[OpenFOAM.org] Paraview not found when installing OpenFoam to Ubuntu 14.04 |
May 17, 2015, 15:34 |
#61 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Guggelhupf,
OK, if my memory doesn't fail me, the problem can be fixed if you run these commands: Code:
cd $WM_THIRD_PARTY_DIR sed -i -e 's=//#define GLX_GLXEXT_LEGACY=#define GLX_GLXEXT_LEGACY=' \ ParaView-4.1.0/VTK/Rendering/OpenGL/vtkXOpenGLRenderWindow.cxx Code:
./makeParaView4 -no-config > log.makePV 2>&1 Sorry about this, because this issue is already fixed in the instructions for Ubuntu 14.10 and onward, on that very same wiki page, and I didn't have had the time/inspiration to re-test building on 14.04 with the same work-flow from 14.10 Best regards, Bruno
May 18, 2015, 03:37 |
#62 |
Björn Greis
Rep Power: 10 |
Hello Bruno and thanks for your recommendations. I will follow your instructions today evening when i am back from work.
Till later, Björn |
May 18, 2015, 14:39 |
#63 |
Björn Greis
Rep Power: 10 |
Hello Bruno,
I followed your instructions but are still unlucky. First point: When I type in: ./Allwmake > make.log 2>&1 or: ./makeParaView4 -no-config > log.makePV 2>&1 for the second time I do not get a summery of the installation like descriped in the Wiki. The second time needs less time then the first but do not give a summery. But there is no Error message after: icoFoam -help bjoern@Linux:~/OpenFOAM/bjoern-2.3.0/run/tutorials/incompressible/icoFoam/cavity$ icoFoam -help Usage: icoFoam [OPTIONS] options: -case <dir> specify alternate case directory, default is the cwd -noFunctionObjects do not execute functionObjects -parallel run in parallel -roots <(dir1 .. dirN)> slave root directories for distributed running -srcDoc display source code in browser -doc display application documentation in browser -help print the usage Using: OpenFOAM-2.3.0 (see www.OpenFOAM.org) Build: 2.3.0-f5222ca19ce6 bjoern@Linux:~/OpenFOAM/bjoern-2.3.0/run/tutorials/incompressible/icoFoam/cavity$ Second: When I follow the Tutorial and want to start ParaView through entering paraFoam I get the well known Error Message: FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers ./Allwclean ./Allwmake What can I do to solute this problem. We want to use OpenFoam at work and it would be really nice to get it on. THX |
May 18, 2015, 14:45 |
#64 |
Björn Greis
Rep Power: 10 |
Stop, everything is fine now. I was to fast.
After following the recommondations of Linux/OpenFoam: FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers ./Allwclean ./Allwmake It starts through ParaView with entering ParaFoam Thank you Bruno! I am able to work now. |
May 19, 2015, 11:06 |
#65 |
Björn Greis
Rep Power: 10 |
Hello together,
after finishing the installation of OF and PV I did not want to work on the tutorial cases. So now, I have the well known problem that I do not have a mesh in ParaView after entering paraFoam. I changed the language to english and entered " export LC_ALL=C" into the mentioned file. That did not help. How can I turn of the desktop effects and how have I to change the grafic card options? |
May 19, 2015, 11:40 |
#66 |
Björn Greis
Rep Power: 10 |
Now I updated the driver of my Nvidia grafic card but still no success.
May 20, 2015, 03:14 |
#67 |
Björn Greis
Rep Power: 10 |
Good news. OF as well as PV is working like I wanted to. To reach this I first selected another grafic card driver. But I dont think that this was it. After starting PV through entering paraFoam there was no (tutorial) mesh. Then I pressed the little button "apply" in PV and rebooted the pc. And than after following the tutorial I got it.
March 15, 2016, 22:07 |
For Paraview installation
#68 |
Rep Power: 11 |
Dear Bruno,
I am a new OFer, and have failed to install paraview3.12 on Ubuntu 14.04.3. The fatal error information is just like what have been mentioned by Jetfire, but the reason seems to be different with Jetfire's. Code:
FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers ./Allwclean ./Allwmake PS: Before this paraview edition, I installed Paraview 4.4.0 for OpenFOAM-v3.0 and did not remove it with changing its environment variables. |
March 19, 2016, 17:18 |
#69 |
Bruno Santos
Rep Power: 128 |
Greetings lisa_china,
Unfortunately the file you have attached is from the wrong folder You provided the file from the folder "ThirdParty-2.1.1", but I need the one from "OpenFOAM-2.1.1". As for ParaView being built properly or not, please provide the output from the following command (after you've activated the OpenFOAM 2.1.1 shell environment): Code:
which paraview Best regards, Bruno
March 19, 2016, 22:37 |
#70 |
Rep Power: 11 |
Hi Bruno,
Thanks for your reply. I installed OpenFOAM following instructions on the OpenFOAM official website. Here is the link: http://www.openfoam.org/archive/2.1....oad/ubuntu.php And it was strange that there was no output when I executed "which paraview" command. Sorry for providing a wrong file. The new attachment was generated when run Allwmake in OpenFOAM-2.1.1. I do not know whether it will provide useful information or not. Just as a reference There is a question: could I download output files from Linux system and perform post-process in paraview on my PC with window system? Thanks for your kind answer. Best wishes. Shan |
March 20, 2016, 14:13 |
#71 |
Bruno Santos
Rep Power: 128 |
Hi Shan,
OK, OpenFOAM 2.1.1 was built without any problems. All that is left is building ParaView 3.12.0. From these instructions: http://openfoamwiki.net/index.php/In...u#Ubuntu_12.10 - do step #9. More specifically, first please run the following commands: Code:
cd $WM_THIRD_PARTY_DIR sed -i -e 's/ClearAndSelect = Clear | Select/ClearAndSelect = static_cast<int>(Clear) | static_cast<int>(Select)/' \ ParaView-3.12.0/Qt/Core/pqServerManagerSelectionModel.h ./makeParaView > log.makePV 2>&1 gzip < log.makePV > log.makePV.gz You can also check by running: Code:
which paraview Code:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers wmSET $FOAM_SETTINGS ./Allwclean ./Allwmake Bruno |
March 20, 2016, 23:15 |
#72 |
Rep Power: 11 |
Thank you very much, Bruno.
I will try and feedback will be given after following your instruction. |
March 21, 2016, 09:01 |
#73 |
Rep Power: 11 |
GOOD NEWS, Bruno.
Paraview was installed successfully by following the instructions provided by you. Thank you very much, Bruno. You are a real expert on this fields. Best regards, Shan |
May 17, 2016, 05:51 |
Problem with paraview Instalation
#74 |
Pradeep
i use ubuntu 14.04 and i'm trying openfoam 3.0.1.
The error message in log.makePV file is : 1 error generated. make[2]: *** [VTK/Wrapping/Tools/CMakeFiles/vtkWrappingTools.dir/vtkParse.tab.c.o] Error 1 make[1]: *** [VTK/Wrapping/Tools/CMakeFiles/vtkWrappingTools.dir/all] Error 2 make: *** [all] Error 2 |
November 16, 2017, 09:26 |
#75 |
Jochum
Hello all!
I've installed the openfoam5 and paraview with the help of the openfoam website. The last thing they recommend is doing a tutorial to check if it al functions. thats were the trouble starts... after following the standard ./allwclean and ./allwmake commando's, it still gives back this error; "ERROR: ParaView not found in /opt/paraviewopenfoam54" And I agree with the error, as there is no folder in the OPT containing Paraviewopenfoam. But if I do a search for the location of the folder, it points towards the OPT folder. Could someone give me a hint on what to do? Last edited by JFe; November 17, 2017 at 03:11. |
December 30, 2017, 12:21 |
#76 | |
Bruno Santos
Rep Power: 128 |
Quick questions:
If not, then please indicate which specific installation instructions did you follow and in which Operating System have you installed it in?
Display Modes | |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
[OpenFOAM.org] Using OpenFOAM 2.3.0 from Deb pack in Ubuntu 14.04 + ParaView 5 from OpenFOAM 4.1 | ad2eb | OpenFOAM Installation | 12 | May 28, 2017 15:30 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
[OpenFOAM.org] (Script)OpenFOAM 2.3.0 and Paraview for Ubuntu 14.04 | p0kerus | OpenFOAM Installation | 2 | December 2, 2014 08:54 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
