[OpenFOAM.org] checking with foamInstallationTest: does this mean that everything is okay? |
April 21, 2015, 03:51 |
Zhiyi Li
Rep Power: 11 |
Dear All,
After I installed OpenFoam, I used the foamInstallationTest to check if everything is okay with my installation. And I got the following message: Executing /home/itvzl/OpenFOAM/OpenFOAM-2.1.x/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: bernoulli OS: Linux version 3.13.0-49-generic ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/itvzl/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/itvzl/OpenFOAM/itvzl-2.1.x yes no $WM_THIRD_PARTY_DIR /home/itvzl/OpenFOAM/ThirdParty-2.1.x yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/itvzl/OpenFOAM/OpenFOAM-2.1.x yes yes yes $FOAM_APPBIN ...-2.1.x/platforms/linux64GccDPOpt/bin yes yes yes $FOAM_SITE_APPBIN .../2.1.x/platforms/linux64GccDPOpt/bin no no $FOAM_USER_APPBIN ...-2.1.x/platforms/linux64GccDPOpt/bin no no $WM_DIR .../itvzl/OpenFOAM/OpenFOAM-2.1.x/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...-2.1.x/platforms/linux64GccDPOpt/lib yes yes yes $FOAM_SITE_LIBBIN .../2.1.x/platforms/linux64GccDPOpt/lib no no $FOAM_USER_LIBBIN ...-2.1.x/platforms/linux64GccDPOpt/lib no no $MPI_ARCH_PATH ...x/platforms/linux64Gcc/openmpi-1.5.3 yes yes yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- flex 2.5.35 /usr/bin/flex gcc 4.8.2 /usr/bin/gcc gzip 1.6 /bin/gzip tar 1.27.1 /bin/tar icoFoam 2.1.x ...M/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/icoFoam ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. Critical systems ok. Dos this mean that everything is okay? But how come when I use the paraFoam command there are something wrong with it and reminding me that : FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers ./Allwclean ./Allwmake |
April 21, 2015, 03:57 |
Rep Power: 11 |
You should compile Paraview (or binaries from repositories, or website).
If you wish to compile, take a look inside third party dir.
beep-beep |
April 21, 2015, 04:32 |
#3 | |
Zhiyi Li
Rep Power: 11 |
I did as the instruction here Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers ./Allwclean ./Allwmake But unfortunately, it is not working. Still the same message showing up when I am trying to use the command paraFoam. Best Regards |
April 21, 2015, 05:30 |
Rep Power: 14 |
This error is not uncommon. A quick search lead me to this thread:
http://www.cfd-online.com/Forums/ope...not-exist.html |
April 21, 2015, 05:52 |
#5 | |
Zhiyi Li
Rep Power: 11 |
It worked. I could use paraFoam now |
installation by sources |
HiFiLES installation problem | Eric Brant | SU2 | 0 | October 31, 2016 20:11 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Help%7e%7einstall openfoam13 on fc5%7e%7e | aderliner | OpenFOAM Installation | 2 | September 11, 2006 07:24 |
Gerris software installation | mer | Main CFD Forum | 2 | November 12, 2005 08:50 |
