-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   swak4foam installation (http://www.cfd-online.com/Forums/openfoam-installation/133948-swak4foam-installation.html)
bharathbs April 23, 2014 02:05
Hi
I am currently working on Openfoam 2.3.
I came across that, swak4foam cannot be installed correctly on latest version of Openfoam.
So i have download older verion (2.1) of Openfoam, based on my ubuntu version.
Can any one please give me guideline or steps for installing SWAK4FOAM successfully in Ubuntu........it is urgent.
Looking forward for the reply.
Thanks
bharath
jherb April 23, 2014 08:00
I was able to use swak4Foam from the development branch with OpenFOAM 2.3 following the installation instructions from here:
http://openfoamwiki.net/index.php/Co...am#Development
(branch port_2.0.x)
cnsidero April 23, 2014 09:55
Originally Posted by bharathbs (Post 487612)
Hi
Thanks
bharath
I'll refrain from using f but you can RTM: http://openfoamwiki.net/index.php/Co...4Foam#Building
There's also a link there for additional installation help if needed.
bharathbs April 24, 2014 05:00
Dear Chris Sideroff and Joachim Herb
Thank you for the timely reply.
I will check and then get back to you.
And also i would like to know from you are there any other utility in OPENFOAM for swak4foam as i am interested to capture different contour at interface region
With regards,
Bharath
wyldckat April 24, 2014 15:36
Greetings to all!
@bharathbs:
It might not be extremely easy to find these instructions, but the steps for installing swak4Foam on Ubuntu have been available since the 22nd of March 2014: http://openfoamwiki.net/index.php/In...ling_On/Ubuntu
I'm sorry, but I have to ask you to please rephrase your question. Because I can't understand if you're looking for a tool for colouring the interface between two phases or if you're looking for a solver to simulate something... :confused:
Best regards,
Bruno
bharathbs April 27, 2014 23:52
Dear Bruno Santos
I am interested to calculate in OPENFOAM the values at internal patch, i.e., like in FLUENT at interface region.
With warm regards,
Bharath
gschaider April 28, 2014 08:20
Originally Posted by bharathbs (Post 488563)
Dear Bruno Santos
With warm regards,
Bharath
Don't shout (writing everything bold is considered shouting). It is rude.
An example for what you want to achieve is found at http://openfoamwiki.net/index.php/Co...e_calcMassFlow
The main problem is making these faceSets/zones. This depends on the way you create your mesh, but for instance the fluentMeshToFoam-converters can do this for you (if you're using a Fluent-mesh)
