August 31, 2023, 12:02 |
Docker OFv10 not running
Rep Power: 2 |
Hello everyone!
One and a half years ago, I successfully installed OF v5.0 and v9 using Docker on my M1 Mac. Recently, I needed a new version (v10), and I did all the necessary steps, and this is my end result. The same issue is with v11. However, when I run my old OF versions, they work without any problem. Did anyone have the same or similar problem, and how did you solve it? Thx in advance! |
November 22, 2023, 10:39 |
Rep Power: 2 |
Hello Foamers!
After 2,5 months, I've managed to solve this issue. I am not an expert with docker, but what I did was take openfoam9-macos script and did everything like in the website, but before I ran it, I modified a few parameters. Wherever they put v9, I changed it to v10. After that, you can, but it is not necessary to change the name from openfoam9-macos to openfoam10-macos. After that, I run it, and it works. Good luck all! |
DTCHull Ship Resistance Tutorial - Morphing vs Overset Dynamic Mesh | myozinaung | OpenFOAM Running, Solving & CFD | 27 | January 18, 2024 16:49 |
'Signal: Segmentation fault (11)' while running openFoam in Parallel Processing | jaymeen721 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2023 19:17 |
OpenFoam in docker (gcc 6) vs. OpenFoam natively compiled (gcc 8.1.1) | Anouk | OpenFOAM Running, Solving & CFD | 0 | September 17, 2018 08:02 |
Error problem while running sadia d lts tutorial | kane | OpenFOAM Running, Solving & CFD | 2 | May 26, 2018 03:38 |
[Docker] Running OpenFoam 4.1 from script without user intervention | fnellmeldin | OpenFOAM Running, Solving & CFD | 9 | June 7, 2017 18:04 |
