Regarding OpenFOAM installation problem on OpenSUSE
Old   March 12, 2014, 06:12
Default Regarding OpenFOAM installation problem on OpenSUSE
harshawardhank
harsha_kulkarni is on a distinguished road
Hello Foamer,,
I want to install OpenFOAM on OpenSUSE 11.4. It is giving error during installing depedant package required for OpenSUSE -
File '/repodata/repomd.xml' not found on medium 'http://download.opensuse.org/distribution/11.4/repo/non-oss/'
Reply ASAP
Harshawardhan Kulkarni
harsha_kulkarni is offline   Reply With Quote
Old   March 12, 2014, 14:58
Retired Super Moderator
Bruno Santos
Greetings Harshawardhan Kulkarni and welcome to the forum!
Unfortunately openSUSE 11.4 is no longer supported by the openSUSE development team, which is why the link "http://download.opensuse.org/distribution/11.4/repo/non-oss/" no longer works as intended.
I strongly suggest that you either upgrade your openSUSE installation to the latest 13.1 version or simply choose a Linux Distribution that supports long term support, such as Ubuntu LTS, CentOS or Scientific Linux.
If you cannot upgrade your Linux installation, then you will have to build everything or almost everything from source code. If this is the case, then please indicate if you still have the original installation disk and which version/model of disk it is, namely if it's the DVD installation disk or the Live CD.
Best regards,
Bruno
Old   March 13, 2014, 01:20
harshawardhank
Thank you....
Old   March 14, 2014, 05:20
Exclamation Regarding OpenFOAM installation problem on OpenSUSE 11.4
harshawardhank
Hello friends,
I have installed OpenFOAM 2.2.0 on OpenSUSE 11.4. The procees of instalation
gets completed. I also run the cavity case in the installed software. but as soon as I
close the software and the terminal and then I reopen it, It is not taking any command
in OpenFOAM. At that time it is also showing the error like "OpenFOAM environment
not configured" when you run ./foamInstallationTest.
Regards
Harshawardhan
Old   March 16, 2014, 05:03
Bruno Santos
Quick answer:
  1. It seems that you did not add this line (or similar) to the "~/.bashrc" file:
    . $HOME/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc
  2. For more detailed information about this: http://openfoamwiki.net/index.php/In...with_the_Shell
[Discussion] Restructuring the Installation page at openfoamwiki.net wyldckat OpenFOAM Installation 16 November 2, 2013 11:43
Problem? with Installation of OpenFOAM 2.1.0 on to Ubuntu 10.4.4 VirtualBox Stubby OpenFOAM Installation 8 March 5, 2012 15:12
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
OpenFOAM 1.5-dev installation in OpenSuSe 10.3 darenyang OpenFOAM Installation 0 April 28, 2009 04:30
Problem in installation of OpenFOAM sachin OpenFOAM Installation 7 January 22, 2008 01:40
