FATAL ERROR: ParaView reader module libraries do not exist
Like Tree1Likes
  • 1 Post By wyldckat
Old   April 1, 2014, 13:11
Default FATAL ERROR: ParaView reader module libraries do not exist
adarsh tiwari's Avatar
adarsh tiwari
adarsh tiwari is on a distinguished road
dear all
while using paraFoam I got the following error.
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers
./Allwclean
./Allwmake
I reinstalled using the commands given in OpenFOAM installation http://www.openfoam.org/download/ubuntu.php,
but the same problem continues.
Please help ASAP.
Thanks and Regards,
Adarsh
adarsh tiwari is offline   Reply With Quote
Old   April 1, 2014, 15:00
Retired Super Moderator
Bruno Santos
Greetings Adarsh,
A few questions:
  1. Which Ubuntu version are you using?
  2. Which exact commands did you use to install OpenFOAM and ParaView?
  3. Do you have more than one OpenFOAM version installed?
Best regards,
Bruno
Old   April 2, 2014, 02:47
adarsh tiwari
Hi Bruno,
I am using ubuntu 12.04 LTS while the commands I have used to install OpenFoam and paraView (for 2.3.0) is
VERS=$(lsb_release -cs)
sudo sh -c "echo deb http://www.openfoam.org/download/ubuntu $VERS main > /etc/apt/sources.list.d/openfoam.list"
sudo apt-get update
sudo apt-get install openfoam230
sudo apt-get install paraviewopenfoam410
initially i tried to install OpenFOAM 2.2.2, but it was unsuccessful, hence I have installed 2.3.0 and then removed 2.2.2.
now i am able to open paraview, but while using the command paraFoam it is showing the message
paraFoam: command not found
i am unable to understand what went wrong
Thanks and Regards,
Adarsh
Old   April 2, 2014, 15:47
Bruno Santos
Hi Adarsh,
  1. Start a new terminal window and check if you're able to use paraFoam or not.
  2. If not, check the content of the file "~/.bashrc". It should only have a single line for OpenFOAM 2.3.0 and no other version.
  3. I hope you used the following command for removing the old version:
    sudo apt-get install openfoam222
Best regards,
Bruno
Old   April 4, 2014, 13:57
adarsh tiwari
Hi Bruno,
I am not able to use paraFoam
I have checked for the content of ~/.bashrc and it's the same
/opt/openfoam230/etc/bashrc
while I removed openfoam 2.2.2 using the following command
 sudo apt-get remove openfoam222
Thanks and regards,
Adarsh Tiwari
Old   April 4, 2014, 15:33
Bruno Santos
Hi Adarsh,
Uhm... it should contain this at the end of the file "~/.bashrc":
. /opt/openfoam230/etc/bashrc
The dot + space at the beginning is very important and without it, it will not work as intended.
Best regards,
Bruno
adarsh tiwari likes this.
Old   April 5, 2014, 11:47
adarsh tiwari
Hi Bruno,
It solved my problem.
THANK YOU VERY MUCH
Adarsh Tiwari
[OpenFOAM.com] paraFoam reader module libraries do not exist sjtuwjh OpenFOAM Installation 14 May 6, 2016 13:55
ParaView reader module libraries do not exist anishtain4 OpenFOAM Installation 5 October 9, 2012 08:25
OpenFOAM-2.0.x on Ubuntu 11.10 kpsl OpenFOAM Installation 43 January 18, 2012 23:17
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
