Home > Forums > OpenFOAM Installation
OpenFOAM on a 32 bit machine
Old   December 4, 2013, 04:48
Default OpenFOAM on a 32 bit machine
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am writing since I have a problem that - I think - is trivial. But I can't solve it.
I usually run OpenFOAM on 64bit machines and everything usually is fine.
A couple of days ago, I tried OpenFOAM on a 32bit machine, running Debian Wheezy. I can't install it, because of some errors.
I give the command
./Allwmake > log
and in the terminal I get the message in the AllwmakeTerminal.zip file.
Also, attached, the log file (Allwmake1.zip and Allwmake2.zip). Could you help in finding what's wrong?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   December 4, 2013, 05:06
Bernhard
Bernhard is on a distinguished road
Your logfiles only contain an error for paraview, but this is only thirdparty as fas as I can see. I think one attachment is missing?
Bernhard is offline   Reply With Quote
Old   December 4, 2013, 05:18
Samuele Z
You're right.
I forgot a file. Probably the most important .
Thanks,
Samuele
Old   December 6, 2013, 10:57
Samuele Z
Hi All,
has anyone have a look, by chance?
Thanks a lot,
Samuele
Old   December 8, 2013, 14:30
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings to all!
@Samuele: Lets see... Debian Wheezy... http://openfoamwiki.net/index.php/In...#Debian_Wheezy points to here: http://openfoamwiki.net/index.php/In...u#Ubuntu_12.10 <- So I suggest that you try these instructions.
Or at the very least, run Allwmake like this:
./Allwmake > make.log 2>&1
This way the errors are recorded along with the output into the file "make.log".
Best regards,
Bruno
Old   December 8, 2013, 17:41
Samuele Z
Forget about this: SOLVED!
Dear Bruno,
thanks for writing.
Actually, I get an error when I type
source $HOME/OpenFOAM/OpenFOAM-2.2.2/etc/bashrc WM_NCOMPPROCS=2 WM_MPLIB=SYSTEMOPENMPI WM_ARCH_OPTION=32
The error is:
lele@dirac:~/OpenFOAM$ source $HOME/OpenFOAM/OpenFOAM-2.2.2/etc/bashrc WM_NCOMPPROCS=2 WM_MPLIB=SYSTEMOPENMPI WM_ARCH_OPTION=32
Cannot open configuration file /home/lele/OpenFOAM/ThirdParty-2.2.2/platforms/linuxGcc/openmpi-1.6.3/share/openmpi/mpicc-wrapper-data.txt
Error parsing data file mpicc: Not found
and that's because the
is not where it is looking for, but it is here:
lele@dirac:~/OpenFOAM/ThirdParty-2.2.2$ locate mpicc-wrapper-data.txt
/home/lele/OpenFOAM/ThirdParty-2.2.2/openmpi-1.6.3/ompi/tools/wrappers/mpicc-wrapper-data.txt.in
/usr/share/openmpi/mpicc-wrapper-data.txt
How can I solve?
Last edited by samiam1000; December 9, 2013 at 12:27. Reason: SOLVED: dummy error!
Thread Tools
Trackbacks are On
STAR-CCM+ 5.04.008 on a 32 bit machine tobe STAR-CCM+ 6 July 25, 2012 01:27
OpenFOAM Installation on Debian-testing 64 bit Afacci OpenFOAM Installation 4 June 30, 2012 17:54
OpenFOAM vs Ubuntu 10.10 64 bit vkrastev OpenFOAM Installation 12 April 23, 2011 10:14
Problems installing OpenFoam on a 64bit machine jango OpenFOAM Installation 1 June 4, 2007 14:53
OpenFOAM Training and Workshop Zagreb 2628Jan2006 hjasak OpenFOAM 1 February 2, 2006 22:07
