-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   Problems compiling pimpleFsiFoam (http://www.cfd-online.com/Forums/openfoam-installation/126158-problems-compiling-pimplefsifoam.html)
arashfluid November 8, 2013 13:33
I want to "wmake" a solver. I've got it correctly compile previously, But when I compile it again later The following error message appears after typing in wmake.
make: Warning: File `/home/arash/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/pimpleFsiFoam' has modification time 2.9e+07 s in the future
make: warning: Clock skew detected. Your build may be incomplete.
whats problem?
nimasam November 9, 2013 08:26
try
wclean
then use
wmake
arashfluid November 9, 2013 08:48
I want to use my FSI solver for pitching motion of airfoil. I've used pointDisplacement on about wingmotion tutorial for the airfoil motion.But I got the following error when running it.
--> FOAM FATAL ERROR:
request for tetPointVectorField motionU from objectRegistry region0 failed
available objects of type tetPointVectorField are
0
From function objectRegistry::lookupObject<Type>(const word&) const
in file /home/arash/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 140.
FOAM aborting
can you help me?
nimasam November 9, 2013 10:20
0
well did you define tetPointVectorField in your creatFields.H or in your solvers?
arashfluid November 9, 2013 10:40
yes. I've checked at it several times.Solver seems to be true.
