Problem in running foam-extend-3.0/tutorials
I have installed foam-extend-3.0 in OpenFOAM/foam-extend-3.0 directory bu fallowing the instructions given in the LINK : http://wikki.gridcore.se/foam-extend/download#compile Later created a directory RUN in OpenFOAM/foam-extemd-3.0 and copied all the tutorials to this RUN directory and tried to run but I am not able to run tutorials . What might be the problem, ??? Please help me Regards.. Sangamesh Hosur |
Greetings Sangamesh,
Well, without being able to see what you are seeing, it's very hard to diagnose what the problem might be. I suggest that you run the following commands, one line at a time, and let us know what do you get from the output of each command: Code:
mkdir -p $FOAM_RUN Best regards, Bruno |
Thank you
Hi ,
I copied the tutorials in $Home/OpenFOAM/foam-extend-3.0/run But The path suggested by you has worked out. Now my question is which solver need to choose for radial flow turbine which is rotating at 160000 rpm ? |
Beyond that, I suggest that you ask in the correct sub-forum ;) edit: Oh, I see now that you already did :) http://www.cfd-online.com/Forums/ope...lesrffoam.html |
Thank you :)
