Paraview - CentOS
Hi everyone,
I'm trying to compile OpenFOAM/Paraview from the source files on CENTOS. For OpenFOAM : everything is fine. For Paraview : I compiled qt and cmake in the ThirdParty directory. I modify the path in the makeParaview script. Then during the configure part, I get this error : Code:
Performing Test GLX_DEFINES_MACRO_GLX_VERSION_1_1 - failed Does anyone know where it comes from ? Thank you. |
Few more information :
- glx.h is in the folder "/usr/include/xcb/glx.h" - I opened the file vtkTestGLX.cmake : it says that OPENGL_INCLUDE_DIR is defined within the function/file "FindOpenGL.cmake"which I don't understand how it works. |
1 Attachment(s)
Well, I updated the system but the compilation is still bugging.
If someone has any idea, I'd take it. Error 1 : Code:
[ 6%] [ 6%] Building CXX object VTK/Common/CMakeFiles/vtkCommon.dir/vtkArrayExtents.cxx.o Code:
Linking CXX shared library ../../../bin/libCosmo.so |
Greetings Aurelien,
According to this blog post: http://techtidings.blogspot.pt/2012/...it-ubuntu.html - the problem might be because the file "/usr/lib64/libGL.so" is pointing to a dead link. Try running this command to check to which file it's pointing: Code:
ls -l /usr/lib64/libGL.so By the way, are you following the installation instructions from this page: http://openfoamwiki.net/index.php/In...CentOS_SL_RHEL ? Best regards, Bruno |
