October 25, 2013, 05:34 |
openFoam222
belghoula
Bonjour tout le monde, j'ai pas réussi d'installer openFoam222. J'inscris ci-dessous le message obtenus:
samir@ubuntu:~$ sudo apt-get install openfoam222 Lecture des listes de paquets... Fait Construction de l'arbre des dépendances Lecture des informations d'état... Fait E: Impossible de trouver le paquet openfoam222 Quelqu'un peut m'aidez s'il vous plaît. Merci d'avance. |
October 26, 2013, 04:31 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings samir and welcome to the forum!
Please write in English, as explained in the forum rules, namely #10: http://www.cfd-online.com/Forums/misc.php?do=showrules As for your question, please follow these installation instructions: http://www.openfoam.org/download/ubuntu.php Best regards, Bruno
October 26, 2013, 07:04 |
belghoula
Hello everyone, I have not been able to install openFoam222. I list below the message obtained:
samir@ubuntu:~$ sudo apt-get install openfoam222 Lecture des listes de paquets... Fait Construction de l'arbre des dépendances Lecture des informations d'état... Fait E: Impossible de trouver le paquet openfoam222 Can anyone help me please. Thank you. |
October 26, 2013, 07:19 |
Bruno Santos
Rep Power: 128 |
Hi samir,
What command did you run before that one? Did you run? Code:
sudo apt-get update Code:
VERS=$(lsb_release -cs) sudo sh -c "echo deb http://www.openfoam.org/download/ubuntu $VERS main > /etc/apt/sources.list.d/openfoam.list" Code:
echo $VERS Best regards, Bruno
November 13, 2013, 13:46 |
Cephise
Rep Power: 13 |
I have same problem. VERS=lucid The file /etc/apt/sources.list.d/openfoam.list have one line with : deb http://www.openfoam.org/download/ubuntu lucid main Thanks for your help, |
November 15, 2013, 02:12 |
Bruno Santos
Rep Power: 128 |
Greetings Cephise,
The deb packages of OpenFOAM 2.2.2 for Ubuntu do not support Lucid (10.04). You'll have to build from source code, as explained here: http://openfoamwiki.net/index.php/In...u#Ubuntu_10.04 Best regards, Bruno
