Openfoam2.2.2 Installation error
Can anyone help me After downlaoding and installing Openfoam, I end up with follwoing error in the new terminal: bash: /opt/openFoam222/ etc/bashrc no such directory or file I'm using Ubuntu 12.04LTS version as Virtual os in Windows 7 Looking forward for fruitful reply Phanindra |
Greetings Phanindra,
If you run this command: Code:
source /opt/openfoam222/etc/bashrc Keep in mind that this command will not work: Code:
source /opt/openFoam222/etc/bashrc Best regards, Bruno |
Thanks
Thank you Bruno ! it works
Please Help
I found the error in my Terminal after installing OPEN FOAM, i am using UBUNTU 12.04 as an operating system.
bash: /opt/openfoam222/etc/bashrc: No such file or directory Same error was found when i type the following command.. source /opt/openfoam222/etc/bashrc Please Help me solving it. This is something new for me. |
Greetings usmanabdullah and welcome to the forum!
Please share images or text of what you get after each step from the official instructions: http://www.openfoam.org/download/ubuntu.php Best regards, Bruno |
