March 5, 2014, 05:59 |
#21 | |
Rep Power: 14 |
March 5, 2014, 06:03 |
#22 |
Ok, show me the output of
echo $FOAM_USER_APPBIN Code:
export | grep -E '(WM_|FOAM_)' |
March 5, 2014, 06:11 |
#23 | ||
Rep Power: 14 |
Here the output:
March 5, 2014, 07:09 |
#24 |
It is rather funny cause these two outputs are contradictory, you write that
export | grep -E '(WM_|FOAM_)' Code:
... declare -x FOAM_USER_APPBIN="/home/USER/OpenFOAM/USER-2.2.2/platforms/linuxGccDPOpt/bin" ... The error you've shown is indeed caused by FOAM_USER_APPBIN being empty, so wmake tries to create binary for the solver in the / folder (and obviously fails). You can try run clean before wmake, maybe where is some stale files with old settings. And cause I don't know your exact environment when you run wmake, I can not suggest you anything concrete. |
March 5, 2014, 08:56 |
#25 |
Rep Power: 14 |
I ve run wclean first and afterward wmake:
wclean wmake make: *** No rule to make target `multiphaseEulerFoam.dep', needed by `Make/linuxGccDPOpt/dependencies'. Stop Thx alot for the help. greetings maybee |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
[OpenFOAM] ParaFoam error message | joey | ParaView | 1 | October 2, 2006 13:28 |
