[OpenFOAM.org] OpenFOAM 4.0 compilation - "cannot open source file..." |
August 24, 2016, 15:43 |
Ed Swindelles
Rep Power: 9 |
Hi All -
I'm trying to compile OpenFOAM 4.0 for the first time, on RHEL 6.8 with Intel ICS v2016.3 and Intel MPI. I don't get too far, though. I have my Intel compiler module loaded, along with a couple prerequisites. Code:
export FOAM_INST_DIR=/apps2/openfoam . $FOAM_INST_DIR/OpenFOAM-4.0/etc/bashrc WM_COMPILER=Icc WM_NCOMPPROCS=24 WM_MPLIB=Intel_MPI $FOAM_INST_DIR/OpenFOAM-4.0/Allwmake -j Code:
Compiling enabled on 24 cores make: Nothing to be done for `all'. Allwmake: no ThirdParty directory found - skipping + wmakePrintBuild -check no git description found + wrmo OpenFOAM/global/global.o removing .o files corresponding to OpenFOAM/global/global.o ... + wmakeLnInclude OpenFOAM + wmakeLnInclude OSspecific/POSIX + Pstream/Allwmake libso + wmake libso dummy /apps2/openfoam/OpenFOAM-4.0/src/Pstream/dummy icpc -std=c++0x -fp-trap=common -fp-model precise -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -diag-disable 654,1125,2304 -O3 -DNoRepository -IlnInclude -I. -I/apps2/openfoam/OpenFOAM-4.0/src/OpenFOAM/lnInclude -I/apps2/openfoam/OpenFOAM-4.0/src/OSspecific/POSIX/lnInclude -fPIC -c UPstream.C -o /apps2/openfoam/OpenFOAM-4.0/platforms/linux64IccDPInt32Opt/src/Pstream/dummy/UPstream.o icpc -std=c++0x -fp-trap=common -fp-model precise -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -diag-disable 654,1125,2304 -O3 -DNoRepository -IlnInclude -I. -I/apps2/openfoam/OpenFOAM-4.0/src/OpenFOAM/lnInclude -I/apps2/openfoam/OpenFOAM-4.0/src/OSspecific/POSIX/lnInclude -fPIC -c UIPread.C -o /apps2/openfoam/OpenFOAM-4.0/platforms/linux64IccDPInt32Opt/src/Pstream/dummy/UIPread.o icpc -std=c++0x -fp-trap=common -fp-model precise -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -diag-disable 654,1125,2304 -O3 -DNoRepository -IlnInclude -I. -I/apps2/openfoam/OpenFOAM-4.0/src/OpenFOAM/lnInclude -I/apps2/openfoam/OpenFOAM-4.0/src/OSspecific/POSIX/lnInclude -fPIC -c UOPwrite.C -o /apps2/openfoam/OpenFOAM-4.0/platforms/linux64IccDPInt32Opt/src/Pstream/dummy/UOPwrite.o In file included from /apps2/openfoam/OpenFOAM-4.0/src/OpenFOAM/lnInclude/Pstream.H(42), from /apps2/openfoam/OpenFOAM-4.0/src/OpenFOAM/lnInclude/UIPstream.H(36), from UIPread.C(29): /apps2/openfoam/OpenFOAM-4.0/src/OpenFOAM/lnInclude/UPstream.H(42): catastrophic error: cannot open source file "labelList.H" #include "labelList.H" ^ In file included from UPstream.C(26): In file included from /apps2/openfoam/OpenFOAM-4.0/src/OpenFOAM/lnInclude/Pstream.H(42), from /apps2/openfoam/OpenFOAM-4.0/src/OpenFOAM/lnInclude/UOPstream.H(36), from UOPwrite.C(29): /apps2/openfoam/OpenFOAM-4.0/src/OpenFOAM/lnInclude/UPstream.H(42): catastrophic error: cannot open source file "labelList.H" #include "labelList.H" ^ /apps2/openfoam/OpenFOAM-4.0/src/OpenFOAM/lnInclude/UPstream.H(42): catastrophic error: cannot open source file "labelList.H" #include "labelList.H" ^ compilation aborted for UPstream.C (code 4) compilation aborted for UOPwrite.C (code 4) compilation aborted for UIPread.C (code 4) make: *** [/apps2/openfoam/OpenFOAM-4.0/platforms/linux64IccDPInt32Opt/src/Pstream/dummy/UOPwrite.o] Error 4 make: *** Waiting for unfinished jobs.... make: *** [/apps2/openfoam/OpenFOAM-4.0/platforms/linux64IccDPInt32Opt/src/Pstream/dummy/UPstream.o] Error 4 make: *** [/apps2/openfoam/OpenFOAM-4.0/platforms/linux64IccDPInt32Opt/src/Pstream/dummy/UIPread.o] Error 4 Code:
$ find -L . -name labelList.H ./OpenFOAM-4.0/src/OpenFOAM/primitives/ints/lists/labelList.H Code:
$ vim ./OpenFOAM-4.0/wmake/rules/linux64Icc/c++ c++FLAGS = $(GFLAGS) $(c++WARN) $(c++OPT) $(c++DBUG) $(ptFLAGS) $(LIB_HEADER_DIRS) -fPIC -I/apps2/openfoam/OpenFOAM-4.x/src/OpenFOAM/primitives/ints/lists Here are the relevant environment variables. Code:
WM_LINK_LANGUAGE=c++ FOAM_SOLVERS=/apps2/openfoam/OpenFOAM-4.0/applications/solvers FOAM_EXT_LIBBIN=/apps2/openfoam/ThirdParty-4.0/platforms/linux64IccDPInt32/lib FOAM_APPBIN=/apps2/openfoam/OpenFOAM-4.0/platforms/linux64IccDPInt32Opt/bin FOAM_TUTORIALS=/apps2/openfoam/OpenFOAM-4.0/tutorials FOAM_JOB_DIR=/apps2/openfoam/jobControl WM_ARCH=linux64 WM_COMPILER_TYPE=system WM_OSTYPE=POSIX WM_THIRD_PARTY_DIR=/apps2/openfoam/ThirdParty-4.0 CGAL_ARCH_PATH=/apps2/openfoam/ThirdParty-4.0/platforms/linux64Icc/cgal-system FOAM_SITE_APPBIN=/apps2/openfoam/site/4.0/platforms/linux64IccDPInt32Opt/bin BOOST_ARCH_PATH=/apps2/openfoam/ThirdParty-4.0/platforms/linux64Icc/boost-system FOAM_APP=/apps2/openfoam/OpenFOAM-4.0/applications WM_CXXFLAGS=-m64 -fPIC -std=c++0x WM_CFLAGS=-m64 -fPIC WM_PROJECT_VERSION=4.0 FOAM_SITE_LIBBIN=/apps2/openfoam/site/4.0/platforms/linux64IccDPInt32Opt/lib WM_COMPILER_LIB_ARCH=64 FOAM_SRC=/apps2/openfoam/OpenFOAM-4.0/src FOAM_SIGFPE= ParaView_DIR=/apps2/openfoam/ThirdParty-4.0/platforms/linux64Icc/ParaView-5.0.1 WM_PROJECT_INST_DIR=/apps2/openfoam FOAM_UTILITIES=/apps2/openfoam/OpenFOAM-4.0/applications/utilities WM_CXX=g++ WM_PROJECT_DIR=/apps2/openfoam/OpenFOAM-4.0 WM_LABEL_OPTION=Int32 WM_NCOMPPROCS=24 WM_PROJECT=OpenFOAM WM_LDFLAGS=-m64 WM_COMPILER=Icc WM_MPLIB=Intel_MPI FOAM_USER_LIBBIN=/home/me/OpenFOAM/me-4.0/platforms/linux64IccDPInt32Opt/lib WM_CC=gcc FOAM_ETC=/apps2/openfoam/OpenFOAM-4.0/etc FOAM_INST_DIR=/apps2/openfoam FOAM_MPI=dummy FOAM_LIBBIN=/apps2/openfoam/OpenFOAM-4.0/platforms/linux64IccDPInt32Opt/lib WM_COMPILE_OPTION=Opt WM_DIR=/apps2/openfoam/OpenFOAM-4.0/wmake WM_LABEL_SIZE=32 ParaView_MAJOR=5.0 FOAM_SETTINGS=WM_COMPILER=Icc WM_NCOMPPROCS=24 WM_MPLIB=Intel_MPI FOAMY_HEX_MESH=yes WM_PROJECT_USER_DIR=/home/me/OpenFOAM/me-4.0 FOAM_RUN=/home/me/OpenFOAM/me-4.0/run WM_OPTIONS=linux64IccDPInt32Opt WM_PRECISION_OPTION=DP WM_ARCH_OPTION=64 FOAM_USER_APPBIN=/home/me/OpenFOAM/me-4.0/platforms/linux64IccDPInt32Opt/bin I_MPI_ROOT=/apps2/intelics/2016.3-full/compilers_and_libraries_2016.3.210/linux/mpi |
August 24, 2016, 20:48 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Ed Swindelles and welcome to the forum!
The first issue I'm spotting is this: Code:
WM_MPLIB=Intel_MPI The correct setting should be this: Code:
WM_MPLIB=INTELMPI Code:
export MPI_ROOT=$I_MPI_ROOT Quote:
./OpenFOAM-4.0/src/OpenFOAM/lnInclude/labelList.H Of course now the problem is figuring out why this folder "lnInclude" was not populated in the first place. Please let us know what each one of the following commands give you: Code:
ls -l $FOAM_SRC/OpenFOAM ls -l $FOAM_SRC/OpenFOAM/lnInclude ln -vs ../primitives/zero/zero.H $FOAM_SRC/OpenFOAM/lnInclude/zero.H Best regards, Bruno
August 24, 2016, 22:17 |
Ed Swindelles
Rep Power: 9 |
Thanks @wyldckat. I fixed the MPI library name and exported MPI_ROOT. Here's the output from the commands you suggested (truncated a bit to fit). It looks like the lnInclude output directory exists and contains items, it just doesn't contain the ones which are producing errors, for some unknown reason.
#1 Code:
ls -l $FOAM_SRC/OpenFOAM drwxrwsr-x 5 me wheel 512 Jun 24 17:33 algorithms drwxrwsr-x 9 me wheel 512 Jun 24 17:33 containers drwxrwsr-x 17 me wheel 32768 Jun 24 17:33 db drwxrwsr-x 8 me wheel 512 Jun 24 17:33 dimensionedTypes drwxrwsr-x 2 me wheel 512 Jun 24 17:33 dimensionSet drwxrwsr-x 10 me wheel 512 Jun 24 17:33 fields drwxrwsr-x 9 me wheel 512 Jun 24 17:33 global drwxrwsr-x 4 me wheel 512 Jun 24 17:33 graph drwxrwsr-x 2 me wheel 32768 Jun 24 17:33 include drwxrwsr-x 12 me wheel 32768 Jun 24 17:33 interpolations drwxrwsr-x 2 me wheel 32768 Aug 23 15:18 lnInclude drwxrwsr-x 2 me wheel 512 Jun 24 17:33 Make drwxrwsr-x 17 me wheel 32768 Jun 24 17:33 matrices drwxrwsr-x 7 me wheel 512 Jun 24 17:33 memory drwxrwsr-x 18 me wheel 32768 Jun 24 17:33 meshes drwxrwsr-x 43 me wheel 32768 Jun 24 17:33 primitives Code:
ls -l $FOAM_SRC/OpenFOAM/lnInclude lrwxrwxrwx 1 me wheel 51 Aug 23 15:18 BiIndirectList.H -> ../containers/Lists/BiIndirectList/BiIndirectList.H lrwxrwxrwx 1 me wheel 52 Aug 23 15:18 BiIndirectListI.H -> ../containers/Lists/BiIndirectList/BiIndirectListI.H lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 BinSum.C -> ../containers/Lists/BinSum/BinSum.C lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 BinSum.H -> ../containers/Lists/BinSum/BinSum.H lrwxrwxrwx 1 me wheel 25 Aug 23 15:18 Callback.C -> ../db/Callback/Callback.C lrwxrwxrwx 1 me wheel 25 Aug 23 15:18 Callback.H -> ../db/Callback/Callback.H lrwxrwxrwx 1 me wheel 41 Aug 23 15:18 CallbackRegistry.C -> ../db/CallbackRegistry/CallbackRegistry.C lrwxrwxrwx 1 me wheel 41 Aug 23 15:18 CallbackRegistry.H -> ../db/CallbackRegistry/CallbackRegistry.H lrwxrwxrwx 1 me wheel 45 Aug 23 15:18 CallbackRegistryName.C -> ../db/CallbackRegistry/CallbackRegistryName.C lrwxrwxrwx 1 me wheel 57 Aug 23 15:18 CirculatorBase.H -> ../containers/Circulators/CirculatorBase/CirculatorBase.H lrwxrwxrwx 1 me wheel 49 Aug 23 15:18 Circulator.H -> ../containers/Circulators/Circulator/Circulator.H lrwxrwxrwx 1 me wheel 50 Aug 23 15:18 CirculatorI.H -> ../containers/Circulators/Circulator/CirculatorI.H lrwxrwxrwx 1 me wheel 47 Aug 23 15:18 combineGatherScatter.C -> ../db/IOstreams/Pstreams/combineGatherScatter.C lrwxrwxrwx 1 me wheel 47 Aug 23 15:18 CompactIOField.C -> ../db/IOobjects/CompactIOField/CompactIOField.C lrwxrwxrwx 1 me wheel 47 Aug 23 15:18 CompactIOField.H -> ../db/IOobjects/CompactIOField/CompactIOField.H lrwxrwxrwx 1 me wheel 45 Aug 23 15:18 CompactIOList.C -> ../db/IOobjects/CompactIOList/CompactIOList.C lrwxrwxrwx 1 me wheel 45 Aug 23 15:18 CompactIOList.H -> ../db/IOobjects/CompactIOList/CompactIOList.H lrwxrwxrwx 1 me wheel 53 Aug 23 15:18 CompactListList.C -> ../containers/Lists/CompactListList/CompactListList.C lrwxrwxrwx 1 me wheel 53 Aug 23 15:18 CompactListList.H -> ../containers/Lists/CompactListList/CompactListList.H lrwxrwxrwx 1 me wheel 54 Aug 23 15:18 CompactListListI.H -> ../containers/Lists/CompactListList/CompactListListI.H lrwxrwxrwx 1 me wheel 55 Aug 23 15:18 CompactListListIO.C -> ../containers/Lists/CompactListList/CompactListListIO.C lrwxrwxrwx 1 me wheel 59 Aug 23 15:18 ConstCirculator.H -> ../containers/Circulators/ConstCirculator/ConstCirculator.H lrwxrwxrwx 1 me wheel 60 Aug 23 15:18 ConstCirculatorI.H -> ../containers/Circulators/ConstCirculator/ConstCirculatorI.H lrwxrwxrwx 1 me wheel 58 Aug 23 15:18 DictionaryBase.C -> ../containers/Dictionaries/DictionaryBase/DictionaryBase.C lrwxrwxrwx 1 me wheel 58 Aug 23 15:18 DictionaryBase.H -> ../containers/Dictionaries/DictionaryBase/DictionaryBase.H lrwxrwxrwx 1 me wheel 60 Aug 23 15:18 DictionaryBaseIO.C -> ../containers/Dictionaries/DictionaryBase/DictionaryBaseIO.C lrwxrwxrwx 1 me wheel 50 Aug 23 15:18 Dictionary.C -> ../containers/Dictionaries/Dictionary/Dictionary.C lrwxrwxrwx 1 me wheel 50 Aug 23 15:18 Dictionary.H -> ../containers/Dictionaries/Dictionary/Dictionary.H lrwxrwxrwx 1 me wheel 47 Aug 23 15:18 Distribution.C -> ../containers/Lists/Distribution/Distribution.C lrwxrwxrwx 1 me wheel 47 Aug 23 15:18 Distribution.H -> ../containers/Lists/Distribution/Distribution.H lrwxrwxrwx 1 me wheel 48 Aug 23 15:18 DistributionI.H -> ../containers/Lists/Distribution/DistributionI.H lrwxrwxrwx 1 me wheel 59 Aug 23 15:18 DLListBase.C -> ../containers/LinkedLists/linkTypes/DLListBase/DLListBase.C lrwxrwxrwx 1 me wheel 59 Aug 23 15:18 DLListBase.H -> ../containers/LinkedLists/linkTypes/DLListBase/DLListBase.H lrwxrwxrwx 1 me wheel 60 Aug 23 15:18 DLListBaseI.H -> ../containers/LinkedLists/linkTypes/DLListBase/DLListBaseI.H lrwxrwxrwx 1 me wheel 39 Aug 23 15:18 DLList.H -> ../containers/LinkedLists/user/DLList.H lrwxrwxrwx 1 me wheel 42 Aug 23 15:18 DLPtrList.H -> ../containers/LinkedLists/user/DLPtrList.H lrwxrwxrwx 1 me wheel 57 Aug 23 15:18 dynamicIndexedOctree.C -> ../algorithms/dynamicIndexedOctree/dynamicIndexedOctree.C lrwxrwxrwx 1 me wheel 57 Aug 23 15:18 dynamicIndexedOctree.H -> ../algorithms/dynamicIndexedOctree/dynamicIndexedOctree.H lrwxrwxrwx 1 me wheel 61 Aug 23 15:18 dynamicIndexedOctreeName.C -> ../algorithms/dynamicIndexedOctree/dynamicIndexedOctreeName.C lrwxrwxrwx 1 me wheel 45 Aug 23 15:18 DynamicList.C -> ../containers/Lists/DynamicList/DynamicList.C lrwxrwxrwx 1 me wheel 45 Aug 23 15:18 DynamicList.H -> ../containers/Lists/DynamicList/DynamicList.H lrwxrwxrwx 1 me wheel 46 Aug 23 15:18 DynamicListI.H -> ../containers/Lists/DynamicList/DynamicListI.H lrwxrwxrwx 1 me wheel 57 Aug 23 15:18 dynamicTreeDataPoint.C -> ../algorithms/dynamicIndexedOctree/dynamicTreeDataPoint.C lrwxrwxrwx 1 me wheel 57 Aug 23 15:18 dynamicTreeDataPoint.H -> ../algorithms/dynamicIndexedOctree/dynamicTreeDataPoint.H lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 exchange.C -> ../db/IOstreams/Pstreams/exchange.C lrwxrwxrwx 1 me wheel 42 Aug 23 15:18 FIFOStack.H -> ../containers/LinkedLists/user/FIFOStack.H lrwxrwxrwx 1 me wheel 41 Aug 23 15:18 FixedList.C -> ../containers/Lists/FixedList/FixedList.C lrwxrwxrwx 1 me wheel 41 Aug 23 15:18 FixedList.H -> ../containers/Lists/FixedList/FixedList.H lrwxrwxrwx 1 me wheel 42 Aug 23 15:18 FixedListI.H -> ../containers/Lists/FixedList/FixedListI.H lrwxrwxrwx 1 me wheel 43 Aug 23 15:18 FixedListIO.C -> ../containers/Lists/FixedList/FixedListIO.C lrwxrwxrwx 1 me wheel 40 Aug 23 15:18 gatherScatter.C -> ../db/IOstreams/Pstreams/gatherScatter.C lrwxrwxrwx 1 me wheel 44 Aug 23 15:18 gatherScatterList.C -> ../db/IOstreams/Pstreams/gatherScatterList.C lrwxrwxrwx 1 me wheel 52 Aug 23 15:18 HashPtrTable.C -> ../containers/HashTables/HashPtrTable/HashPtrTable.C lrwxrwxrwx 1 me wheel 52 Aug 23 15:18 HashPtrTable.H -> ../containers/HashTables/HashPtrTable/HashPtrTable.H lrwxrwxrwx 1 me wheel 54 Aug 23 15:18 HashPtrTableIO.C -> ../containers/HashTables/HashPtrTable/HashPtrTableIO.C lrwxrwxrwx 1 me wheel 42 Aug 23 15:18 HashSet.C -> ../containers/HashTables/HashSet/HashSet.C lrwxrwxrwx 1 me wheel 42 Aug 23 15:18 HashSet.H -> ../containers/HashTables/HashSet/HashSet.H lrwxrwxrwx 1 me wheel 46 Aug 23 15:18 HashTable.C -> ../containers/HashTables/HashTable/HashTable.C lrwxrwxrwx 1 me wheel 50 Aug 23 15:18 HashTableCore.C -> ../containers/HashTables/HashTable/HashTableCore.C lrwxrwxrwx 1 me wheel 46 Aug 23 15:18 HashTable.H -> ../containers/HashTables/HashTable/HashTable.H lrwxrwxrwx 1 me wheel 47 Aug 23 15:18 HashTableI.H -> ../containers/HashTables/HashTable/HashTableI.H lrwxrwxrwx 1 me wheel 48 Aug 23 15:18 HashTableIO.C -> ../containers/HashTables/HashTable/HashTableIO.C lrwxrwxrwx 1 me wheel 41 Aug 23 15:18 Histogram.C -> ../containers/Lists/Histogram/Histogram.C lrwxrwxrwx 1 me wheel 41 Aug 23 15:18 Histogram.H -> ../containers/Lists/Histogram/Histogram.H lrwxrwxrwx 1 me wheel 40 Aug 23 15:18 IDLList.H -> ../containers/LinkedLists/user/IDLList.H lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 IFstream.C -> ../db/IOstreams/Fstreams/IFstream.C lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 IFstream.H -> ../db/IOstreams/Fstreams/IFstream.H lrwxrwxrwx 1 me wheel 53 Aug 23 15:18 ILList.C -> ../containers/LinkedLists/accessTypes/ILList/ILList.C lrwxrwxrwx 1 me wheel 53 Aug 23 15:18 ILList.H -> ../containers/LinkedLists/accessTypes/ILList/ILList.H lrwxrwxrwx 1 me wheel 55 Aug 23 15:18 ILListIO.C -> ../containers/LinkedLists/accessTypes/ILList/ILListIO.C lrwxrwxrwx 1 me wheel 43 Aug 23 15:18 indexedOctree.C -> ../algorithms/indexedOctree/indexedOctree.C lrwxrwxrwx 1 me wheel 43 Aug 23 15:18 indexedOctree.H -> ../algorithms/indexedOctree/indexedOctree.H lrwxrwxrwx 1 me wheel 47 Aug 23 15:18 indexedOctreeName.C -> ../algorithms/indexedOctree/indexedOctreeName.C lrwxrwxrwx 1 me wheel 47 Aug 23 15:18 IndirectList.H -> ../containers/Lists/IndirectList/IndirectList.H lrwxrwxrwx 1 me wheel 48 Aug 23 15:18 IndirectListI.H -> ../containers/Lists/IndirectList/IndirectListI.H lrwxrwxrwx 1 me wheel 32 Aug 23 15:18 INew.H -> ../db/IOstreams/IOstreams/INew.H lrwxrwxrwx 1 me wheel 37 Aug 23 15:18 InfoProxy.H -> ../db/IOstreams/IOstreams/InfoProxy.H lrwxrwxrwx 1 me wheel 43 Aug 23 15:18 IOdictionary.C -> ../db/IOobjects/IOdictionary/IOdictionary.C lrwxrwxrwx 1 me wheel 43 Aug 23 15:18 IOdictionary.H -> ../db/IOobjects/IOdictionary/IOdictionary.H lrwxrwxrwx 1 me wheel 45 Aug 23 15:18 IOdictionaryIO.C -> ../db/IOobjects/IOdictionary/IOdictionaryIO.C lrwxrwxrwx 1 me wheel 33 Aug 23 15:18 IOField.C -> ../db/IOobjects/IOField/IOField.C lrwxrwxrwx 1 me wheel 33 Aug 23 15:18 IOField.H -> ../db/IOobjects/IOField/IOField.H lrwxrwxrwx 1 me wheel 31 Aug 23 15:18 IOList.C -> ../db/IOobjects/IOList/IOList.C lrwxrwxrwx 1 me wheel 31 Aug 23 15:18 IOList.H -> ../db/IOobjects/IOList/IOList.H lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 IOmanip.H -> ../db/IOstreams/IOstreams/IOmanip.H lrwxrwxrwx 1 me wheel 29 Aug 23 15:18 IOMap.C -> ../db/IOobjects/IOMap/IOMap.C lrwxrwxrwx 1 me wheel 29 Aug 23 15:18 IOMap.H -> ../db/IOobjects/IOMap/IOMap.H lrwxrwxrwx 1 me wheel 33 Aug 23 15:18 IOMapName.C -> ../db/IOobjects/IOMap/IOMapName.C lrwxrwxrwx 1 me wheel 25 Aug 23 15:18 IOobject.C -> ../db/IOobject/IOobject.C lrwxrwxrwx 1 me wheel 25 Aug 23 15:18 IOobject.H -> ../db/IOobject/IOobject.H lrwxrwxrwx 1 me wheel 26 Aug 23 15:18 IOobjectI.H -> ../db/IOobject/IOobjectI.H lrwxrwxrwx 1 me wheel 27 Aug 23 15:18 IOobjectIO.C -> ../db/IOobject/IOobjectIO.C lrwxrwxrwx 1 me wheel 33 Aug 23 15:18 IOobjectList.C -> ../db/IOobjectList/IOobjectList.C lrwxrwxrwx 1 me wheel 33 Aug 23 15:18 IOobjectList.H -> ../db/IOobjectList/IOobjectList.H lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 IOobjectReadHeader.C -> ../db/IOobject/IOobjectReadHeader.C lrwxrwxrwx 1 me wheel 36 Aug 23 15:18 IOobjectWriteHeader.C -> ../db/IOobject/IOobjectWriteHeader.C lrwxrwxrwx 1 me wheel 37 Aug 23 15:18 IOPtrList.C -> ../db/IOobjects/IOPtrList/IOPtrList.C lrwxrwxrwx 1 me wheel 37 Aug 23 15:18 IOPtrList.H -> ../db/IOobjects/IOPtrList/IOPtrList.H lrwxrwxrwx 1 me wheel 36 Aug 23 15:18 IOstream.C -> ../db/IOstreams/IOstreams/IOstream.C lrwxrwxrwx 1 me wheel 36 Aug 23 15:18 IOstream.H -> ../db/IOstreams/IOstreams/IOstream.H lrwxrwxrwx 1 me wheel 27 Aug 23 15:18 IOstreams.C -> ../db/IOstreams/IOstreams.C lrwxrwxrwx 1 me wheel 27 Aug 23 15:18 IOstreams.H -> ../db/IOstreams/IOstreams.H lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 IPstream.C -> ../db/IOstreams/Pstreams/IPstream.C lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 IPstream.H -> ../db/IOstreams/Pstreams/IPstream.H lrwxrwxrwx 1 me wheel 40 Aug 23 15:18 ISLList.H -> ../containers/LinkedLists/user/ISLList.H lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 ISstream.C -> ../db/IOstreams/Sstreams/ISstream.C lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 ISstream.H -> ../db/IOstreams/Sstreams/ISstream.H lrwxrwxrwx 1 me wheel 36 Aug 23 15:18 ISstreamI.H -> ../db/IOstreams/Sstreams/ISstreamI.H lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 Istream.C -> ../db/IOstreams/IOstreams/Istream.C lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 Istream.H -> ../db/IOstreams/IOstreams/Istream.H lrwxrwxrwx 1 me wheel 39 Aug 23 15:18 Keyed.H -> ../containers/Identifiers/Keyed/Keyed.H lrwxrwxrwx 1 me wheel 40 Aug 23 15:18 KeyedI.H -> ../containers/Identifiers/Keyed/KeyedI.H lrwxrwxrwx 1 me wheel 39 Aug 23 15:18 labelBits.H -> ../algorithms/indexedOctree/labelBits.H lrwxrwxrwx 1 me wheel 42 Aug 23 15:18 LIFOStack.H -> ../containers/LinkedLists/user/LIFOStack.H lrwxrwxrwx 1 me wheel 31 Aug 23 15:18 List.C -> ../containers/Lists/List/List.C lrwxrwxrwx 1 me wheel 31 Aug 23 15:18 List.H -> ../containers/Lists/List/List.H lrwxrwxrwx 1 me wheel 32 Aug 23 15:18 ListI.H -> ../containers/Lists/List/ListI.H lrwxrwxrwx 1 me wheel 33 Aug 23 15:18 ListIO.C -> ../containers/Lists/List/ListIO.C lrwxrwxrwx 1 me wheel 45 Aug 23 15:18 ListListOps.C -> ../containers/Lists/ListListOps/ListListOps.C lrwxrwxrwx 1 me wheel 45 Aug 23 15:18 ListListOps.H -> ../containers/Lists/ListListOps/ListListOps.H lrwxrwxrwx 1 me wheel 36 Aug 23 15:18 ListLoopM.H -> ../containers/Lists/List/ListLoopM.H lrwxrwxrwx 1 me wheel 37 Aug 23 15:18 ListOps.C -> ../containers/Lists/ListOps/ListOps.C lrwxrwxrwx 1 me wheel 37 Aug 23 15:18 ListOps.H -> ../containers/Lists/ListOps/ListOps.H lrwxrwxrwx 1 me wheel 46 Aug 23 15:18 ListOpsTemplates.C -> ../containers/Lists/ListOps/ListOpsTemplates.C lrwxrwxrwx 1 me wheel 51 Aug 23 15:18 LList.C -> ../containers/LinkedLists/accessTypes/LList/LList.C lrwxrwxrwx 1 me wheel 51 Aug 23 15:18 LList.H -> ../containers/LinkedLists/accessTypes/LList/LList.H lrwxrwxrwx 1 me wheel 53 Aug 23 15:18 LListIO.C -> ../containers/LinkedLists/accessTypes/LList/LListIO.C lrwxrwxrwx 1 me wheel 57 Aug 23 15:18 LPtrList.C -> ../containers/LinkedLists/accessTypes/LPtrList/LPtrList.C lrwxrwxrwx 1 me wheel 57 Aug 23 15:18 LPtrList.H -> ../containers/LinkedLists/accessTypes/LPtrList/LPtrList.H lrwxrwxrwx 1 me wheel 59 Aug 23 15:18 LPtrListIO.C -> ../containers/LinkedLists/accessTypes/LPtrList/LPtrListIO.C lrwxrwxrwx 1 me wheel 34 Aug 23 15:18 Map.H -> ../containers/HashTables/Map/Map.H lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 NamedEnum.C -> ../containers/NamedEnum/NamedEnum.C lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 NamedEnum.H -> ../containers/NamedEnum/NamedEnum.H lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 OFstream.C -> ../db/IOstreams/Fstreams/OFstream.C lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 OFstream.H -> ../db/IOstreams/Fstreams/OFstream.H lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 OPstream.C -> ../db/IOstreams/Pstreams/OPstream.C lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 OPstream.H -> ../db/IOstreams/Pstreams/OPstream.H lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 OSstream.C -> ../db/IOstreams/Sstreams/OSstream.C lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 Ostream.C -> ../db/IOstreams/IOstreams/Ostream.C lrwxrwxrwx 1 me wheel 35 Aug 23 15:18 Ostream.H -> ../db/IOstreams/IOstreams/Ostream.H lrwxrwxrwx 1 me wheel 47 Aug 23 15:18 PackedBoolList.C -> ../containers/Lists/PackedList/PackedBoolList.C lrwxrwxrwx 1 me wheel 47 Aug 23 15:18 PackedBoolList.H -> ../containers/Lists/PackedList/PackedBoolList.H lrwxrwxrwx 1 me wheel 48 Aug 23 15:18 PackedBoolListI.H -> ../containers/Lists/PackedList/PackedBoolListI.H lrwxrwxrwx 1 me wheel 43 Aug 23 15:18 PackedList.C -> ../containers/Lists/PackedList/PackedList.C lrwxrwxrwx 1 me wheel 47 Aug 23 15:18 PackedListCore.C -> ../containers/Lists/PackedList/PackedListCore.C lrwxrwxrwx 1 me wheel 43 Aug 23 15:18 PackedList.H -> ../containers/Lists/PackedList/PackedList.H lrwxrwxrwx 1 me wheel 44 Aug 23 15:18 PackedListI.H -> ../containers/Lists/PackedList/PackedListI.H lrwxrwxrwx 1 me wheel 50 Aug 23 15:18 ParSortableList.C -> ../containers/Lists/SortableList/ParSortableList.C lrwxrwxrwx 1 me wheel 50 Aug 23 15:18 ParSortableList.H -> ../containers/Lists/SortableList/ParSortableList.H lrwxrwxrwx 1 me wheel 54 Aug 23 15:18 ParSortableListName.C -> ../containers/Lists/SortableList/ParSortableListName.C lrwxrwxrwx 1 me wheel 41 Aug 23 15:18 PstreamBuffers.C -> ../db/IOstreams/Pstreams/PstreamBuffers.C lrwxrwxrwx 1 me wheel 41 Aug 23 15:18 PstreamBuffers.H -> ../db/IOstreams/Pstreams/PstreamBuffers.H lrwxrwxrwx 1 me wheel 34 Aug 23 15:18 Pstream.C -> ../db/IOstreams/Pstreams/Pstream.C lrwxrwxrwx 1 me wheel 50 Aug 23 15:18 PstreamCombineReduceOps.H -> ../db/IOstreams/Pstreams/PstreamCombineReduceOps.H lrwxrwxrwx 1 me wheel 34 Aug 23 15:18 Pstream.H -> ../db/IOstreams/Pstreams/Pstream.H lrwxrwxrwx 1 me wheel 43 Aug 23 15:18 PstreamReduceOps.H -> ../db/IOstreams/Pstreams/PstreamReduceOps.H lrwxrwxrwx 1 me wheel 56 Aug 23 15:18 PtrDictionary.C -> ../containers/Dictionaries/PtrDictionary/PtrDictionary.C lrwxrwxrwx 1 me wheel 56 Aug 23 15:18 PtrDictionary.H -> ../containers/Dictionaries/PtrDictionary/PtrDictionary.H lrwxrwxrwx 1 me wheel 37 Aug 23 15:18 PtrList.C -> ../containers/Lists/PtrList/PtrList.C lrwxrwxrwx 1 me wheel 64 Aug 23 15:18 PtrListDictionary.C -> ../containers/Dictionaries/PtrListDictionary/PtrListDictionary.C lrwxrwxrwx 1 me wheel 64 Aug 23 15:18 PtrListDictionary.H -> ../containers/Dictionaries/PtrListDictionary/PtrListDictionary.H lrwxrwxrwx 1 me wheel 37 Aug 23 15:18 PtrList.H -> ../containers/Lists/PtrList/PtrList.H lrwxrwxrwx 1 me wheel 38 Aug 23 15:18 PtrListI.H -> ../containers/Lists/PtrList/PtrListI.H lrwxrwxrwx 1 me wheel 39 Aug 23 15:18 PtrListIO.C -> ../containers/Lists/PtrList/PtrListIO.C lrwxrwxrwx 1 me wheel 40 Aug 23 15:18 PtrMap.H -> ../containers/HashTables/PtrMap/PtrMap.H lrwxrwxrwx 1 me wheel 59 Aug 23 15:18 SLListBase.C -> ../containers/LinkedLists/linkTypes/SLListBase/SLListBase.C lrwxrwxrwx 1 me wheel 59 Aug 23 15:18 SLListBase.H -> ../containers/LinkedLists/linkTypes/SLListBase/SLListBase.H lrwxrwxrwx 1 me wheel 60 Aug 23 15:18 SLListBaseI.H -> ../containers/LinkedLists/linkTypes/SLListBase/SLListBaseI.H lrwxrwxrwx 1 me wheel 39 Aug 23 15:18 SLList.H -> ../containers/LinkedLists/user/SLList.H lrwxrwxrwx 1 me wheel 42 Aug 23 15:18 SLPtrList.H -> ../containers/LinkedLists/user/SLPtrList.H lrwxrwxrwx 1 me wheel 47 Aug 23 15:18 SortableList.C -> ../containers/Lists/SortableList/SortableList.C lrwxrwxrwx 1 me wheel 47 Aug 23 15:18 SortableList.H -> ../containers/Lists/SortableList/SortableList.H lrwxrwxrwx 1 me wheel 58 Aug 23 15:18 StaticHashTable.C -> ../containers/HashTables/StaticHashTable/StaticHashTable.C lrwxrwxrwx 1 me wheel 62 Aug 23 15:18 StaticHashTableCore.C -> ../containers/HashTables/StaticHashTable/StaticHashTableCore.C lrwxrwxrwx 1 me wheel 58 Aug 23 15:18 StaticHashTable.H -> ../containers/HashTables/StaticHashTable/StaticHashTable.H lrwxrwxrwx 1 me wheel 59 Aug 23 15:18 StaticHashTableI.H -> ../containers/HashTables/StaticHashTable/StaticHashTableI.H ...(truncated) Code:
ln -vs ../primitives/zero/zero.H $FOAM_SRC/OpenFOAM/lnInclude/zero.H `/apps2/openfoam/OpenFOAM-4.0/src/OpenFOAM/lnInclude/zero.H' -> `../primitives/zero/zero.H' |
August 30, 2016, 17:14 |
Ed Swindelles
Rep Power: 9 |
So I was getting nowhere and decided to rm -rf the directory that was untarred from the source download. I then reran the download and untar and this issue has gone away...¯\_(ツ)_/¯
Thanks all! |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 17:25 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
