -------------------------------------------------------------------------- [caelinux:05633] [[49395,1],1] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/runtime/orte_init.c at line 132 -------------------------------------------------------------------------- It looks like MPI_INIT failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during MPI_INIT; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): ompi_mpi_init: orte_init failed --> Returned "Data unpack would read past end of buffer" (-26) instead of "Success" (0) -------------------------------------------------------------------------- *** An error occurred in MPI_Init *** before MPI was initialized *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort) [caelinux:5633] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! *** An error occurred in MPI_Init *** before MPI was initialized *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort) [caelinux:5634] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! [caelinux:05634] [[49395,1],3] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/util/nidmap.c at line 371 [caelinux:05634] [[49395,1],3] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../orte/mca/ess/base/ess_base_nidmap.c at line 62 [caelinux:05634] [[49395,1],3] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../../orte/mca/ess/env/ess_env_module.c at line 173 [caelinux:05634] [[49395,1],3] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/runtime/orte_init.c at line 132 -------------------------------------------------------------------------- It looks like MPI_INIT failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during MPI_INIT; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): ompi_mpi_init: orte_init failed --> Returned "Data unpack would read past end of buffer" (-26) instead of "Success" (0) -------------------------------------------------------------------------- [caelinux:05635] [[49395,1],5] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/util/nidmap.c at line 371 [caelinux:05635] [[49395,1],5] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../orte/mca/ess/base/ess_base_nidmap.c at line 62 [caelinux:05635] [[49395,1],5] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../../orte/mca/ess/env/ess_env_module.c at line 173 [caelinux:05635] [[49395,1],5] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/runtime/orte_init.c at line 132 -------------------------------------------------------------------------- It looks like MPI_INIT failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during MPI_INIT; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): ompi_mpi_init: orte_init failed --> Returned "Data unpack would read past end of buffer" (-26) instead of "Success" (0) -------------------------------------------------------------------------- *** An error occurred in MPI_Init *** before MPI was initialized *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort) [caelinux:5635] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! [caelinux:05636] [[49395,1],7] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/util/nidmap.c at line 371 [caelinux:05636] [[49395,1],7] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../orte/mca/ess/base/ess_base_nidmap.c at line 62 [caelinux:05636] [[49395,1],7] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../../../../orte/mca/ess/env/ess_env_module.c at line 173 [caelinux:05636] [[49395,1],7] ORTE_ERROR_LOG: Data unpack would read past end of buffer in file ../../../orte/runtime/orte_init.c at line 132 -------------------------------------------------------------------------- It looks like MPI_INIT failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during MPI_INIT; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): ompi_mpi_init: orte_init failed --> Returned "Data unpack would read past end of buffer" (-26) instead of "Success" (0) -------------------------------------------------------------------------- *** An error occurred in MPI_Init *** before MPI was initialized *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort) [caelinux:5636] Abort before MPI_INIT completed successfully; not able to guarantee that all other processes were killed! -------------------------------------------------------------------------- mpirun has exited due to process rank 1 with PID 5633 on node caelinux exiting improperly. There are two reasons this could occur: 1. this process did not call "init" before exiting, but others in the job did. This can cause a job to hang indefinitely while it waits for all processes to call "init". By rule, if one process calls "init", then ALL processes must call "init" prior to termination. 2. this process called "init", but exited without calling "finalize". By rule, all processes that call "init" MUST call "finalize" prior to exiting or it will be considered an "abnormal termination" This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [caelinux:05630] 3 more processes have sent help message help-orte-runtime.txt / orte_init:startup:internal-failure [caelinux:05630] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages [caelinux:05630] 3 more processes have sent help message help-orte-runtime / orte_init:startup:internal-failure Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open Source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 14; method hierarchical; //method metis; //method parMetis; simpleCoeffs { n (4 1 1); delta 0.001; } hierarchicalCoeffs { n (14 1 1); delta 0.001; order xyz; } manualCoeffs { dataFile "cellDecomposition"; } metisCoeffs { //n (5 1 1); //cellWeightsFile "constant/cellWeightsFile"; } // ************************************************************************* // Last edited by wyldckat; October 27, 2013 at 15:04. Reason: Changed [QUOTE] to [CODE][/CODE] |
October 27, 2013, 15:15 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Tommi:
Good luck! Best regards, Bruno
clusters, openfoam 2.2.x, tutorials |
[OpenFOAM.org] Installing OpenFOAM 2.1.0 on ROCKS cluster | aerospain | OpenFOAM Installation | 6 | December 15, 2014 03:35 |
OpenFOAM on cluster (ubuntu 12.04 LTS x64) | novakm | OpenFOAM | 5 | October 19, 2013 06:38 |
Continuity. Stop critertion of PISO and SIMPLE in OpenFOAM solvers. | idrama | OpenFOAM | 4 | September 21, 2010 03:26 |
OpenFOAM requirements for a cluster | farbfilm | OpenFOAM | 2 | September 14, 2010 23:56 |
Linux Cluster Setup Problems | Bob | CFX | 1 | October 3, 2002 18:08 |
